e61 touring tail light bulb carrier - Bimmerfest - BMW Forums
Old 11-12-2019, 06:03 AM
smaglik smaglik is offline
Mein Auto: 2007 X3, 2003 M5
Hello. As I'm working through fixing all of the issues with my new to me touring, I've come across a burned bulb carrier receptacle on the right rear. I see I can buy bulb carrier only for the sedan, but I can't find that for the touring. I've done a bit of searching, and haven't found a discussion about this. Does the part carry over between the sedan and the touring? If not, any options besides trying to replace the whole tail light, or try to repair the burned receptacle? Thanks!
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 06:08 AM
twh twh is offline
Mein Auto: '06 530xi 6sp, '09 X5 3.0
Realoem.com is a site that you can cross reference parts.
There are some models that have had recalls or bulletins that have an extra ground added to the bulb carrier for burned socket problems.
Old 11-12-2019, 06:50 AM
I'm familiar with realoem. It doesn't show that carrier as an option. I'll look into the bulletins, though since I never go to a dealer, that's probably only useful for information. Thanks!
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 07:28 AM
twh twh is offline
I looked up the E61...the tail light in the rear hatch has a carrier, but the tail light in the body does not. It looks like the bulb housing is integrated into the light assembly and there is no carrier. Does that match what you see?
Old 11-12-2019, 08:04 AM
Correct.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 08:08 AM
twh twh is offline
Post a picture if you can of the damaged unit.
Old 11-12-2019, 08:50 AM
Here it is. Sorry, not a great pic. Burn is at the top.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 08:55 AM
Let's try again.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 09:40 AM
dharmabmw dharmabmw is online now
Mein Auto: 2006 530Xi
I repaired mine by cutting away the melted plastic blob with a box cutter. The bulb holder was then able to make proper contact and illuminated properly. I had an intermittent bulb failure indication along with a dim lamp.
2006 E61 MT
2010 E91 MT
Old 11-12-2019, 09:41 AM
twh twh is offline
You talking about the small burn in the mounting hole next to that "P2" graphic on the metal? That doesn't look bad to me. if the plastic isn't melted though, I'd proceed as follows.
(1) Shine up all the metal rings with some fine sandpaper. Those metal rings around the bulb holes are grounds.
(2) Get a very small drill bit...maybe need to go to a hobby shop for that one. Drill a hole using a pin vise (ie, not an electric drill) in the burned mounting hole and screw in tiny screw to hold that piece in place. I did this to some broken off mounting posts on my wife's X5 tail lights.
(3) Add another ground wire. That's the brown wire. Here's an example thread...the brown center that is bolted to the dy is a ground cluster. Just run another one to the tail light.
https://forum.bmw5.co.uk/topic/12606...oblem-pre-lci/
Old 11-12-2019, 10:44 AM
Thanks for the ideas guys! I'll report back after the fix.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-12-2019, 02:05 PM
audiophool audiophool is offline
BMWs since '87
Mein Auto: 2008 535xi (LCI)
Your lamp socket's contact tabs need to be examined as well. The melty spot on the tail light housing is caused by heat due to a poor connection between the socket tab and the ring on the housing. Best practice is to get a new lamp socket since heating weakens the tab. Re-forming or shining that tab may work for a while but it will fail again.
I corrected a similar problem on our E53 X5 with a new socket and not clocking the socket fully, allowing the contact to connect to a good spot on the ring.
Old 11-12-2019, 05:03 PM
Noted. Thank you.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-14-2019, 02:25 PM
So, my mechanic had the car to give me a write up on some of the tasks I don't want to do, and I told him about the taillight issue. He fixed it with some soldering and an added wire to force a good connection on the bulb. I'll post a photo shortly.
2003 M5
2007 530ixT
2007 X3 6MT
Old 11-16-2019, 10:54 AM
Here is the photo. Looks like he soldered a wire in to make a connection on it
2003 M5
2007 530ixT
2007 X3 6MT
