Is it transmission or what? - Bimmerfest - BMW Forums
Old 11-02-2019, 10:09 AM
GPSnV1's Avatar
GPSnV1 GPSnV1 is offline
Mein Auto: X5 5.0i
I was taking my little dog to PetsMart. A pick up in front of me stalled. A row of cars were behind me spaced, it seemed, like 2 inches apart.
I put the lever in reverse to indicate we needed to get out of line to get around. Nobody was moving. When I moved the lever again I saw the first of several error messages.
I think the first one was something about 4x4. Then the next message I remember was something about the transmission.
I eventually got to PetsMart that was one block away. I got a warning about not being able to get the lever in Park. So I had the lever in drive and turned off the engine.
As I did this another message said that perhaps restarting the car would resolve my issues.
I returned to the vehicle maybe 10 minutes later. I could not get the engine to start. I do not remember seeing any new error messages or icons.
I am inclined to tow to an independent shop that does BMWs and see what they turn up. Does anyone see anything here that indicates I should take it to the dealer?
2008 X5 4.8i. 2012 X5 5.0i retired, 2004 X4 4.4i retired
BS RL/EL, Max 360, V1 (3.894) V1C LE/V1 Driver
2015 BMW X5 xDrive 50i/XL/CW/DA+/EP/LP/FVS
Old 11-04-2019, 01:43 AM
FredoinSF FredoinSF is offline
Mein Auto: 4 BMWs, 1 Mini, 1 Vespa
Going to the independent for diagnosis is probably best next step/ Any spills on or around the shifter?
Old 11-04-2019, 05:16 AM
GPSnV1's Avatar
Mein Auto: X5 5.0i
This is my wife's car so I do not look around very close, but at the moment I do not remember a spill near the lever.
After I started this thread, I went back to the car to have it towed. While waiting for the tow truck, I called BMW and described what had happened.
So the last time I tried to start the car, I got a battery warning. When the tow truck came, he was finally able to jump start the car but it would not keep running so he used a portable unit to keep inside the hood while he put my car on top of his truck.
I decided to start with the dealer since they know my record of 5 X5s from them. If this is just a battery then not much to worry about. If it is more serious, then I will look at towing the car over to the independent dealer I want to use who is roughly 1 mile from my dealer.
Old 11-04-2019, 06:39 AM
Gary214 Gary214 is offline
Mein Auto: 2011 X5 50i M-Sport
How old is the Battery ?
Its the usual suspect and least of your worries.
Hope it works out that way
Old 11-04-2019, 06:42 AM
GPSnV1's Avatar
Mein Auto: X5 5.0i
Thank you. I thought it was not old, but they could not find record of a new battery for at least 2 years.
I just talked to the BMW SA and he said that "under voltage errors" can be generated by a weak battery.
So for now I am hoping for the best. The temp was also low Saturday but not the first day below freezing here.
Old 11-04-2019, 10:29 AM
GPSnV1's Avatar
Mein Auto: X5 5.0i
SA says immediately need battery and alternator. They discounted cost to come close to the independent shop that I called to compare.
Also need oil leak issues, but I am putting that off to the first of next year as we are working on the house right now.
