7/70,000K timing chain warranty. - Page 6 - Bimmerfest - BMW Forums
Old 03-17-2019, 11:36 AM
namelessman namelessman is offline
Mein Auto: bimmer
Originally Posted by mikessc View Post
Look for black connector with GREEN dot on it in the attached photo.
Thanks!
Looking at the photo, it looks like the borescope somehow needs to do a 90-degree turn through a straight circular opening, probably BMW needs to make some special tools.
Also, does the sensor just the plastic part with the green dot, meaning the cylinder part on top cannot be removed?
It looks like that cylinder part needs to be gasket sealed from the inside(and cannot be removed unless VC is off), or else the camshaft sensor area can leak.
Old 03-17-2019, 12:06 PM
Mein Auto: bimmer
It looks like a plausible way to examine the plastic guard rail snap on is through the oil filler cap opening, but some special semi-rigid borescope extension bent at the correct angle(s) is needed.
Looking at mikessc's photo of the upper guard rail, and shining flashlight through my oil cap opening, there is a clear path through the 2 plastic loops, towards the snap-on area.
Old 03-17-2019, 12:07 PM
mikessc mikessc is offline
Mein Auto: F10 2012 528i
Originally Posted by namelessman View Post
Thanks!
To remove the sensor, disconnect the connector first.
The sensor is fasten to the bottom of cylinder header near where the connector was located.
Google for following parts number and visit ecstuning site which has images on the parts.
The O-ring cost about USD2 only.
Camshaft Sensor
13627525014
O-Ring
12141748398
You can find all the parts number at realoem.
Maybe this attach photo will help you to visualize better.
Old 03-17-2019, 12:09 PM
Mein Auto: bimmer
Camshaft Sensor
13627525014
O-Ring
12141748398
OK this sounds like a good DIY project, thanks for the tips buddy!
In fact, do talk to foremen in your workshop and ask them to publish a SIB to BMW techs worldwide how to examine N20/N26 plastic guard rail snap on through the intake camshaft sensor opening!!!
Old 03-17-2019, 01:04 PM
Funny. Ha, ha .....
Maybe the BMW techs already know about this.
Old 03-18-2019, 10:41 AM
Mein Auto: bimmer
Funny. Ha, ha .....
Local service techs/foremen only said to "watch" out for the high pitch whining ....
One foreman did suggest any timing chain issue(if bad enough) also would trigger a camshaft timing fault/CEL, so has your car logged any camshaft fault code?
My thinking is the first thing techs will do with camshaft CEL is to replace the sensor, maybe that will be a good time to inspect with borescope.
Old 10-17-2019, 10:02 PM
buuza33 buuza33 is offline
Mein Auto: 2013 528xi Black Sapphire
Hi All,
I have 2013 528i xdrive. The engine became noisy in end of July 2019, since then the car would make a lot of noises when cold start and kick when shifting on lower gear. Oct 9th 2019,
I made a video of a noise in the morning(it's a lot louder than video shows), drove to work less than 2 miles, and car broke down while entering garage, the brake pedal stuck down, Drivetrain malfunction light is on, when tried to start it would crank and go up to 300-400rpm on tachometer, but that's it. Towed to the nearest shop they said it's timing chain issue, googled everything about it, 3 days ago took the car to BMW dealer. I'm still waiting them to diagnose and everything (taking 3 days?!).
If it's timing chain, then I should be covered under 7/70(mine is 6.9 years and 65k).
Will update this post along the progress
Old 10-17-2019, 11:20 PM
Mein Auto: bimmer
Originally Posted by buuza33 View Post
Hi All,
Wow just in time repair! The video sounds like droning(somewhat noisy background?), so is there a high pitch whining starting in July? How many miles from first warning(a lots of noises) in July to drivetrain malfunction? Is there a CEL triggered?
Old 10-18-2019, 07:41 AM
I only saw 'Drivetrain malfunction' once in September, drove about 2-3k since July, but noise was always there when cold start since July. No CEL light
Old 10-18-2019, 10:50 AM
Mein Auto: bimmer
Thanks for feedback. This is first time gas pedal is mentioned for TC failure, maybe the ECU can detect camshaft timing issue an shut down engine preemptively to avoid further engine damage.
Old 10-18-2019, 02:42 PM
The pedal stuck because i was going downhill, slowly entering garage. that's when it happened
Old 10-22-2019, 10:39 AM
Hi All,
Just spoke with the SA at bmw dealership, they confirmed the timing chain failure (BINGO!).
BMW NA will take a look at the photos and confirm if it's either engine replacement or just a timing chain fix. Hoping for a new engine
2013 bmw 528i xdrive, 65k
UPDATE: bmw will install new engine
Old 10-22-2019, 03:00 PM
Mein Auto: bimmer
That is a great outcome, and just-in-time!
Old 11-04-2019, 12:19 PM
There are more to this story, now the dealer saying that after new engine installed, transmission won't shift and there are problems with the turbo.
These repair are out of pocket...
Old 11-04-2019, 03:59 PM
Mein Auto: bimmer
That is unfortunate, given whole engine has been replaced, and turbo/transmission needs to be disconnected, my take is dealer needs to take care of those too without incurring extra costs to customers.
Old 11-05-2019, 05:49 PM
Well, good news, dealer says transmission and turbo was broken before timing chain, but how do you brake timing chain if your transmission and turbo not working?? He had no answer
So, the estimate he gave me was: $12.5k for transmission, $4.3k for turbo
What you think it is?)
Old 11-05-2019, 07:44 PM
Mein Auto: bimmer
Forum posts about N20/N26 timing chain issues virtually have zero reference to transmission/turbo, it is unclear if BMWNA will cover this or not under TC ELW.
Old 11-06-2019, 06:03 AM
lyleswk lyleswk is offline
Mein Auto: 04 325Ci Sport Coupe
Get another opinion...
Old 11-06-2019, 10:02 AM
DBU's Avatar
DBU DBU is online now
Mein Auto: Glacier Silver X4 M40i
"Bait and switch" comes to mind. Dealer obviously damaged transmission when they replaced the engine. If Turbo is faulty, find out the time stamp on that error code. In fact, demand a time stamp for all error codes on your car. Good luck.
His: 2017 X4 M40i - Glacier Silver with all the options (except cold weather stuff) - not needed in SoCal
Hers: 2015 X4 28i - Glacier Silver - loaded M-Sport
Old 11-13-2019, 09:31 AM
Is it even possible to damage transmission and turbo while replacing an engine?
The dealer won't give any fault codes and timestamps, simply ignoring me
Old 11-13-2019, 11:39 AM
It's always possible to damage something or more likely install incorrectly, although messing up both would be highly unlikely in my opinion unless the shop was really incompetent. My one question to potentially expose them is was the replacement engine a traditional "long block" or something else. My replacement engine came with a turbo.
Old 11-13-2019, 11:46 AM
JoeyMcMahon666 JoeyMcMahon666 is online now
Mein Auto: 2004 BMW 530i e60 5 serie
I donít get it, I have 125k miles on my n26. 2013 f30 build. Change oil and filter every 5k. Auto start/stop is turned off. Never had an issue with my timing chain and guide. I feel like so many people are getting taken for a ride over this issue, honestly. This also sounds like a bait and switch tactic ....
Sent from my iPhone using Bimmerfest
Old 11-13-2019, 12:09 PM
Mine had 117K and I can attest to the damage that happens if the guide comes apart; I saw the piece that broke. In my opinion, you're sitting on a ticking time bomb if your car is before the guide update. I just don't know when that happened.
As to the turbo and tranny, I agree and will repeat what I said above: Get another opinion. If they screwed something up during the install, I wouldn't trust them to fix it.
Old 11-13-2019, 12:53 PM
What was your oil change interval??? Did you use auto start/stop? How much damage? How much to fix?
Old 11-13-2019, 01:29 PM
Recommended BMW internals with Castrol synthetic. Twice done by the dealer, twice by myself. Before I bought it from my dealer, it was maintained by a nearby dealer per BMW recommendations. Checked all that before I bought the car...I have a very good relationship with my local dealer.
Can't answer the question on start/stop. My son drove the car and he never mentioned it. It isn't on now and I never changed it, but that may have reset when we disconnected the battery for the engine swap.
I purchased a salvaged engine from a 2013 model with 55K miles. My dealer maintained that car from first sell until it was wrecked (checked via the VIN). I replaced the timing chain guide and the oil supply line before I installed in my car. Engine cost me 3250, install was 1200, and new parts were about 400, so about 5000.
