Synth etic Oil Brand - Page 3 - Bimmerfest - BMW Forums
Old 02-21-2016, 10:09 PM
OlgaMPM OlgaMPM is offline
Mein Auto: E46
LL04 is a Low SAPS formulation not for use in U.S, Australia etc.
Old 02-21-2016, 10:47 PM
Andy320i Andy320i is offline
BMW E46 320i
Mein Auto: BMW 320i \ Ford Escape
Originally Posted by namelessman View Post
This is the reference to LL-04:
http://www.oilspecifications.org/bmw.php
"BMW Longlife-04 (BMW LL-04)
Special BMW approval for fully synthetic long-life oil. Viscosities are SAE 0W-30, 0W-40, 5W-30 and 5W-40. Usually required for BMWs equipped with a diesel particulate filter (DPF). Can also be used where a BMW Longlife-98 or BMW Longlife-01 oil is recommended."
Based on this if LL-01 is approved for E39 engines then LL-04 should be OK.
Thanks man. I assumed they would not be putting oil in my car that would be harmful. thanks
1995 Acura Integra (Sold)
2001 Mazda Protege MP3 (Sold)
2004 Acura RSX Type S (sold)
2001 Honda CBR F4i (sold)
2005 Ford Escape XLT 3L 4x4, winter beast
2004 BMW 320i Summer toy
Old 02-21-2016, 11:01 PM
Mein Auto: E46
Originally Posted by crazy4trains View Post
You only need to worry about the LL (Long Life) spec if you are going to run longer (say 15,000 mile) oil change intervals. Just use a good quality oil and replace it at a reasonable (say 5000-7500 mile) interval. Your cooling system will explode and leave you with warped cylinder heads before you will suffer any oil related engine damage. That is what you should worry about.
Motor on!!!
Totally incorrect. The LL01 spec sets minimum viscosity, minimum HTHS, etc. Best not to post on an oil thread if you don't understand oil basics
Old 02-21-2016, 11:14 PM
namelessman namelessman is offline
Mein Auto: bimmer
However, this PDF from BMW does say LL-04 is only approved for use in Europe:
http://www.opieoils.co.uk/pdfs/BMW-O...s-and-Recs.pdf
LL-04 supposedly is not suited to high sulphur level in US spec gasoline, although CA CARB-regulated gasoline seems to have sulphur level approaching Euro 5 spec(and the rest of US supposedly should follow by 2017). Maybe it is best to stay with LL-01 for now.
Old 02-21-2016, 11:17 PM
Mein Auto: bimmer
A side note is that BMW has moved to LL01FE and LL14FE which both has reduced HTHS in the name of fuel efficiency for MY16 and on N20/26/55 and B58 in US-spec cars. How can that be good for longevity of the engines?
Old 02-22-2016, 06:15 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
I do understand oil "basics". For these cars all that one needs is a basic understanding of oil. These engines are not "special" and do not require special or unique oil characteristics if changed on a reasonable interval. I have yet to read one thread documenting engine failure from somebody that used a good quality non-LL01 oil and that changed the oil at a reasonable interval. Although there may be some science behind the LL01 spec, the main reason for it was purely marketing. BMW's bottom line is what drove them to develop the spec and not the other way around.
I stand behind my earlier statement.
2002 530i
Old 02-22-2016, 10:40 AM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
If you said the oil cap name is purely marketing/bottom line, I would agree wholeheartedly.. I disagree vehemently that LL01 about the bottom line. Same goes for any manufacturer spec.
Done wrong, you get a VW 1.8T sludge factory.
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
Old 02-22-2016, 11:01 AM
Mein Auto: bimmer
Interestingly BMW now pushes LL-01FE on new cars, and that supposedly has HTHS of 2.9(versus 3.5 for FF-01). So nowadays even Mobil 1 5W30 with 3.1 and no A3/B3 seems to qualify for LL-01FE! But is HTHS of 2.9 really good for engine longevity?
Old 02-22-2016, 11:15 AM
I have yet to have an engine wear out before the transmission/body/electrical was done first.
Old 02-22-2016, 11:34 AM
Bingo. You win the prize.
2002 530i
Old 02-22-2016, 12:01 PM
Mein Auto: E46
Bluster. Can you explain why most XW30's don't meet spec for viscosity and HTHS yet BMW 5W30 does? We await with bated breath
Old 02-22-2016, 12:19 PM
eburnz's Avatar
eburnz eburnz is offline
30FF <3
Mein Auto: 2007 335i sport
so mobile 1 & castrol edge is still good to top off with even with this label change?
2007 BMW 335i Sport
Gone but not forgotten:
2007 550i SMG AMRTuned (Prod. 10/2006)
2004 BMW 530i (Prod: 7/2004)
2001 BMW 525i (Prod: 10/2000)
"Call it what you want, it's a BMW"
Old 02-22-2016, 01:03 PM
Mein Auto: bimmer
Your previous comment of "Done wrong, you get a VW 1.8T sludge factory." still means LL-01 is used to keep engine running so that transmission/body/electrical is done first, right?
The point though is that BMW is heading to a LL-01 "lite" spec, namely LL-01FE. So would you use LL-01FE instead of LL-01?
Old 02-22-2016, 01:57 PM
Please re-read my first post (#41).
I am sure that oil producers are producing better and better oils every day. My point is that "better is often the enemy of good enough". LL01 is good enough. Has been for 15 years. If the oil I buy tomorrow meets the LL01 spec of 10 years ago, but doesn't meet the new LL spec, then that is still good enough for me. I am not driving a high performance race car. Just buy a good quality oil from a major producer, (no dollar store stuff) and change it at a reasonable interval and all will be well.
2002 530i
Old 02-22-2016, 02:50 PM
Mein Auto: E46
As expected you didn't needs understand the question nor could you answer it.
Old 02-22-2016, 03:01 PM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Give it a rest, Olga....what he`s saying (and rightfully so) is that BMW engines are machines (albeit finely-crafted machines), but they`re not powering the bleeding Space Shuttle, for Chrissakes....
Let me remind you that many generations of car guys behind us ran their high-performance racing engines on dino oil for decades....
The road goes ever onward....
(R.I.P. Jever)
Old 02-22-2016, 03:34 PM
Mein Auto: E46
He stated LL01 is purely about oci length when it obviously isn't. Do you understand why even though he doesn't?
Old 02-22-2016, 05:50 PM
No I did not answer the question. Nor do I need to. I made a "qualitative" statement about motor oil quality and engine longevity. I am a car enthusiast, not a petroleum engineer. FastBob hit the nail on the head.
Enjoy your evening.
2002 530i
Old 02-22-2016, 07:08 PM
Fast Bob's Avatar
Keeping it surreal
Are you familiar with the old saying "Can`t see the forest for the trees" ? Well, you are definitely THERE, my man.... truth be told, I couldn`t give a rat`s ass about the technical merits of any particular oil, because I put faith in the fact that a whole team of engineers WAY above my pay grade formulated these oils to get the job done, as I`m sure they do....
(R.I.P. Jever)
Old 02-22-2016, 07:37 PM
Mein Auto: bimmer
It looks like for Mobil 1 0W40(and others too?) the issue is the the testing process is enhanced, and 0W40 no longer qualifies as LL-01. So the oil does not improve, but the testing improves, even when the spec LL-01 stays the same.
Old 02-22-2016, 07:53 PM
Mein Auto: E46
No I did not answer the question. Nor do I need to. I made a "qualitative" statement about motor oil quality and engine longevity. I am an car enthusiast, not a petroleum engineer. FastBob hit the nail on the head.
Enjoy your evening.
Hers a tip. If you know nothing about oil stay of oil threads. Simple as...
Old 02-22-2016, 07:55 PM
Mein Auto: E46
Oh dear...
Old 02-22-2016, 08:22 PM
My comment about the sludge factory means that spec'ing the wrong oil can have consequences. anyways, i would not rule out an FE oil purely on the basis of it being an FE oil, but that would not be my primary reason for using/not using it. I'd like to get some data before mixing it up, as what I'm doing now seems to be working out so far.
Old 02-22-2016, 08:50 PM
Mein Auto: bimmer
The subtle point is that the technical merits are the basis of the automaker's recommendations, so not understanding those merits (and/or demerits) will be a disservice to the consumers themselves. For example, when BMWAG starts to push LL-01FE as a substitute of LL-01, should consumers follow suite? Is the push of LL-01FE for BMWAG's benefits(e.g. CARB), or customer's(fuel efficiency)?
And the fact that the LL-01 testing is changed such that long standing, LL-01 is "demoted"(?) is an interesting development too. Should consumers feel confident to put any currently labeled LL-01 oil in their cars, since they put faith in the the engineers who originally came up with the rating, but now those oils fail the enhanced tests?
Old 02-23-2016, 09:02 AM
Oh my, you really are stuck on yourself!
I know a little bit about oil. That level of knowledge is good enough for me and most others on this board. I think I'll stay.
2002 530i
