Z4 Cigarette Lighter Fuse - Bimmerfest - BMW Forums
Old 11-13-2009, 03:55 AM
aspinalj aspinalj is offline
Mein Auto: BMW Z4 2.0 SE
Hi,
I managed to blow the cigarette lighter fuse in my 2006 Z4 the other day. There's no indication in the fuse box as to which it is. Can anyone help, please?
John
Old 11-16-2009, 08:48 AM
courtier courtier is offline
Mein Auto: 2004 Z4
Coincidentally, the same thing happened to me about a week ago when I was testing out a new cigarette-lighter-powered air pump that I purchased after converting to non-RFT's. It's a blue 15amp fuse in space #5 I think. There should be a white fuse guide to the left of the fuse panel that lists which all of the systems the individual fuses correspond to. I think it's #5, but I'd verify that for yourself.
Old 04-25-2010, 05:15 PM
Master Apex Master Apex is offline
Mein Auto: Z4MC
My accessory (lighter) plug has no power also, where is this blue 15amp fuse space #5 located?
Old 04-25-2010, 05:23 PM
johnsock's Avatar
johnsock johnsock is offline
Mein Auto: E82, E84
Fuse box is behind the glove compartment, there should be a card in there showing fuse positions. Once open, you can unlatch the rear portion of the glove compartment and it will swing downward on another set of hinges, exposing the fuse box.
Old 06-19-2010, 06:27 PM
mallen726 mallen726 is offline
Mein Auto: 2006 Z4 0si
the fuse diagram is no help as there is no symbol that looks anything like a cigarette lighter!!
Old 06-19-2010, 08:14 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Did you see post #2, 3 and 4.
Old 06-19-2010, 08:16 PM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
The glove box has two clips on the inside at the very top. With some slight pressure and the clips pressed the glove box will pull down. #5 is the bottom row, second fuse from the left 15 amp ( blue ) fuse.
Old 04-02-2011, 12:09 PM
Laura Grantham Laura Grantham is offline
Mein Auto: 2003 Z4
Smile 2003 bmw z$
Many Thanks. It is fuse #5, a 15 amp fuse. I replaced it and now its working again. The diagram was missing from the fusebox. It sure would be great if BMW would put the diagram in the owner's manual too.
