Problem Solved Z4 3.0 SMG - Bimmerfest - BMW Forums
Old 04-05-2011, 03:05 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Smile Problem Solved Z4 3.0 SMG
Hey, I finally figured out why my 2004 Z4 3.0 SMG was running rich in Bank 1 and Bank 2 It was the k&n air filter. Removed k&n air filter replaced with stock air filter . No more rich condition and no more SES light !!!!!!!! I know a lot of people use the k&n filter and have no problem, guess my car just did not like it. Later all !!!
Old 04-05-2011, 03:18 AM
Swanicyouth's Avatar
Swanicyouth Swanicyouth is offline
Mein Auto: M Roadster
Those things are junk IMHO. So many have had issues.
Old 04-14-2011, 04:58 AM
X5M5 X5M5 is offline
Official Bangle Hater
Mein Auto: '01 X5 4.4i, '00 M5
Don't a lot of Cold Air Intakes (CAI) use K&N filters?
I have always been hesitant about running a K&N on a Mass Airflow car...
'01 X5 4.4i Topaz Blue/Black, '00 M5 Anthracite/Red, '06 Z4M Red/Black, '05 Acura RL White/Tan, '12 X6 3.5i, '17 540xi
Old 04-16-2011, 08:16 AM
dyerkes dyerkes is offline
Mein Auto: 2005 Z4 3.0 - SMG
That makes no sense. The MAF is what measures your air intake. You get into a lean situation when additional air enters your system without the MAF measuring in (somewhere between backside of MAF and intake runners. The K&N may well have allowed more air to be drawn into your engine, and your engine managmenet system was not able to compensate with enough fuel to offset the increased air flow. Perhaps you have an issue with your fuel system not being able to deliver an increased fuel flow. Perhaps you've got one or more fuel injectors that are dirty. Also, your fuel management system "learns" the fuel and air mixture ratio, and after a couple of hours of use and it self-adjusts (assuming you don't have other fuel or intake leak issues).
David
Old 05-05-2011, 04:06 AM
Yea, I know it did not make sense to me either. But, thats my story and I'm stick'n to it ! You can also check the Z4-FAQs and How-tos section it has a post about this in it. Later.
