spark plug wrench - Bimmerfest - BMW Forums
Old 10-31-2019, 11:13 PM
mohamedrani mohamedrani is offline
Mein Auto: 520i 1998
spark plug wrench
hey guys,
i tried to change the spark plugs in my car, the size was written that it's a 16 mm wrench , when i bought one , found that i've 21 mm socket "should have checked the new spark plugs' size before buying the wrench ,
anyway i bout another one which is 21 mm and it fits the size with the new spark plugs , but the strange thing is the wrench doesn't go all the way to the spark plugs in the car,as if the wall gets little tighter when getting close to the spark plugs, it that normal and need to buy another wrench or there's something wrong , because i can't believe that i can't change my spark plugs and I WILL NOT go to a mechanic just to change them
these two which i bought, and the one that's alone is i found on the internet , would it help ?
ID:	870483   Click image for larger version
Current Garage
98 E39 520i - 260k KM
bn63605
Old 10-31-2019, 11:20 PM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
Use a regular socket wrench, with an extension.
No need for a spark plug wrench.
<=E39=>
Old 11-01-2019, 12:11 AM
Bmwe39528i Bmwe39528i is online now
Mein Auto:
What Chedley said. I changed them on both of my 528i's. Used deep socket and then a magnet to get them out
Old 11-01-2019, 02:45 AM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
well a spark plug socket has a piece of rubber that holds the plug in the socket..
13/16's or 5/8's
mine are both very very deep (*like 6") with 3/8's drive
Specializing In Breaking Things Professionally
15486372<-----
Old 11-01-2019, 05:14 AM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Yeah, the rubber insert is nice. Keeps the plugs, especially the new plugs, from falling out of the socket.
2002 530i
Old 11-01-2019, 06:51 AM
cn90 cn90 is online now
The rubber insert has its own issues.
If the rubber inserts falls off and stays with the spark plug, it is a pain to remove.
I do NOT use rubber insert any longer.
I currently use Magnetic Gear Wrench:
https://www.bimmerfest.com/forums/sh...php?p=12972983
Old 11-01-2019, 09:30 AM
528iAut 528iAut is offline
Mein Auto: 1996 528i
You have one in your toolbox in the cars trunk, just dont use the little rod to wrench it with, it will bend...
E39 528i Steptronic 1996, Comfort seats, Rear sunshade, Focal amplifier and front speakers, Oxford Green.
Old 11-01-2019, 10:37 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
12-point sockets have thinner walls.
And I use a locking extension to retain the socket.
Finally, I do not use a thread lube. BMW recommend dry installation; modern plugs have a electroplated body to ameliorate stuck plugs.
Old 11-01-2019, 11:14 AM
namelessman namelessman is offline
Mein Auto: bimmer
Rubber grommets in spark plug sockets can come loose and stick with the plugs, and can be a pain to remove from deep inside opening.
Metal prongs in spark plug sockets can scratch the ceramic insulation on the new plugs, and affect the operating characteristics of the plug.
A good magnetic socket is really the way to go, M54 needs 16mm(6 point?), the newer engine needs 14mm (really) thin wall 12 point, e.g. BMS has a great one.
Old 11-04-2019, 07:55 AM
1+,
As I mentioned above, once you go MAGNETIC wrench, there is no going back to rubber.
It is so much better with magnetic.
Old 11-04-2019, 11:14 AM
Mein Auto: bimmer
Originally Posted by cn90 View Post
1+,
My local trusted indy said the same, a good quality magnetic socket delivers reliable service every time in first try, while rubber/prong sockets keep breaking, which costs time and money!
