Turbo extended warranty - Bimmerfest - BMW Forums
Old 08-30-2012, 02:34 PM
cooksta cooksta is offline
Mein Auto: 335i
Angry Turbo extended warranty
My '08 335i has just blown it's 2nd pair of turbos in less than 95k miles. The first set was replaced at 32k under warranty. My understanding at the time was that the replacement would be covered for another 50k from that point. However, once BMW extended turbo warranty to 82K I assumed my replacement would also be extended from the 50k to the 82k. BMW NA is saying that it expired at the 82k mark (32+50), though they are willing to pick up cost of parts and dealer will pick up $1k of labor leaving me to pay $1,500. Has anybody had this issue or have any thoughts on how to handle. I appreciate your help.
Old 08-30-2012, 02:50 PM
haskindm haskindm is offline
Mein Auto: 335I Convertible
Warranty was extended to 82K miles, period. Not sure I understand your question. The fact that your turbo was replaced does not effect the 82K mile warranty. The warranty expires when the car gets 82K miles on it, if they are offering you help beyond that, grab it!
Old 08-30-2012, 03:18 PM
Mein Auto: 335i
Appreciate the reply. Am I crazy to think the replaced turbo should be covered for 82k miles from mileage at replacement? Meaning the car itself would have 114k.
Old 08-30-2012, 03:37 PM
Ilovemycar Ilovemycar is offline
wooohooo
Mein Auto: '08 335i coupe 6MT sport
Not crazy, but maybe just a misunderstanding I suppose. $1,500 is not so bad IMO for this situation.
I may drop almost that much on maintenance on my beater truck as soon as the end of this week. Did fluid and filter changes on the wholesale level, replaced all front ball joints (and upper arms, no choice there), a couple of bumper brackets, self supplied PCV valve install, maybe finally deciding to fix an ABS sensor issue (it's a primitive tech here, so I didn't decide to do it last year), etc. It appears my radiator cap might have a tiny seal leak, and am thankful that the condensation evidence on the water pump is not due to a failing water pump. Last place I took my truck in for a steering rack did a sh!tty job on the boots, but I'm not paying to fix that unless I decide to get a whole new rack to begin with. Alignment now too, etc. If I ever have to replace a turbo on the BMW while out of warranty, I'd be satisfied with that price. It could be a lot worse I imagine.
Old 08-30-2012, 03:42 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
thats not how warranties work. they cover the car as a whole, not the individual part, so having a part replaced does not reset the clock.
bmw extended the coverage to 82K total vehicle miles.
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Present: 2019 G01 M40i ZDA/2VF/ZPP/ZPX/688/3AC
Old 08-30-2012, 03:52 PM
Mein Auto: 335i
Got it. Appreciate the feedback. I'll suck it up and take the deal. I love the car.
Old 08-30-2012, 04:06 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi 4dr; '03 330Ci
They offered you a reasonable deal and this may help reduce the sting a little more: Your replacement turbos will be covered by the BMW parts warranty. This is separate from the vehicle limited warranty (new or CPO) and covers genuine BMW parts installed by a BMW dealer for 12 months and 12,000 miles (whichever comes first).
The parts warranty covers parts and labor to replace the failed, covered parts. The time and mileage clocks start from the date & mileage on the invoice and apply only to the parts installed for that service. (It applies to over-the-counter parts purchases too but labor is excluded in that case.)
So if your new new turbos crap out within the parts warranty, you get NEW new new turbos free.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
2003 330Ci Sport 5MT - Black Sapphire Metallic / Natural Brown / Myrtle + the important stuff (+ go-fast stuff)
BMW CCA
Last edited by Zeichen311; 08-30-2012 at 04:13 PM. Reason: Verified warranty terms from an invoice
Old 08-30-2012, 05:44 PM
SuperTerp SuperTerp is offline
Mein Auto: R8, M4, M5. M3, 550, 335i
You don't have cpo correct? If so I'd be a little ticked (although 1500 for bmw turbos is an insanely good deal). In essence he assumed each set of turbos was covered for 82. Either way good deal and I'd thank the dealer.
Old 08-30-2012, 08:28 PM
BMWCCA 149159
Mein Auto: 17Ridgeline/14JGC/
Cooksta:
How are you driving this 335? I ask not to hammer you but understand how two turbos have been blown. It is very unusual to blow turbos unless you run them hard before the oil is up to temp because it will blow the seals.
Did the dealership happen to tell you what the issue with the turbos was?
I think the dealership is being fair with you.
How about telling us how you use it so we might be able to give you some thoughts on how to prolong life on those bad boys.
Old 08-31-2012, 11:01 AM
Kilgore Trout's Avatar
Kilgore Trout Kilgore Trout is offline
Chicks dig Wagons!
Mein Auto: E91
I was wonder the same thing. I've not read many posts about turbo failures and had presumed this was a rare event.
2009 E91 Montego Blue w/ Gray Dakota 6AT ZPP/Logic7/Sirius/Idrive/Butt warmers/6FL/PCD/CA/6NL/Xenons
Old 08-31-2012, 01:53 PM
daytrader daytrader is offline
Mein Auto: 2010 E92 335i
Originally Posted by fun2drive View Post
Cooksta:
Correct, it's very important to be up to temp before you WOT!
I'm even wondering why it's not in the manual and even better using dash engine warning lights the way M3s use to(not sure if they still do).
Old 08-31-2012, 02:09 PM
burnie35's Avatar
burnie35 burnie35 is offline
Old Timer (Really)
Mein Auto: 2020 BMW X5 XDrive40i
I think you got a fantastic deal! No charge for parts (from BMWNA) and the dealer knocks off $1000 of the labor ... wow! No complaints there...
2020 X5 XDrive40i M-Sport, Arctic Grey
2017 X5 35 M-Sport, Carbon Black, Black (Retired)
2009 535i Sport, Jet Black | Cobb Stage 2 Aggressive | Injen DCI | AR Downpipes | BMS Led Angel Eyes | Michelin Pilot Sport A/S Plus (Retired)
2008 528i (Retired)
2006 328ci (Retired)
1975 US Army (Retired)
Old 08-31-2012, 07:04 PM
Banned
Mein Auto: 2009 E93 N54
Like fun2drive & KT, mighty curious about exactly what failed on the turbos.
Mind you, replacement mighta been a shotgun blast. Or, could be a part problem so diff to access that turbo replacement; refurbishment elsewhere was the cost effective way to go.
Interested in wastegate issues in particular. They ARE adjustable! But one's a bugger to do even that....
Old 11-23-2012, 11:07 PM
sptt144's Avatar
sptt144 sptt144 is offline
Mein Auto: 2009 335i
With my JB4 installed I have the ability to disable the turbos and go to an economy mode. What exactly does this do to turn off (or bypass) turbos and is this bad for the engine? The car still runs pretty good although definitely about 60% of normal power but does not suck gas. However, not fun to drive at all this way
Old 11-24-2012, 03:16 AM
Squidget Squidget is offline
Mein Auto: 2011 335i E90 (MT,Sport)
Simplifying:
Turbos work by converting exhaust gas motion into rotating motion (via turbine), and that rotating motion drives a compresser fan. The compressor fan pushes more air into the engine, and thus more HP. When people talk about 'boost' pressure, it's the forced air they are describing.
There's a part, called a wastegate, that diverts most exhaust gas away from the turbo's turbine. When the gate is fully open (aka bypassing gases), the turbine doesn't spin much, and the turbo adds no real boost. Less air, less HP. Basically, the wastegate is the throttle for the turbo.
The wastegate is computer controlled, and one of the main things tuning packages such as JB4 focus on. There's no harm done by bypassing turbos, in fact it will likely prolong the life of your engine due to lower boost pressures.
BMW CCA Member
Old 11-24-2012, 03:57 AM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
OP did you ask the dealer for any insights as to why the trubos are failing? I too was under the impression that this was very rare.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 08-09-2017, 02:17 PM
osu9400 osu9400 is offline
Mein Auto: 2011 335d
Does the warranty extension apply to the 2011 335D?
Old 08-09-2017, 02:54 PM
need4speed's Avatar
need4speed need4speed is offline
Mein Auto: 16 435 CV Msport PPK, Q5
this
Old 08-09-2017, 03:29 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Breaking in the Pony
Mein Auto: 19 Mustang GT / 05 Tacoma
No. The warranty extension mentioned here is on the wastegates for the two turbos on an N54 gas engine.
Prior 44 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92 / 2015 BMW M235xi xDrive F22
Old 10-20-2019, 05:28 PM
mwae9312 mwae9312 is offline
Mein Auto: 2012 E93
can anybody link me to any official BMW document that extends the N54 turbo warranty to 82K miles. My dealer yesterday insisted that there is no such warranty applicable to my 2012 E93 335IS. I have the cold start wastegate rattle and now the car has suddenly started consuming oil. Not looking forward to pulling those puppies out, though i do have the rattle repair kit and the so-called turbo rebuild kits to replace the oil seals.
Old 10-20-2019, 11:29 PM
relative4 relative4 is offline
Mein Auto: '08 335xi E90 manual
Oddly, that warranty appears only to have applied to the main run of N54s through 2010, not to the 335is.
Old 10-21-2019, 02:33 PM
Zooks527's Avatar
PDF attached.
As relative4 notes, the warranty extension was for N54 engines through 2010 only. At that point in the game, they did some minor changes (I believe to the bushings) that dropped the occurrence rate down.
