Rescued to the South now - Page 5 - Bimmerfest - BMW Forums
Old 09-29-2018, 05:02 PM
BimmurBrothor's Avatar
BimmurBrothor BimmurBrothor is offline
BeeemerBro
Mein Auto: X3 M54 150k
Originally Posted by jeepo23 View Post
By looking at your pics the telephone module was probably never installed. That wiring looks intact as when it left factory its just prewired for it but the module was never added.
No need to get discouraged, those items on there are minor stuff and easy fixes. The most expensive being the phone module approx. $70 on ebay.
Your info makes sense...notice the overhead functions...do you see what's missing...yeah the "SOS" option! It's all coming together now. Thanks again jeepo23.Click image for larger version
Sent from my SM-J727T using Bimmerfest mobile app
[FONT="Arial Black"]
Old 09-29-2018, 05:21 PM
jeepo23 jeepo23 is offline
Mein Auto: 2008 X3, 6 Speed
Originally Posted by BimmurBrothor View Post
Your info makes sense...notice the overhead functions...do you see what's missing...yeah the "SOS" option! It's all coming together now. Thanks again jeepo23.Attachment 820971
Yah thats what mine looks like too. The microphone would be hidden to the left in those little grilled slot part
Old 09-29-2018, 06:24 PM
BeeemerBro
So we are now down to 3! (excluding th air bag man).
Old 09-29-2018, 06:28 PM
BeeemerBro
I'm in hopes... by when she hits *200k*..I'll have a clear clean dash.Click image for larger version
Old 09-30-2018, 06:47 AM
The ABS, 4x4 and Brake lights are those not typically related to the little actuator gear in the transfer case? It's like a 10$ part, wouldn't hurt to replace the fluid at the same time.
Old 09-30-2018, 07:37 AM
mitch500 mitch500 is offline
Mein Auto: 1997 e36 m3 s54
Yes they are
Old 09-30-2018, 10:38 AM
BeeemerBro
Yep. ..got it in hand...just got to find the time maybe tomorrow...hear, for the airbag,,,,, just cleaning the connections in the stirring wheel could get rid of the light...we'll see...you know what happened with my last airbag situation. ...https://www.bimmerfest.com/forums/sh....php?t=1280480
Sent from my SM-G386T using Bimmerfest mobile app
Old 10-01-2018, 04:26 AM
BeeemerBro
ya think it's time to replace the braided ground strap? Like to get a nice thick one...Click image for larger version
Old 10-01-2018, 04:33 AM
Ya thatís end of life! There is some at Walmart their battery cables think like 2 or 4gauge with the eyelet on them they have a pvc jacket on them as well..
Old 10-01-2018, 12:22 PM
Wow I need to check my aground straps!
Old 10-01-2018, 12:31 PM
BeeemerBro
common failure at this age...it will make you think the battery is bad or the starter...you'll have your car towed to the dealer...the dealer will discover it's the $8 dollar ground strap, replace it and charge you $800 dollars for the labor. when you could have done the job for $8....that's why they call them the "stealer"!
Old 10-03-2018, 07:50 AM
BeeemerBro
Dead key fob...
I suspect the battery power is depleted...however, that shouldn't affect the functioning of the key when used in the door key hole...right. When key is turned to the RIGHT =locks are opened...when key is turned to the LEFT= locks are locked. in other words (correct me if I'm wrong) the key fob battery has no barring on the manual locking/ unlocking of door locks when key is inserted in the door lock.
BeeemerBro
Dead key fob...
Dead key?
Old 10-03-2018, 08:07 AM
Dead key?
Just change that battery, but I'm sure you know that. eBay has batterys for $5
Old 10-03-2018, 08:17 AM
BeeemerBro
yea I know...I got a couple on hand. just didn't want to go through cutting the fob open and soldering in the new bat. hey but that saves me $170 bucks
Old 10-03-2018, 08:31 AM
abscate abscate is offline
Mein Auto: 2006 BMW X3... VOLVO... V
Dont forget to register it
(troll runs back under his bridge)
Old 10-03-2018, 09:04 AM
BeeemerBro
??? Register
Old 10-03-2018, 09:28 AM
There was a flame war over whether the E83 series requires the battery to be registered to the car to ensure proper operation
I was just poking the hornets nest to see if any were left..
You can use any decent battery to replace it if needed, registration of batteries is a later BMW thing
Old 10-03-2018, 09:46 AM
BeeemerBro
no,no,no...no registering needed my friend for these x's that's one of the reasons I favour this type BMW.
I think I was in that fire fight....I survived.
Old 10-03-2018, 10:05 AM
Once battery is replaced in the key the key does need to be reinitialized to the car. No joke. It's done with a sequence of button presses, no software required.
Look it up online, the E46s had it the and mutant E83 does too.
Old 10-03-2018, 11:02 AM
BeeemerBro
oh! yea...now that's correct. for diamond keys...hold open button down while press the bmw button 3 times and lift. But first put key in position 1 and then remove...this is what your referring to...right?
Old 10-03-2018, 08:03 PM
Ive never had To do this on my E83 when i disonnect the battery, which is every time I do electrical work .
Old 10-03-2018, 08:50 PM
BeeemerBro
Yeah.....the battery in the key not the battery in the trunk.
Old 10-04-2018, 06:25 AM
BeeemerBro
Yeah. .the battery in the key not the one in the trunk.
*So here's the problem*
a disconnected/broken battery prong...your mission...if you should choose it...is to switch out the full battery replace with a battery which has a non damaged electrical prong.
Old 10-04-2018, 06:29 AM
BeeemerBro
See the broken prong...
