X5 E70 (2007 - 2013)
E70 BMW X5 produced between 2007 and 2013. Discuss the E70 X5 with other BMW owners here. |
#51
Checking thicknesses, on my car and several other cars it always ends up needing a disc change every other pad change.
If you are at -2mm after only 45000km I would double check everything with a caliper, that is not normal. |
Sponsored Links | ||
Advertisement | ||
#52
I live in an area with hills and mountains.. maybe this is why.. no issues with the calipers, etc - 100%. even rears are worn about 1mm on the outer side (i did not measure the rears, just decided to replace them as well)
#53
No. I was referring to the proper speed/braking to do when pads are first installed so the pads sit correctly on the rotors. It involves a series of fast slowdowns without fully stopping. Like 50mph down to 5mph done quickly. That sort of thing. Sent from my iPhone using Bimmerfest mobile app
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air |
Advertisement | ||
#54
Had the same issue but with the rear brakes. That was 3000miles ago and they are still fine. I purchased the Akebono pads and Zimmerman rotors just to have ready on hand. I had the rotors cut last brake change so saved me about 140$. Bought everything from FCP euro and amazon
#56
DON'T re-use stretch bolts.... EVER! I had an O2J drop down to the subframe and rip the motor mounts apart on a mk4 VW GTI. I was going down the Jersey turnpike (at a fairly excessive speed). It could have been worse and it gave me a reason to swap in an O2M 6 speed and raxles. That's car had gone through 3 transmissions with the PO. It was an expensive lesson to learn. The trans mount bolts were stretch bolts and the P.O. had re-used them. I had the car for a week when this happened. Inspected to find the threads were not damaged. If it had been a new bolt and torqued properly, it would have ripped the aluminum threads out with it. I've also (20 years ago) re-used the stretch bolts that bolt the pressure plate to the crank on an O2O. Let me tell you how much fun it was drilling those out of the crank shaft in a mk2 Jetta. You can take or leave my advice and either way, I'll tip my hat and walk away. But is it ever worth that kind of trouble....? Even if you luck out a few times, it's not worth it to find out. IMO. To each, their own... |
#57
FYI, I just did fronts and tears pads and rotors on my diesel. Used hella rotors and akebono pads and love em. Tried to find textar epads but according to textar , they don't make them for the rear. Akebono s are almost as good as OE with much less dust.
#58
Did they explain why the sensor failed? It’s takes wear to make it pop up. Sent from my iPhone using Bimmerfest mobile app
#61
Faulty sensor sends message to computer reporting breaks pads needs service. If you can see that you have plenty of pad material left on your pads, the service fault light is coming a faulty sensor.
#62
service due light (front brakes)
I think it depends on how many mm you have left. The sensor causes the code before they have to be replaced. It’s a warning. Not a rush and go get it done warning. Sent from my iPhone using Bimmerfest mobile app
#63
I don't know if this is a universal statement, but stretch bolts (aka torque to yield bolts) have a specification that includes initial torque and then an added rotation of X degrees. So, when I don't see an added degrees in the spec, I assume the bolt is not a stretch bolt. Now, the bolt may have some fancy integrated locking feature that is one time use only, but that's a different thing.
#64
All fasteners in tension - not compression or shear - stretch. Yield means that the stress goes into the plastic region of the stress-strain curve, plastic where the strain is not recovered. If the fastener does not yield then it has stayed in the elastic region and can be reused as far as metallurgy goes. Procedure is another issue. To be clear, stress units are force per area, lbf/in^2 in English. Strain units are change in length per length.
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness. (The Works of George Santayana p. 65) Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it. |
#65
In other words..."stretch bolts" or "torque to yield bolts" are bolts that stretch *beyond* their ability to go back to their original length when removed.
#66
TTY go into plastic region. All clamping bolts / fasteners stretch a bit, not necessarily yielding.
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness. (The Works of George Santayana p. 65) Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it. Last edited by Doug Huffman; 10-16-2019 at 09:04 AM. |
#67
Think of torque to yield fasteners as being installed to spec and then "bent" or "creased". Once they are, they'll hold what they're supposed to at the engineered spec. Until, they're removed. You can't re-use (un bend then re-bend) them because they can not be expected to hold to the same (engineered) specs. It only takes a few bends of that paper clip to completely fail. So for safety's sake, you can (probably) re-use TTY to hold together paper, but not transmissions, pressure plates or brakes. |
#68
got all pads and rotors replaced yesterday. took a while mostly because I cleaned up the spots for the pads to slide nicely with the brush/sandpaper.
the pads had about 2-3mm of the material on them. so, the conclusion is after the service light there is about at least 1000 km or more before the pads would wear out completely.. maybe even more. for the caliper slides - it is 7mm not 9 mm hex. |
#69
Bummer. Sorry... Verzonden vanaf mijn iPhone met Tapatalk |
#70
luckily I had one
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
