Misfire at WOT (freeze frame data attached) - Bimmerfest - BMW Forums
Old 11-10-2019, 07:38 PM
DRpeppZ DRpeppZ is offline
Mein Auto:
Iíve recently purchased a 2007 335i 6MT and have a pretty serious misfire issue. At idle with AC off there is a miss that doesnít throw a check engine light but throws pending codes for cylinders 4,5,6. At WOT it usually will begin to misfire heavily at the top end of 2nd gear, I clutch in and shut the engine off, turn it back on and it no longer misfires. A few nights ago I pushed it hard through all the gears and the same thing happened as it usually does in 2nd but this time shutting the car off and turning it back on didnít remedy the misfire and it set codes instead of just flashing the CEL. Upon reading these codes I can see the pending for misfire at 4,5,6 and set codes for cylinders 5,6.
Iíve attached a freeze frame form when the codes were set, I also replaced the plugs and noticed there is oil in the spark plug wells. Leading me to believe the valve cover is leaking. FF data leads me to believe the valve cover is the cause, ruling out HPFP by the fuel rail pressure. I could be wrong though and thatís why Iím here. Thanks for any input.
Timing advance is 6 degrees and fuel rail pressure was 43,448 psi.
Sent from my iPhone using Tapatalk
Old 11-11-2019, 07:34 AM
marvinstockman marvinstockman is offline
Mein Auto: 1997 M#
Your fuel trim is all over the place, and I'm surprised the car even runs, with bank 1 & 2 LTFT running very lean. Pretty big vacuum leak?
Also, your fuel pressure should be between 50 and 60 psi, and not 43,000 psi. Maybe you're reporting the wrong units?
Get the data again, but during normal driving.
Old 11-11-2019, 08:25 AM
relative4 relative4 is offline
Mein Auto: '08 335xi E90 manual
Smoke test, walnut blast
Old 11-12-2019, 01:13 AM
Mein Auto:
Will provide data from normal driving tomorrow. Although while I was driving normally yesterday I noticed the fuel pressure at the rail was bouncing around from 650-900 psi. The STFT for both banks never got above or below 5% either.
Old 11-12-2019, 01:16 AM
Mein Auto:
Forgot to mention as well, that original fuel pressure reading was in mmhg, converted to psi is 831 psi. That is the fuel pressure at the rail as reported by my code reader.
Old 11-12-2019, 07:20 AM
Mein Auto: 1997 M#
Dr. Pepp, sorry I forgot you have a high pressure fuel pump because you are direct injected, 50 to 60 psi is for manifold injection. As such, your pressures are probably normal, but I have no direct experience with direct injection.
That said, your LTFT is crazy.
Old 11-12-2019, 07:23 AM
Mein Auto: 1997 M#
Also, you need to monitor air/fuel ratio, which should be about 14.7.
Old 11-12-2019, 08:21 AM
nsjames nsjames is offline
Mein Auto: e91
your long term fuel trims are super fat, but your short term is pulling almost all of that fuel.
I'd reset the fuel trims and see how it plays out, but you probably have some sort of leak somewhere. for it to have affected the long term trim that much it's been like that for a while.
do you know if it's ever had injectors replaced?
