Eerie Howling Noise on X3 - Bimmerfest - BMW Forums
Old 08-30-2014, 02:14 PM
lvb034 lvb034 is offline
Mein Auto: 2005 BMW X3
Hey everyone,
My 2005 X3 recently started making this eerie howling noise. I have a notion that it is some form of bearing that is worn, but am not too sure. I took a video of the sound when driving today and posted it to youtube here :
If anyone knows the cause of this sound please let me know...
Thanks!_a_
Old 09-14-2014, 01:41 AM
Ronzofb2 Ronzofb2 is offline
Mein Auto: 2005 X3
Check your DISA valve.
Old 09-14-2014, 04:36 AM
Frenchx3 Frenchx3 is offline
Mein Auto: 2011 335i Xdrive Sedan
Sounds like it might be your oil seperator. You can check pretty easily by pulling the oil filler cap off when the engine is idling. Cover the opening lightly with your palm. There should be a light vacuum. If there is a strong vacuum and/or the noise gets louder that's what it is. Just search "chewbacca sound" or "oil seperator".
Old 11-03-2019, 06:30 AM
BMWaufKS BMWaufKS is offline
Mein Auto: 2008 X3
Anyone know what this sound is in the video? (You may have to turn up the volume.) It's only when driving. (VC and oil cap have been replaced on mine, with OEMs).
Since 1/2016, restoring a
2008 BMW X3 M-Sport, N52, automatic ("#1")
Modifications:
All stock except dashcam
Since 3/2017, also restoring a
2008 BMW X3 base-model, N52, automatic ("#2")
Modifications:
Dashcam, cargo cover, cargo mat
Old 11-03-2019, 11:04 AM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
I have the notion of the
a/c...was the compressor on in the video?
Here's just one for you...
https://www.bimmerfest.com/forums/sh...php?p=11577873
Sent from my SM-J727T using Tapatalk
[FONT="Arial Black"]
Old 11-03-2019, 12:04 PM
Mein Auto: 2008 X3
Not a compressor-like warbling sound. More eere and varying with speed; no sound when sitting still.
Just did a sound-test at five points. On mine, looks to be the _new_ center support bearing! :-(
Modifications:
Modifications:
Old 11-03-2019, 01:08 PM
dukedkt442 dukedkt442 is online now
Location: Hudson Valley/LI, NY; Treasure Coast, FL; OBX, NC.
Mein Auto: X3, 442, S15, Silverado
Iím if the CCV camp.
Remove the drive belt and run it to certainly remove any belt driven item from the list.
Old 11-03-2019, 01:56 PM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
You drove over Chewbacca!
It is a definite vacuum problem sound - like DISA valve or crankcase problem
Is it engine speed, engine load, or vehicle speed dependent?
Old 11-03-2019, 02:07 PM
Mein Auto: 2008 X3
Too much "warbling" in his sound. And the really big thump-thump driving over him would be telling.
It's the CSB for mine. IDK for the long-gone OP, but likely the same I'd guess due to the very similar sound. Would be interesting to know if he/she/they had work done to his/her/their driveshaft beforehand.
Modifications:
Modifications:
Old 11-07-2019, 07:52 PM
Mizzoutigers Mizzoutigers is offline
Mein Auto:
This sounds a lot like the issue I am having with my 2008 X3. Ever since I had the rear drive shaft replaced it has made an intermittent whistling noise that changes pitch based on the speed I am driving. It only makes the noise when driving and seems to be louder when car is cold and softer when the car is warm. My mechanic checked the new drive shaft, to include the new center support bearing, and claimed it looked ok. How did you determine it was the new center support bearing? How did you test it? The sound is driving me crazy. Thanks for your help.
Old 11-07-2019, 08:47 PM
Mein Auto: 2008 X3
https://www.bimmerfest.com/forums/sh....php?t=1344613
New OEM bearing arrived today; hope to install it this weekend if ...
Modifications:
Modifications:
Old 11-10-2019, 03:11 PM
Mein Auto: 2008 X3
Just finished the installation and test drive. New, OEM center support bearing cured the problem.
Modifications:
Modifications:
Old 11-10-2019, 05:35 PM
BeeemerBro
Great! I know that's a relief....so many possible causes
Old 11-11-2019, 08:54 PM
cn90 cn90 is offline
Probably CCV Valve as mentioned.
Google "Xoupost BavarianE39 CCV Mod".
I did this and did not regret bc it reduces my oil consumption from 1qt/400 miles to nothing.
Also prevents hydrolock.
Old 11-11-2019, 09:06 PM
Mein Auto: 2008 X3
Not for mine; was the CSB.
Modifications:
Modifications:
Old 11-12-2019, 08:40 AM
You still killed Chewie, you arenít off the hook yet
Old 11-14-2019, 07:26 PM
Mein Auto: 2008 X3
I find your lack of faith disturbing.
P.S. The seller of the original, non-OEM part made good on his warranty.
Modifications:
Modifications:
Old 11-14-2019, 08:07 PM
Jared6988 Jared6988 is offline
Mein Auto:
Thanks the company going send me a new csb I hope it works like it did for you thanks for the help
howl, noise x3, weird, whine, x3
