E46 2001 330ci Dinan 3 - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Closed Thread
Old 06-01-2020, 08:33 AM
Tron_330Ci Tron_330Ci is offline
keeping it clean
Mein Auto: 2001 330Ci Dinan 3
2001 330ci Dinan 3
Hello,
Im selling my 2001 DINAN 3 330ci
149,500 miles
Clean Carfax
Tabs good till February
smog cert and title in hand.
in excellent condition.
All mods installed by dinan engineering in morgan hill California.
Everything else is stock.
Sport package.
Multi function steering wheel
17in M3 rims (no rash)
power sport seats with big bolsters.
Car runs and drives amazingly.
No leaks engine or sunroof (sunroof drains are tested and clear) car has been maintained properly mobil one oil/mann filter/Highest octane,
when replacing packs and plugs last year i found everything was so clean,
DISA looked brand new when replacing old cracked rubber air intake boot with new.
Zero Vanos rattle and seal looks new.
Zero suction of oil cap when removed as the engine idles (I purposefully drive 20 min on freeway once a week to let her breathe if ive only done short trips that week)
Tires have 60% decent tread left.
Coolant expansion tank looks brand new! (most likely metal water pump is installed due to the new condition of everything else)
(has german auto solutions aluminum 1.2 bar 17.4 psi pressure release expansion tank cap)
Tail light wiring has been BMW dealership redone...(common failure)
Electric radiator fan converted..(preferred to stock engine mounted fan)
Even the dash clock can still be set.
All power everything works.
Key remote rolls down front windows, opens side rear windows and sunroof. (of corse sunroof shade works flawlessly)
EVERYTHING is there in the interior and all lights work.(has glovebox flashlight, it just needs a new battery)
Great brakes and power steering
Turns like a track car with dinan performance springs and koni adjustable struts feels so locked in with zero body roll.
Ive owned 2 years and only driven 3000 miles. Was my second weekend car until recently selling my 4x4.
I am now tired of not getting to work when it snows.....
I would chose not to go to work if there was snow on the road due to not wanting to risk someone sliding into and damaging the car. (from OCD issues)
I miss the lake and getting out to walk in the woods. Both places with roads id never take this car...
I have a nice AWD H6 Outback lined up and need this sold asap.
Tabs good till February/Clean Carfax/smog cert/title in hand.
Price is 4000.00 FIRM
More pics are in link...
https://www.facebook.com/marketplace...77483046222556
Car has ALWAYS been warmed up to ABOVE the cold blue gauge bar then stayed under 3k untill needle is in center of guage on EVERY drive.
I have been driving only manual cars for 26 years (i miss my 1976,malaga 2002) (i drive safe and never hard due to OCD and over sensory issues)
*only dash light is airbag, code is front left pillar./CarFax no bags deployed*
*slight 3rd gear knotch ONLY on cold mountain mornings BEFORE the transmission warms up (does not grind if driven cold by me, when colder out i rev match and shift lightly into 3rd all other gears are fine cold)..after transmission warms up its butter smooth and there is no way to make it knotch...*
*clutch engages high yet grabs fine, Currently my only car and i drive 3x week.*will need clutch soon
*Needs window switch tops, came with them not there.* (i use a chopstick or my pinky and all switches work well, i did not replace because i do not roll windows down ever and only use AC)
*front OEM badge was paint faded so i removed all paint, can still see the logo yet its not blaring BMW. I like it so much this way. I was going to do the same to the rear badge yet it was like new so i left it*
*Carfax recall is form 4 months ago for airbag, your dealer will fix free.*
Everything works well and is like new or replaced.
All windows/traction control/AC/DISA/VANOS/seals- all good looking working like new
No Check engine light/PASSED SMOG/CLEAN CARFAX/
2001 bmw 330ci dinan stage 3
150,000 miles
5 speed manual transmission
Dinan stage 3 rear badge
Dinan stage 3 proformance engine software tune
Dinan e46 freeflow exhaust
Dinan e46 throttle body
Dinan high flow e46 air intake box
Dinan carbon fiber e46 motor cover [expensive and discontinued]
Dinan front strut brace
Dinan rear strut brace
Dinan struts and springs
Dinan floor mats [for date nights] (expensive and discontinued)
Weather tec mats front rear and trunk mat. [For daily use]
Interior is 9 out of 10
Sport e46 power seats
All power windows and sunroof work flawlessly
Everything works well in and out
All tools are there in working tool flap.
No check engine light
Please message on facebook through my add only.
Thanks So Much!
Also comes with:
Stock BMW Business CD head unit (current aftermarket cd player has not powered up since i bought car, i bought this factory stock unit to plug and play yet did not mind hearing the exhaust notes instead.)
Full weathertech mats front/rear/trunk and DINAN e46 fit front/rear mats
new hella oil level sensor (needs to be installed on next oil change, 2 bolts and a plug in)
new VDO fuel level sender in box (thought mine was bad, upon inspection i found one wire was broken. I re-soldered/shrink tube/electric taped rite and now all is good... new sender is ready for when this one goes.)
stock lug bolts (locking bolts are now on)
New quart of 0/40 mobil one. (have not noticed in these 3000 miles of ownership that it burns oil much at all, i check level every fill up, have not needed to add oil much yet do not drive her much.) (oil and filter changed once every year Mann filter of corse)
a few extras from interior parts ive replaced, trunk interior light lens and the like.
Priced to sell cash as is 4000.00 FIRM with a new clutch this car will be bulletproof.
currently drives well with no slipping driving to work.
throttle is a consistent solid pull all the way through the range
if your use to stock you will be amazed.
can feel the push in your seat in 5th at 70mph
I know that the first one here with 4000.00 cash will drive it home with a HUGE smile.
I hope this rare car can go to someone who will take good care of it and not someone who wants to race/drift/or abuse it.
Old 06-02-2020, 11:52 AM
keeping it clean
With the state of everything and the fact that Mount Shasta is far from everyone.....
Here is a full walk around tour, no mask required.
*full walk around, windows/sunroof drop/exhaust*
https://imgur.com/NBAuMZr
*interior driverside*
https://imgur.com/kyVILmJ
*interior passenger side*
https://imgur.com/HeGUlHK
*trunk/tools/tires*
https://imgur.com/3FnkEzi
*dash/start/rev/motor close up sound*
https://imgur.com/mMFkzsS
Ive done my best to create the most detailed review of everything.
thank you.
Old 06-04-2020, 12:24 PM
keeping it clean
Filmed spirited driving to show clutch and driving condition..
Freeway on and off (3rd to 4th hick-up was my mistake, i was closing the sunroof at the same time)
https://imgur.com/sSTlC2h
Slower up and down shifts
https://imgur.com/ItDNbKB
Priced to sell ASAP.
sorry guys no trades, no holds,
4000.00 firm
SALE PENDING SUNDAY
Old 06-07-2020, 09:03 AM
keeping it clean
SOLD
Thank you to the new owner for understanding my social anxiety.
He is a BMW mechanic who knows what he has and deserves it.
He will most likely share on this forum in the near future.
I shed a tear while walking away from the car.
Yet,
I am on my way to get my rebuilt outback h6 in an hour.
MODS LOCK THREAD PLEASE
thanks for this forum and the ability to sell on it.
Closed Thread
330ci, clean, dinan, dinan 3, e46, sale
