4B06 - Set Zero Adjustment Cylinder 4 Injector - 2009 335d - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 08-12-2017, 07:13 PM
09bmw335d 09bmw335d is offline
Mein Auto: 335d
I started getting this CEL error recently, seems to reoccur every 150-200kms.
4B06 - Set Zero Adjustment Cylinder 4 injector.
I have a 2009 335d with 200,000 kms on it.
Had a lot of work done under warranty.
Last year I had the following done:
- Replace all 6 diesel fuel injectors
- Carbon cleaning
- Replace intake manifold
- Replace Engine Head
No issues since last year and 20,000km+ until couple of days ago.
It seems this error is probably related to having the DDE replaced now.
My question is that I don't notice any issues when the CEL comes on, do I really need to fork out 2-3K to get the dde replaced, or should I juts run it as is.
Any thoughts would be appreciated.
Old 08-12-2017, 07:26 PM
ingenieur ingenieur is offline
Mein Auto: 2011 335d M-sport
Has the crankshaft incremental wheel adaptation been reset? This must always be done after carbon cleaning.
Old 08-12-2017, 07:56 PM
Mein Auto: 335d
Not sure but the cbu and intake manifold was done at 145k. The head and injectors were done at 180k.
Old 08-13-2017, 03:13 AM
Doug Huffman's Avatar
Nuclear engineer
Looking at the carbon cleaning procedure ...
... it appears to require only that the Crankshaft Position pulse sensor be removed for locking TDC with Special Tool 11-2-300 and reinstalled. In the replacement procedure there is no mention of (re)adaptation.
There is a requirement to reset injectors zero adjustment after carbon cleaning.
Old 08-13-2017, 04:51 AM
Refer to the SIB 13 04 14 - it can be found in rippjd's post:
https://www.bimmerfest.com/forums/sho...15&postcount=2
Old 08-13-2017, 07:40 AM
Mein Auto: 335d
But the car has been fine for 20k after the last repair, so this would still fix?
Old 08-13-2017, 06:54 PM
Good question - I would readout the stored adaptation values (NMK) for all cylinders at each of the 3 rail pressure set points.
Old 09-08-2017, 05:52 AM
Mein Auto: 335d
Problem solved, I got the dealer to update the software to the latest integration level (1 hour labor), then I used ISTA+ / k-DCan cable to reset the increment wheel adaptation.
The error code has not come back yet, even the 4592 / 4593 errors that were being logged but not setting off a CEL have stopped occurring.
Old 05-28-2020, 11:51 AM
spamcop01 spamcop01 is online now
Mein Auto:
I did a CBU cleaning about 2-3 months ago and initially didn't have any SES warnings afterward. Then I started getting 4592 (Smooth running controller, cylinder 4) with a 4B06 (Zero-mass adaption injector Cylinder 4). I followed the suggestions many have had about resetting the crankshaft increment wheel adaptation and the ISTA+ app reported that it was successfully reset. However, it keeps coming back. I've also been experiencing periodic rough idling (not usually when I start the car, but after I've driven, parked, and started it again).
Here are some details on my setup:
2011 335d
Current Integration Level: E89X-14-11-501
ISTA/Rheingold System Version: 4.10.15.15600 (see attached versions list)
I also tried to reset some other adaptations that have been suggested on other posts/forums but with limited success (some succeeded, others failed).
Any suggestions on exact steps or things I should do to resolve this would be appreciated. I am NOT very skilled with ISTA/INPA so details are important.
Thank you!!
Old 05-29-2020, 12:59 PM
mik325tds mik325tds is offline
Mein Auto: 335d
2011 335d
Thank you!!
I'm a bit surprised that your DDE accepted the increment wheel adaptation reset request. That SW wasn't implemented until Integration level E89x-16-11-500 I believe. It is possible though that your DDE was updated by itself without ISTA-P which then doesn't update the integration level. Can you please use Tool32 and execute the job aif_lesen and check the SW#? It should be 8588675 for the newest SW.
Some of the other adaptations don't reset with standard OBD-USB cables, you'd need someone with and ICOM for that. But I don't believe that this is the reason for your DTC.
Another thing I'd suggest is to perform the "intake port sooting" measurement: It is in ISTA under troubleshooting, Function Structure, Diesel electronics DDE7 US, Air mass system, Intake port sooting. Make sure your engine is at operating temperature before you start. Post results here.
Old 05-29-2020, 05:21 PM
ard ard is offline
Resident Curmudgeon
mike325tds.
Quite an impressive post #1.
Not the usual "I just got a new BMW, isnt it shiny?" post one sees.....
Dont be a stranger. Thanks for contributing
OEM is not what BMW sells
Old 05-30-2020, 07:30 AM
Mein Auto: 335d
mike325tds.
Thanks for the warm welcome. I'm a regular on e90post forum and @spamcop01 asked me to look at his post to see if I can help.
Old 06-06-2020, 03:04 PM
Mein Auto:
Hi Michael! Think I ran the correct "intake port sooting" measurement per your instructions (PDF's are attached). I also attached a PDF from the Operations Report output when I was trying to reset adaptations back in April. As I reminder, when I did the CBU cleaning, I also blocked the swirl ports.
Much like with ISTA, I have no idea what I'm doing with Tool32, so I'll do some reading and see if I can get the aif_lesen job running to collect the SW#. OK, I found the correct PRG file to run the aif_lessen job and the results are also attached (says Software# is 8588676). If there is other data that needs to be collected, please send me the steps. I'm so bad at this that I can't even figure out how to gracefully exit from ISTA!!
This car was owned for most of its life by a little old lady in CA before I purchased it from her in November and just about all the service was done at a BMW dealership. I believe one can update the integration level using ISTA-P, but I'm not comfortable doing any programming like that. Is the dealership the only place to get it updated?
Old 06-07-2020, 07:11 AM
Mein Auto: 335d
Okay, the good news is that you did a good job cleaning your intake ports. The intake port sooting results are very good.
You definitely need a SW update on your DDE though. If you go to a dealer, make sure they don't talk you into replacing your injectors. They are most likely fine. Tell them to read SIB13-04-14.
If you want to take the drive to MI, I can do the SW update for you. Don't attempt it yourself unless you have a good power supply (not charger) with at least 50A. The procedure usually takes several hours.
In your operation reports I don't see that you did the increment wheel adaptations - you sure you did them?
Old 06-07-2020, 12:16 PM
Mein Auto:
Thx, Michael! Yes, I've executed the wheel adaptations reset multiple times and every time it says it's been successful. If I knew the proper steps within ISTA, I'd generate an ops report every time, but I'm still not sure how I even got the one I uploaded. As I said, I don't even know how to gracefully get out of it half the time. It's not a very intuitive tool.
Thx for the offer, but that's a pretty long road-trip. Can indy shops do this work or would you recommend sticking with a dealer? Also, what specific service do I ask for? For example, can I ask just for a DDE SW update or do I need a full integration level upgrade?
One other thing: in your note you metioned SIB13-04-14. In there it says "Target integration (new): E89X-14-11-501" which is what I'm on. But I still need a newer one, right?
Old 06-09-2020, 04:50 AM
Mein Auto: 335d
You can find printouts of each session in ISTA in the folder Rheingold/Print on your hard drive. I'd still recommend going to the newest integration level. Try going to a dealer and ask if they would preemptively update the SW of your car because of the problem with the FRM in the E90. That should be done at no cost because it saves them from replacing the FRM when it dies eventually. They usually flash the whole car to the newest integration level then.
