E70 Radio From Hell - Bimmerfest - BMW Forums
Old 11-06-2019, 09:23 AM
atroyan atroyan is offline
Mein Auto:
E70 Radio From Hell
Hi All,
My radio/cd is staying on after I remove key and lock the car the radio will not go to sleep, if i press the mute button on my radio after the car is off and door is locked, the audio will start to play (no idrive display, just audio from the radio) and I can hear the fan running on it. Because of this, I am getting a high battery drain warning. Has anyone ever seen this before ? i've attached error from my bav tech scanning:
Instrument cluster
Current Fault Codes
A559:
Clamp 30g-f switch off
Error will not cause a warning light
Error is not currently present
Test conditions have been completed
Audio system controller
Current Fault Codes
ABD3:
MOST/CAN radio gateway CD73/MD73
Current Fault Codes
E18D:
E18D Wake up device tried to wake up network 3-times without success. (Error_WakeUp_Failed).
E18F:
E18F Central registry does not match with debit configuration (Error_Registry_New).
Telematic control module
Current Fault Codes
A387:
Bluetooth antenna defect or not connected (ERROR_BT_ANTENNA)
Error is currently present
