Pro Nav IDrive - Bimmerfest - BMW Forums
Old 03-27-2020, 05:24 AM
M SPEC M SPEC is offline
Mein Auto:
Pro Nav IDrive
Hey guys can someone shed some light
on settings that are missing in my IDrive??
Lock settings gs are not present and the comfort blink option(blink three times in one touch).
I believe it's a coding issue.
Also can I program Daytime running lights to only switch on Parker's not low beam?
I think prior to purchase last week BMW has updated my IDrive/NAV software and not my maps as requested. But I can't find the software version for the IDrive.
Found maps software it hasn't been done (2009).
Any experts on this dilemma?
Thanks in advance
Old 03-27-2020, 05:42 AM
OnlyGerman OnlyGerman is offline
Officially a BMW Addict
Mein Auto: F15, F10, E60
What year is your E60?
"Itís what non-car people donít get. They see all cars as just a ton and a half, two tons of wires, glass, metal, and rubber, and thatís all they see. People like you or I know we have an unshakable belief that cars are living entitiesÖ" - Jeremy Clarkson
Old 03-27-2020, 11:23 AM
Mein Auto:
Hi mate thanks for reply! It's build 10/2008
Old 03-27-2020, 03:51 PM
Mein Auto:
Can anybody help? It's an E61 BTW
Old 03-27-2020, 05:18 PM
theroux theroux is offline
Mein Auto: 2006 E60 530i
What color is the iDrive settings? A brown or grey? Brown is the earlier version and a silver/grey means you have the latest update. You'll need to have coding done to get what you're looking for, I'm not sure why the 3 blink indicator option is missing though since even my 06 has that and I also have the DRL setting in iDrive (which is pointless since it just makes the xenons be on at all times in auto mode).
Old 03-27-2020, 06:48 PM
Assuming you have the CCC, there isn't much of a "update" to do. Also, not sure how options that should be there are not.
Old 03-27-2020, 06:51 PM
wcr3d wcr3d is offline
Mein Auto: 2013 535iX M Sport
It is also necessary to ask what country you are in?
Different options for different countries.
Also are you sure it is the Pro version?
Mein Auto:
It's CIC. Pro Nav the settings colour is grey
Old 03-27-2020, 07:11 PM
Mein Auto:
Sorry I'm in Australia. It's Australian delivered
Old 03-27-2020, 07:12 PM
Mein Auto:
Yes 100% pro
Old 03-27-2020, 08:19 PM
Use This link to determine which version you have, sorry the quickest I could find.
https://mca.electricmura.ro/en/blog-...or-nbt-idrive/
I ask you to do this as I think I there is confusion.
Also is your screen the full size of the window?
Things like business version doesn't always get the same options.
Old 03-27-2020, 10:19 PM
Mein Auto:
Guys the car has pro Nav large screen size it is optioned from factory with it. It is CIC has the one DVD Drive in center fascia, and 6 stack CD in glovebox.
Also has factory TV
Old 03-27-2020, 10:28 PM
Mein Auto:
My apologies it has code 609 which is CCC PRO NAV. But I read on the net if it had one DVD Drive and another CD drive in fascia it was CCC. I guess because it has 6 stack option in glovebox the CD drive is removed in fascia? Thank you for clearing this up wcr3d.
So as for lock settings missing can I get it back?
CCC I read not much I can do ***x1f614;
Old 03-28-2020, 05:55 AM
No problem, now it goes back to what was said about the brown and gray colors.
Gray being the latest.
I have never heard of options being disabled like you had stated.
I would start with decoding the VIN to find which options it is supposed to have.
There are a number of sites to do this and you can usually be able to save the list as a pdf.
Old 03-28-2020, 01:00 PM
Mein Auto:
Very confused
Is it possible that BMW have put a typo in for the coding/missing letter? It says 609- which means its a Pro NAV, so according to the link wcr3d has attached (which has helped thank you!) it states 609 is a CCC, 609A is a CIC, but the menu screen is not as described on the site.
I have a menu screen that you scroll through not one that looks like the iDrive toggle (joystick sort of image)- which means its a CCC. It also has the 8 button one DVD drive which they claim to be CIC. The car was built 10/2008 it is an Australian delivered car, is it possible the previous customer retro fitted to a CIC or BMW decided to fit CIC from factory as the car according to the site is just 1 month short of CIC iDrive NAV and BMW did not enter the letter "A" after 609 in the option coding list?
Old 03-28-2020, 01:04 PM
Mein Auto:
Maybe I have to pull it apart to confirm on the serial number label?
Old 03-28-2020, 02:34 PM
I guess it is possible but highly unlikely.
Your physical description suggests it is CIC.
When I had my e60, it was two disc drives and a cd changer in the glovebox.
As you see there is a big difference in between the two interfaces.
The odds would be better that someone did do a retrofit.
It could also explain your lack of certain categories.
Old 03-28-2020, 02:55 PM
Mein Auto:
Mmm ok appreciate your feedback
Old 04-07-2020, 01:18 AM
krisbiker2 krisbiker2 is offline
Mein Auto: 530i
2009 was the change year from CCC to Ci C. I had one. Thought when I bought it that it was a CiC as it visually looked like it. I then found the same as you, on investigation it appears there were a number of cars that had a mix of parts from both, the CCC of old, using up the stock they had with the front and controller off the CiC. Mine still had the double dvd slot tho, so you may have CiC , if you have there was an early software update to it that is required before it can be treated via USB, if yours has CiC, there will be a USB IN THE PASSENGER GLOVEBOX, ignore armrest USB, it's totally different
