Towing Photos with X5. - Page 16 - Bimmerfest - BMW Forums
Old 12-11-2017, 08:36 PM
kanar200's Avatar
kanar200 kanar200 is offline
Mein Auto: X5d 2011, 530e
Not sure why there is "lol", but yes, some self-adjusting brakes required backing up the trailer. Apparently, the self-adjusting brakes in my trailer can adjust going forward and backing up.
Originally Posted by Kostyan View Post
could you please elaborate. Are they self-adjusting by backing the trailer up? lol
Ultimate Towing Machine - towing Jayco 28DSBH (2017)
We travel not to escape life, but for life not to escape us.
Old 12-11-2017, 08:41 PM
kanar200's Avatar
And one photo from the recent trip.
Old 12-12-2017, 07:01 AM
Kostyan Kostyan is offline
Mein Auto: 12 X5 diesel, 04 330 CIC
Never heard of self-adjusting (esp. that way) trailer brakes, hence the LOL - your input is appreciated and hope you don't take it the wrong way. Not sure if there is a way to verify if my trailer has self adjusting brakes.
Thanks for posting useful info everyone. It appears that I have paired the Prodigy correctly and left it at default boost setting because it felt providing the right amount of braking force at the time. The main culprit is pulsating trailer brakes, which is really amplified and felt in the car - but at no point in time my rig and family felt we were not safe. The rig stops on a dime. The trailer is parked for the winter, and come spring I will play with setting to see if that helps with pulsating, or take trailer to a shop,
Old 12-12-2017, 07:10 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
Brakes needing adjustment are drum-shoe brakes and self-energizing. During normal ahead braking the shoe assembly shifts slightly to bite harder. During reverse braking the same shift will engage a ratchet pawl-wheel on sufficiently worn shoes to expand the adjuster one ratchet per backing braking.
Self-energizing makes modulation more difficult and causes the trailer surging.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 03-09-2018, 01:52 AM
kakalika's Avatar
kakalika kakalika is offline
Mein Auto: 12 X5 d, 08 535, 02 530i
Rented a trencher yesterday
Run flat tires? Nein Danke!
Old 04-04-2018, 01:47 AM
kakalika's Avatar
My E60 project!!
Old 04-04-2018, 06:20 AM
road ruler road ruler is offline
Mein Auto: 2010 BMW X5 Sport
Looks nice!!!!
Old 04-04-2018, 06:49 AM
kanar200's Avatar
Without seeing photos, I thought that you are towing with E60.
Old 04-04-2018, 09:53 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
That X5 is earning its keep.
What's the story with the E60?
Current:
2018 540ix
2015 428i convertible
2013 Cooper S
2007 650i - 6 speed
2002 330ci convertible - 5 speed
Past:
2012 X5 Diesel
2012 Countryman S All4 - 6 speed
2006 Cooper S - 6 speed
2006 330i - 6 speed
1997 328is - 5 speed
1991 318is - 5 speed
1988 635csi - 5 speed
1988 325i convertible - 5 speed
1969 2002 with tii and 5 speed conversions
Old 04-04-2018, 02:18 PM
35dx5 35dx5 is offline
Mein Auto: 2012 X5 - 35d -- 131k
trailer brakes pulsate
hey, my guess in your pulsating brakes /
your inboard brake settings in your features on brake lighting. needs to be programmed properly, some settings on brake light control flash, if its set that way. They can be set to flash, pulse and or intensity of brake force, I believe.
Was it a factory harness, or dealer installed wire harness and hitch. I've read in the past that the bmw harness is worth every penny.
other than that maybe water in your tail light sockets / shorting the two stag brake lights.
maybe an abs sensor too close to its exciter ring after all else. but usually you would have a code.
Old 04-05-2018, 02:12 AM
kakalika's Avatar
Bought it from Copart with accident damage. Just removed all the damaged parts and was taking it to have the frame rail inspected for damage.
Old 04-10-2018, 11:23 AM
asbjorjo asbjorjo is offline
Mein Auto: 2013 X5 35D
From our trip to Arizona this Christmas, taken at White Sands in New Mexico.
Except for a few spots with heavy crosswinds we could set the cruise at 72. Hadn't it been for the lack of view out rear and not so great mileage you'd never know the trailer was there. Have since added extended mirrors and a Hayes Sway Master.
Old 04-10-2018, 11:46 AM
kanar200's Avatar
Check the speed rating of your trailer tires. Many are rated to 65 mph.
Old 04-10-2018, 02:04 PM
Michael47 Michael47 is offline
Mein Auto: '12 X5 35d
(IMAGE MISSING IN ACTION)
(1) can't see the image because I don't have your google login name/password.
(2) vehicle handling is a function of tire pressures, both of the trailer and the tow vehicle. Given that BMWs have sporty handling, tire pressures are especially critical. If they aren't high enough, you get directional instability as well as lack of grip, meaning they will skid sideways easily, too. They also run hot, leading to possible blow-outs.
I have no idea what you were towing (see #1 above), but I can tell you that my X5 towing a 5,000 lb travel trailer tows straight as an arrow without any anti-sway mechanisms. I have also had private conversations with several people here who have expressed directional stability issues, and every one of them has been running with tire pressures too low, that once corrected, found their issue resolved. While the Hayes Sway Master may have eliminated your sway, you would be well advised to check tire pressures, as there are additional safety issues involved beyond sway with under inflated tires.
'12 X5 35d
'05 Jeep Libby CRD (now deceased)
'01 VW Jetta TDI
formerly '69 BMW 2002 and '67 BMW 2000CS
Old 04-10-2018, 04:31 PM
My bad, been a while since posting photos to forums. Should be visible now.
I used to race road bikes, then moved on as race mechanic, so reasonably OCD about tire pressure. As I mentioned above it's perfect except for strong crosswinds, particularly with passing big rigs. Think driving through West Texas in northern winds.
If reducing speed a bit it's perfectly fine in wind as well, but will still notice when big rigs blast past. The Sway Master takes care of that so that's not noticeable anymore either.
Old 04-10-2018, 10:23 PM
kanar200's Avatar
I am towing fairy often and fairly large trailer. I always tow with max pressure in the rear wheels (50 psi) and increased pressure in the front. Also, I feel the difference between low profile wheels (20 inches) and higher profile wheels (18 inches, which I am using during winter for ski trips).
Old 04-23-2018, 06:35 PM
kakalika's Avatar
Rented this to move some dirt. Home Depot claims a total weight of 6000 pounds. Still using my Invisihitch.
Old 04-23-2018, 09:14 PM
kanar200's Avatar
Did they just let you hitch up at Home Depot or you needed to sign the docs with your blood that you are responsible for your actions?
Old 04-23-2018, 09:28 PM
kakalika's Avatar
They came out and hitched me up. Tested that my lights were all working before letting me drive off.
Old 04-28-2018, 02:22 PM
cjrussell cjrussell is offline
Mein Auto: 2012 X5 diesel
I have a 2012 X5d too. Pull a 1952 Chris Craft Riviera 2x annually about 90 miles. Boat and trailer are 3300 lbs. fully loaded, with 300 lbs. tongue weight. Have no rear dip and handles great relative to pick up with 200 lower torque rating.
Sent from my SM-N950U using Bimmerfest mobile app
Old 05-04-2018, 03:34 AM
kakalika's Avatar
More work for the X
2500 pounds empty trailer weight, plus whatever 3.5 yards of fertile loam soil weigh.
Old 05-04-2018, 03:47 AM
kakalika's Avatar
Is your boat like this? Beauty!!!!!
Old 05-04-2018, 06:23 PM
SoCaLE39 SoCaLE39 is offline
Mein Auto: E60 M5, E46 325i
Few weeks back. The other project I'm working on...
Old 05-06-2018, 08:26 PM
kanar200's Avatar
New Brighton Beach, CA
Dog clearly not ready to go back home
Old 05-08-2018, 08:31 PM
Not towing much these days but doing a lot of cycling. Just upgraded my trailer hitch mounted bike carrier to a carbon fiber frame friendly setup.
FWIW, with no bikes on, the carrier allows the tailgate to open without tilting it out of the way. Nice surprise.
Current:
2018 540ix
2013 Cooper S
2007 650i - 6 speed
Past:
2012 X5 Diesel
2006 330i - 6 speed
