Headlight bulb replacement - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X Series > X1 F48 (2016 - current)
Second generation F48 BMW X1 builds on the success of it's predecessor. Increases in power, interior and cargo space keep it a leader in the small SUV field.
Old 11-10-2019, 07:58 AM
XBimmerrr XBimmerrr is offline
Mein Auto:
Hello Everyone, does anyone knows if replacing the headlight and fog light bulbs to led will this void warranty?
Old 11-10-2019, 01:53 PM
Rustynuts Rustynuts is offline
Mein Auto: 16 X1 M-Sport
No idea. Are you making physical changes to anything or are these drop-in bulbs? If drop-in, no flashing required, etc., I'd just keep the old bulbs in case of trouble. Then swap them back in before the dealer. Might work!
Old 11-10-2019, 03:59 PM
ejw2011 ejw2011 is offline
Mein Auto: 11 F25 35i , 17 F48 28i
No unless it creates and found to cause other problems. If you do replace halogen bulbs to led, you need to code your ecu for led bulbs, else you'll get error codes and flashing/hyperflasing.
Search forum on led swap, there are many discussions on this, what you need to do, and what you need. Search is your friend.
Old 11-11-2019, 07:40 PM
Mein Auto:
Well these will be plug n' play bulbs so I guess they have to be coded. I just hope the dealership doesn't give me any issues or denying servicing the vehicle if I ever need service done on it for example oil change or any recalls if any that needs to be done
Old 11-11-2019, 07:41 PM
Mein Auto:
Have you changed the halogen bulbs to LED yourself? If so, did the dealership give you any problems?
Old 11-11-2019, 08:13 PM
wcs2229 wcs2229 is offline
Mein Auto: 2018 BMW X1 F48 xDrive28i
Maybe you have to confirm the LEDs meet legal specs, which is more important. Not all LEDs are the same and I wouldn't just trust the manufacturer saying they are legal. I think f48 has "pseudo-adaptive" LED headlights that don't actually move:
https://f48.bimmerpost.com/forums/sh....php?t=1244986
If you need coding, it may be overwritten with BMW firmware updates.
