Engine Malfunction. Reduced power. - Bimmerfest - BMW Forums
Old 12-29-2019, 12:36 PM
Wherespete Wherespete is offline
Mein Auto: X5 35i sport activity
Ok, so this popped up on my BMW today, it's a 2012 X5 35i sport, 82k miles. The issue is, "engine malfunction, reduced power" light came on, the 1/2 yellow version. The strange thing is, maybe I'm crazy or just an idiot, first started driving her today and my Sirius satellite radio was not getting a signal, no satellite radio. So, as I was driving, I called Sirius to try to get that problem fixed. The guy said to pull over, turn off the car so he could try to reset something. Started her back up, started driving, got to the highway, pushed her and bingo, the engine malfunction light comes on.... Needless to say, I headed back to my house, slowly, and now am wondering what the heck happened. Could there be any correlation between the Sirius guy dicking with my satellite signal and this malfunction light? Any ideas? Thanks in advance.
Old 12-29-2019, 12:41 PM
sohor1's Avatar
sohor1 sohor1 is offline
Mein Auto: 2012 X5 35i
Youíll need to pull the codes, it could be many things.
Old 12-29-2019, 03:00 PM
ard ard is offline
Resident Curmudgeon
This is where putting off spending 150 for that code reader all of a sudden seems needlessly frugal...'
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 12-29-2019, 05:16 PM
Well, so I decided to drive the car again, and right after I pulled out of my garage, the satellite radio was working normally....drove the car to a local auto parts store, the guy used his code reader on the car, and it indicated "no codes found". Could this thing have reset itself somehow? Maybe I should take it to another parts store, see if they find anything. Or I guess i could take it back out on the highway, see if the higher speed activates the "engine malfunction, reduced power" warning.
Old 12-29-2019, 05:37 PM
ard ard is offline
Resident Curmudgeon
Uh, as I said, this is where not spending the $150 on say a foxwell nt520BMW scanner seems like an issue
The parts store likely is using a generic OBD scanner, not a scanner that will read BMW codes....
Old 12-29-2019, 06:12 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Take the advice. Get a BMW specific scanner. Get the codes before you canít drive anymore. The BMW wonít fix itself.
Sent from my iPhone using Bimmerfe
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 12-29-2019, 07:54 PM
ard ard is offline
Resident Curmudgeon
Not trying to be a dick, BTW. Its A frustrating situation...instead of getting on with codes and troubleshooting you now have to wait for amazon!
Oh, you asked about a Sirius 'reset' (or whatever they did) possibly causing this issue. Not possible, IMO. Never heard of such a thing, and cannot see how something in the Sirius module can impact the DME.
But get any codes, and you'll get help here.
Old 12-29-2019, 08:02 PM
twh twh is offline
Mein Auto: '06 530xi 6sp
Here's the thing. Some codes are basic and able to be found by just about any code reader. Like a misfire code. But, the car has more than a dozen computers and a generic code reader isn't going to get all the codes. If the car had a iDrive message, there will be a code. You need a BMW aware code reader to get to many of them. That's what ard is saying to you. There are a number of BMW aware code readers, the one he pointed you to is one of them.
Old 12-29-2019, 09:28 PM
B4_685's Avatar
B4_685 B4_685 is offline
Mein Auto:
Just bought a NT530 on amazon - late xmas gift to myself hehe
Old 05-19-2020, 07:52 AM
steiny93 steiny93 is offline
Mein Auto: x5 xDrive50i
any update? were you able to fix the issue?
Old 05-19-2020, 09:06 AM
Yes, got it repaired a while back. My issue was a simple hose that had become unhooked from the turbo or something to that effect. Took it to my guy, he checked it, reconnected the hose and sent me on my way. Good news.
Old 05-20-2020, 03:21 PM
msan msan is offline
Mein Auto: 2012 X5 35i / 2011 E90 M3
Just happened to me yesterday. I have a 2012 BMW X5 35i N55 , 100k miles
Haven't been driving it much due to the stay at home orders. The prior time I drove it, it gave the discharge warning at start up so I drove it around and I hooked it up to a trickle charger overnight.
Next time, which was yesterday, I took it out, it drove fine for 10 minutes and then on the way home on a very slight downhill with minor acceleration it "misfired" and warning came up for reduced power, engine malfunction and I got these codes. Limped home.
2EFE
2F03
2EE0
2EF1
Not sure where to start for fix....I did restart the car and it ran fine with no warnings.
Old 05-20-2020, 03:35 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is offline
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
CHARGE the battery
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 05-20-2020, 04:45 PM
ard ard is offline
Resident Curmudgeon
2EFE
2F03
2EE0
2EF1
Give the battery a full and proper charge with an AGM charger.
Clear the codes. See if they come back.
Could be a ton of things, but start there....
Old 05-30-2020, 11:56 AM
OK so i charged it on a ctek charger set at AGM/snowflake and charged it until it showed full. Warmed up the car, drove it softly for 5-10 mins, no problems, then I decided to give it some gas and it bogged down and gave me the reduced power warning and lost power. I shut down the car and restarted and got my power back but eventually lost it again when I tried to accelerate hard. It was almost like the turbo couldn't help or maybe its fuel related.
Now I am thinking I have to bring it to a shop to diagnose. Was hoping it was just low charge on battery due to not using the car much.
Old 05-30-2020, 12:11 PM
propchef propchef is offline
Do You Smell That?
Mein Auto: 997.1
Spark Plugs. Mine showed the very same symptoms and it was the plugs.
Old 05-30-2020, 12:20 PM
Thanks for the suggestion. I did get them changed at 80k miles. So it has been a little over 20k miles since. About a little over 2.5 years ago.
I guess i have the time to redo them now with the virus. I just hope its not coils, hpfp, or injectors since I hate taking out all the junk to get to the spark plugs....
Appreciate the suggestion and will try and DIY the plugs
Old 05-30-2020, 12:26 PM
Do You Smell That?
Mein Auto: 997.1
The code said it was a misfire. Turning off the car, then restarting cleared the issues, until I got on an onramp or tried to accelerate. When I pulled the first plug it became obvious.
20k sounds low for a plug to go bad so it could be a coil.
Old 05-30-2020, 01:50 PM
Nuclear engineer
Coil outputs. How are they going to be affected by accelerating.
ID:	894695   Click image for larger version
Old 05-30-2020, 05:26 PM
ard ard is offline
Resident Curmudgeon
When you have a misfire WITH LEAN CONDITIONS, the DME disables the circuit- this protects the cylinder from a potenially damagiung 'lean fire'. When you restart the motor, it clears. Until it misfires again,
A coil (or plug) is unlikely to fail IN A WAY THAT CAUSES LEAN CONDITIONS (obviously). My first pass thoughts.
What codes- SPECIFICALLY- are you seeing now?
Old 05-30-2020, 05:57 PM
Do You Smell That?
Mein Auto: 997.1
If you're asking me, my mechanic made the same argument. There's a thread about it. I took my car home, changed the obviously corrupt plugs, cleared the codes, problem solved. This was late November. I just checked the codes again the other day (issues with the reverse warning systems) and there were no misfire codes and the car has been running well with predictable gas mileage. Other than losing an expansion tank, she's been fine.
Old 05-30-2020, 06:34 PM
ard ard is offline
Resident Curmudgeon
20k plugs? Doubtful.
HOWEVER, if they didnt change them...or used the wrong plugs, perhaps.
Old 05-30-2020, 08:15 PM
Codes I am seeing now. Look to be the same as the first time.
ID:	894755   Click image for larger version
ID:	894757   Click image for larger version
ID:	894759   Click image for larger version
Old 05-30-2020, 08:40 PM
ard ard is offline
Resident Curmudgeon
How old is the battery?
The misfire stuff seems like one thing...but the other codes are odd-ball 'low voltage' type stuff, or coding stuff. Has the car ever been coded? Anyone mess with modules, AWS, etrc?
Old 05-31-2020, 11:28 AM
I bought the car used from a BMW dealer in Illinois back in June 2017. It came with a Duracell AGM car battery. There are no date codes anywhere on the battery. I checked the terminals and all around but no date. The car build date is Nov 2011. So at some point in between 2011 and 2017 the battery was replaced.
I did not have this reduced power issue until after I let the car sit for weeks due to the lockdown. And I got a discharge warning.
If you think I should start with replacing the battery I can do that. I can buy one and install it myself. That is less hassle than trying to replace ignition items or fuel injectors. And I guess the battery is at least 2.5 years old.
Thanks again!
