Scratched Headlight Lens replacement - Bimmerfest - BMW Forums
Old 05-26-2020, 04:29 PM
QDP QDP is offline
Mein Auto: 2011 X-5 5.0i
Bought on Ebay two clear lenses, for my 2011 X-5 m sport 5.0. was told these are OEM, but from HK, well, they look fine.
Reg. mechanic says he won't touch 'em. Grrrr. My existing lenses just have been polished too often, kind of wilted, scratched/discolored.... Watched several You Tube vids but they all look and sound like idiots!
Any recommendations who to go to, who does this, So CA, Ventura area? Cost?
Anybody DONE this? Using a Dremel saw to cut them out along the edge....? Really? or drop entire assembly for 12 minutes in an oven at 200ļF, also I question THAT wisdom.
Appreciate your thoughts, THX
Quentin
Quentin Dart Parker, architect
www.ArchWork.com
2011 BMW X-5 5.0 Msport. loaded 140k miles Best E70 ever!
2019 BMW X-3 M40i loaded
Old 05-26-2020, 07:40 PM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Try a body shop rather than a regular mechanic. Insurance companies will specify just the lens if it is available and the other parts of the headlight are undamaged, so a body should be pretty well versed in the procedure.
FWIW the oven trick is well known and successful on the E46 side. The heat basically softens the sealing material so you can cleaning pull the lens. It depends on which headlight version you have on the E46 and I don't know enough about the E70 headlights to comment as to whether it will work or not but if the lenses are sold separately and there are tabs, it should be doable. Hairdryer on high is other method.
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 05-28-2020, 05:17 AM
ArgentoCarNut ArgentoCarNut is online now
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
Hi Quentin, in my experience, almost nobody wants to mess with this procedure due to the complexity and high-likelyhood of leaking/water ingress afterwards.
I did the work myself once when retrofitting a projector lens on a Toyota vehicle. I put one headlight assembly in the oven and used a heat gun for the other. This softens the Butyl glue that seals the lens in place so you can remove it and replace. You will need a roll of new Butyl tape to put in the lens.
Definitely not an easy or clean job. Good luck.
Old 05-28-2020, 06:06 AM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
You said the lenses have been polished too much and are scratched/yellowed. Have you tried a restoring kit with sanding pads? The 3M one worked well for me and lasted.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 05-28-2020, 07:31 AM
propchef propchef is offline
Do You Smell That?
Mein Auto: 997.1
I just bought this and will be doing it soon. https://www.chemicalguys.com/headlig...LEX_443_9.html
OP, maybe buy some used junkyard lenses and restore those? If anything goes wrong you still have headlights. #twocents
Old 05-28-2020, 07:57 AM
blue dragon blue dragon is offline
Mein Auto: X5 35D
This guy used to be big into the headlight modification and he can easily swap the lenses for you
https://www.lightwerkz.net/
http://www.wardphotography.com/sig10.jpg
| '09 X5 35D - Work horse (Sold) | '17 X1 MSport - Wife's daily | '17 - 340i MSport - My daily | '17 X5 35D - current work horse |
Old 05-30-2020, 08:10 AM
Do You Smell That?
Mein Auto: 997.1
Before and after.
This took 2 beers and 3 hours. Started with 2500 wet sandpaper and ended with carnauba wax.
Old 05-30-2020, 08:40 AM
What was that?
Originally Posted by propchef View Post
Before and after.
You gon hate me for this... but Costco and Samís Club offer this service with lifetime warranty for ~$30
Old 05-30-2020, 09:10 AM
Do You Smell That?
Mein Auto: 997.1
But do they give you BEER? HUH? No, they don't.
I goggled and couldn't find Costco doing it but Sams, yes. Sounds like they give it a quick wet sand then apply some kind of UV coating. And the price went up to $49.95 I spent less.
Old 05-30-2020, 10:59 AM
I donít know if you guys detail your own cars but if you do, follow same procedure for your lights as you do your paint.
I usually clay and wax once a year and just wax once. I always hit the headlight lenses and tail lights and Iíve never had to do anything more to my lights. I donít know if the automated car wash chemicals have an impact, I suspect they might. I prefer to drive a dirty car until I can hand wash it than taking it through the scratch master.
Just took picture of the 18 year old e46 this week after hanging those cabinets. I bought that car new and itís had zero body work so that headlight is original.
Sent from my iPad using Bimmerfest mobile app
Current:
2018 540ix
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 330i - 6 speed
Old 05-31-2020, 10:14 PM
ard ard is offline
Resident Curmudgeon
FWIW: Ive put on an Xpel headlight film after polishing. Provides UV protection as well as pitting/abrasion resistance.
Alignment here: The Definitive Alignment Thread
OE is Original Equipment aka 'BMW Original Parts' aka 'What you buy at the BMW dealer with a BMW label'
OEM is Original Equipment Manufacturer... EITHER the company that made the OE part or.... A part this is identical to the OE part, but is sold by the OEM under their own label
OEM is not what BMW sells
http://www.bimmerzone.com/category/T...ricks_OEM.html
https://www.turnermotorsport.com/t-OEvsOEM
Old 06-01-2020, 06:22 PM
What was that?
Do these come pre-cut to shape?
Old 06-01-2020, 06:41 PM
ard ard is offline
Resident Curmudgeon
Some models.
new lens install, scratched lens replacement
