time to replace air shocks / struts - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - F01 / F02 / F03 / F04 (2008 - 2015)
The 5th generation F01/F02/F03/F04 BMW 7 Series flagship forum. The redesigned 7 series leads off the BMW Fxx chassis code, offering an 8 speed automatic transmission and all turbocharged engine options.
Old 11-11-2019, 10:43 AM
sportlineguy sportlineguy is offline
Mein Auto: 2011 alpina B7L
It seems that my 2011 alpina b7l is a bit soft and wallowing at @ 105k and think it might be time to replace the rear air shocks and front struts. Thinking of going with the Arnott for the rear and oem for the front. Will changing those out make that much of a difference - in sport + it firms up but still the squat and dive seem a bit much. Any suggestions appreciated
Old 11-11-2019, 12:53 PM
UsernameWorks UsernameWorks is offline
Mein Auto:
Old 11-12-2019, 06:09 AM
are there any better options than the stock air suspension setup? what have others done to firm up the ride and control squat and dive?
Old 11-12-2019, 06:36 AM
Mein Auto:
Are you running in sport mode?
Old 11-12-2019, 06:40 AM
sport and sport +
Old 11-12-2019, 06:42 AM
Mein Auto:
Outside of going coilovers there isn't much as far as I know....
I think you will benefit from a fresh set of struts, usually fixes the sloppiness due to years of use.
Old 11-12-2019, 04:05 PM
csmeance's Avatar
csmeance csmeance is offline
Mein Auto: 760Li
also check all the bushings in the rear suspension and subframe; the shocks can be still in working order but all the slop can come from the bushings.
2013 TL Advance 3.5L
2006 BMW 760Li - Alpine White/Ebony-Ivory Two Tone
2007 MDX Sport/Ent.- NGM/Taupe
lRB Slotted RotorslRoof RailslFront & Rear GarnishlAuto Mirrorl
2004 TL NAVI Auto - SSM/Quartz
lComptech SwaybarlHacked NavlTVNAV2GolUSA-SPEClDVD PlayerlSwitchblade KeylRB Slotted RotorslA-Spec Brakesl
