help, where does this connector go (under intake manifold) - Bimmerfest - BMW Forums
Old 06-15-2018, 07:05 PM
jason0 jason0 is offline
Mein Auto: x5
upon replacing my intake manifold, I found this loose connector that i did not remove myself, must of gotten snagged.
It is under the intake manifold, it splits off from a harness that continues on to a coupling connector on the a/c compressor.
Numbers on this connector are:
7570216
and
7807642
Old 06-15-2018, 07:13 PM
God-Follower's Avatar
God-Follower God-Follower is offline
Achtung! Hochspannung!
Mein Auto: 2018 i3, F10 535d
N52 or N55?
Sent from my PH-1 using Bimmerfest mobile app
Old 06-15-2018, 07:17 PM
Mein Auto: x5
N55, sorry
2012 x5 n55
Old 06-15-2018, 07:18 PM
Mein Auto: x5
I am so desperate to find out where it goes, I am looking through every wiring diagram to try to find the color of wire match
its white with green stripe and white with purple(i think, maybe black)
Old 06-17-2018, 11:28 AM
Michael47 Michael47 is offline
Mein Auto: '12 X5 35d
Before you allow full-on panic to set in, do be aware that BMW, like most manufacturers, uses the same wiring harness in every vehicle, regardless of what options are ordered, thus on any given unit, you are guaranteed to find multiple connectors hanging idly and flapping in the breeze. Doesn't mean anything is disconnected, only that whatever that one goes to, you don't have it.
'12 X5 35d
'05 Jeep Libby CRD (now deceased)
'01 VW Jetta TDI
formerly '69 BMW 2002 and '67 BMW 2000CS
Old 06-17-2018, 12:36 PM
Mein Auto: x5
interesting, may be thats the case.
I gave up on finding where it goes, and re-assembled.
Everything appears to be working, and ISTA does not show any errors from any modules.
Old 06-18-2018, 11:41 AM
There you go. It's the acid test. If anything doesn't work, maybe it is unplugged, but if everything works, well . . . .
There is, of course, a limit to that. Like if the engine falls out onto the ground, or a door falls off, . . . .
'12 X5 35d
'01 VW Jetta TDI
Old 11-07-2019, 09:29 AM
AKottas AKottas is offline
Mein Auto:
The Me Too Extra Connector!
I know this is an old post, but I just did a N55 swap in my E70 and have the very same plug left over. I was very careful, but feared failure. At least finding this post has given me some hope.
Old 11-07-2019, 09:31 AM
Mein Auto: x5
How in the world did you find this thread?
Old 11-07-2019, 10:46 AM
Mein Auto:
Google is amazing, searched 2012 bmw x5 35i open connector under intake and it brought me here. I assume you have been running fine with not connected to anything?
Old 11-07-2019, 10:48 AM
Mein Auto: x5
correct
