Fog Light Assembly Replacement - Bimmerfest - BMW Forums
Old 10-09-2019, 08:27 AM
Aerospike Aerospike is offline
Send a message via ICQ to Aerospike
Mein Auto: 2014 X1 35i
Good morning,
I can't find a whole lot of info on this, but from what I found it seems like I have to take the whole bumper off to replace the broken fog light? Also what's the P/N I need for the RH assembly shown? I have adaptive headlight, but I don't know if that bumper has the aero package.
Name:	RH Fog Light.jpg
Old 10-09-2019, 08:32 AM
Doug Huffman's Avatar
Nuclear engineer
RealOEM.com for part numbers. www.NewTIS.info for procedure.
Old 10-09-2019, 09:06 AM
Thanks, I can't find replacement of the assembly on TIS, just the bulb:
https://www.newtis.info/tisv2/a/en/e...lamps/AliaHU09
From the diagarame, it seems like you have to remove the entire assembly to replace the bulb. I'm assuming screws (2)secure the entire assembly and not just a bulb retainer.
Name:	Fog Light Aft Side.png
Old 10-09-2019, 01:36 PM
stonex1's Avatar
stonex1 stonex1 is offline
Mein Auto: 13' X1 35i
More info here.
It might be easiest to remove the plastic under shielding. Lots of small screws, but will give you easy access to the housing area on either side of the car.
Should be three screws to remove the lamp.
2013 X1
MinGrey,Xenon,HK,PwrSeats,Sirius,XLine,Nav
Old 10-09-2019, 05:03 PM
Yukoner Yukoner is offline
Mein Auto: 2011 328i x-drive
https://www.fcpeuro.com/products/bmw...ft-63172993525
Interesting it specifically says "w/o Adaptive Headlights". Are the fog lights adaptive as well ? I didn't realize that the fogs had anything to do with the headlights.
Not even sure if -40 degrees is cold anymore ?
Old 10-10-2019, 06:50 AM
The fog lights come on individually when you turn the steering wheel to light up the corner.
Old 10-10-2019, 07:49 AM
Nuclear engineer
Originally Posted by aerospike View Post
the fog lights come on individually when you turn the steering wheel to light up the corner.
+1
Milady Wife can't see the headlights adapt around the corner or the fog light light up the corner. Notice the assymetrical reflector internal to the fog light housing.
Old 10-10-2019, 08:27 AM
Silly question, which bumper do I have? The parts website doesn't show that even when I enter the VIN.
Old 10-11-2019, 05:59 AM
87bimmerguy 87bimmerguy is offline
Mein Auto: 95 M3/01 525iT
I'm not familiar with the X1, but if it's the same part as the X3, there is a small metal tab on top of the light, if you depress it with a screwdriver you should be able to slide the whole lamp out the front.
Old 10-11-2019, 09:00 AM
Still wondering which bumper I have. I thought it was the base bumper without the aero package, but realOEM is not confirming that.
Old 10-11-2019, 10:24 AM
Markst Markst is offline
Mein Auto: BMW 5
You have the standard lci bumper.
Old 10-11-2019, 11:01 AM
rice_rocket88 rice_rocket88 is offline
Mein Auto: 2008 535xi
As 87bimmerguy said... you just need to get a thin screwdriver and push the tab on the top and the foglight will come out. I just went online amazon to buy myself a replacement foglight. The exact same one my wife broke (got hit by some random rock).
Old 10-11-2019, 11:50 AM
FWIW, I have the same bumper on my X1 (from what I can tell from your pic), and I do not have the aero package either.
Old 10-15-2019, 05:31 AM
Thank you!
replace fog light assembly
