Welcome to the 5-Series DIY Forum... - Bimmerfest - BMW Forums
5 Series DIY
Old 04-28-2003, 11:28 PM
Jon Shafer's Avatar
Bimmerfest Founder
Mein Auto: E92 M3 Cp + E30 325
And welcome to vietsb as the forum moderator...
I also want to call everyone's attention to the quintessential
e39 DIY site, BMWTIPS.com.
Pssst. Check out the irc BMW chat networks they've got
going over there too...
P.S. watch out for the guy named 'wolf'...
Old 04-28-2003, 11:29 PM
PropellerHead's Avatar
Brevity= the soul of wit
sah LUT
Old 04-29-2003, 02:50 AM
vietsb vietsb is offline
Mein Auto:
HOLA!
Now, I just need to post ~950 more times to get a cool avatar under my name.
I'm gonna start making a list of E12, E28, E34, E39, and (gulp) E60 Do-It-Yourself sites. If anyone has some favorites, please pass them my direction so I can refer other folks as well.
I posted my intro here if anyone wants to take a gander.
I hope to see folks post their DIY experiences here, to other BMW forums, and to model-specific sites like BMWTips.com.
Old 04-29-2003, 11:52 AM
Ågent99's Avatar
Ågent99 Ågent99 is offline
Moderator, 5-Series
Mein Auto: 2017 340i
Originally posted by vietsb
HOLA!
Pssst....notice my avatar and serious lack of 1000 posts!!???
Talk to "Da Man" JS...he'll set you up just right!
Chris
Old 04-29-2003, 11:57 AM
Mein Auto:
Yeah, I know. But I plan on doing it the old-fashioned way. Just got one step closer!
Old 04-29-2003, 11:59 AM
Ågent99's Avatar
Moderator, 5-Series
But you're a Moderator right now...special privileges but, hey, suit yourself!
Chris
Old 04-29-2003, 12:02 PM
Now THERE'S a man after my own mind.
Ahem... juuust over 200 more to go.
Old 04-29-2003, 12:06 PM
Mein Auto:
Speaking of privileges...
When you gonna give us the privilege of visiting Casa'de'Agent99 for some CDV liberation? I'm gonna be gone the last weekend in May, but otherwise, I can work my schedule around your "soon to be" announced date.
Hey, do you know how Jon did the sticky for your CDV post on the 5-Series forum? Or do you have to be a super-mod to do that? I'd like to post a "DDIY-LADIFYFKK" sticky when you actually pick a date.
(Don't Do-It-Yourself - Let Agent99 Do-It-For-You For KrispyKremes)
PS - I still have a $125 arbor pilot bit w/ your name on it.
Old 04-29-2003, 02:11 PM
Ågent99's Avatar
Moderator, 5-Series
CDV will most likely happen in June...christ...it is nearly May already.
Yeah, I gotta take care of that arbor bit some time....
Chris
Old 05-10-2018, 04:19 PM
solobolo719 solobolo719 is offline
Mein Auto: 07 bmw 530xi
Does. Anyone have the preventative maintenance pdf for the e60? It showed mostly everything you need to replace or flush to keep the car. Ru ning into 200k.
Old 10-30-2019, 05:29 PM
Jakedoub Jakedoub is offline
Jakedoub
Mein Auto: 2003 BMW X5
New to forum - 2003 X5 help needed. I hope I am creating this post in the correct location, but if not, please advise. I have a 2003 X5. I just purchased this vehicle from someone who tried to fix some things themselves; however it is apparent they did not know anything about vehicles. I have replaced the door latch assembly on 3 of the 4 doors as they were all broken. I've changed the window regulator on all of the same doors. The key doesn't work in the lock tumbler on the door, and I'll rebuild that later. The front drivers door handle assembly now works as you would expect, it opens from the interior and the exterior. The front passenger door worked from the interior only. After replacing the door handle assembly, the door does not open from the interior or exterior. I can use the fob to lock and unlock the vehicle, but only the drivers side will actually unlock... the front and rear passenger side doors will make a noise, and the lock mechanism will go up and down, but the handles on both the outside or inside will not open the doors. I am assuming these doors are "deadlocked"...? I've scanned through many threads and have not found anyone explaining how to open a door that is closed when it is deadlocked. I'm a medium skilled mechanic, so I've done all of the typical things that would be suggested. I can access the latch assemble through the interior door panel, as they are still removed, and I can move the linkage to open the door... but it will not actually open the door. Does anyone have any suggestions on how to get my passenger side doors open? I'm assuming that the door lock actuators will need to be replaced, but I can't open the doors to replace them. I would also take a guess and say that I would be able to apply 12v power to the correct wires that connect to the door lock actuator to get it to engage or disengage, but there are about 8 wires going to the lock actuator and I'm not sure which ones to supply power to, and I'm not sure of this would even work. Any help would be greatly appreciated. This vehicle is for my wife, and her father is coming in 4 days, and it's also the first time I'm meeting him... so it'd be really cool to have this fixed before he comes. Thank you for any help, and again I apologize if this is not the correct location for this post. Jake.
