Need help with misfires - Bimmerfest - BMW Forums
Old 11-09-2019, 08:22 AM
R3jus R3jus is offline
Mein Auto:
So i found out the problem was the ccv hoses, so i took of the intake manifold, replaced the whole ccv, replaced intake manifold gasket and put everything back on everything runs fine but i still get the misfire in cylinder 6, Could this be the problem because i didnt change the throttle body gasket? Or something else is wrong?please help
Old 11-09-2019, 11:09 AM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
with a single cylinder fault, its very improbable the TB gasket is your issue. 4 things come to mind.....plug, coil, injector or compression for cylinder 6 in your case.
99 528i 5sp sport
be alert...the world needs more lerts
Old 11-09-2019, 11:20 AM
Mein Auto:
So its TB gasket?
Old 11-09-2019, 01:38 PM
crazy4trains's Avatar
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
Are any one of those 4 items mentioned a throttle body gasket?
2002 530i
Old 11-09-2019, 02:10 PM
Mein Auto:
I did not change the throttle body gasket
Old 11-09-2019, 03:09 PM
Burning2nd's Avatar
Under the lift arms
Mein Auto: e39, e83, e60
i doubt its a Tb gasket... that gasket is a lot lest important then others like manifold (*where the crankcase pressure is a lot different )
Specializing In Breaking Things Professionally
15486372<-----
Old 11-09-2019, 06:49 PM
Mein Auto:
Well i did change the intake gasket
Old 11-09-2019, 07:53 PM
Did you read post # 2?
2002 530i
Old 11-09-2019, 07:57 PM
mattmar1's Avatar
Wingnut
did you remove the throttle body and reinstall it with the old gasket, or are you just leaving us to figure out what you did thru osmosis? we need a bit more detailed info in the future. as stated before, a single cylinder steady miss is most likely what was mentioned in post # 2.
99 528i 5sp sport
Old 11-10-2019, 12:26 AM
Mein Auto:
Yes i removed the throttle body and put it back on with the old gasket
Old 11-10-2019, 06:23 AM
Mein Auto:
What 2 post?
Old 11-10-2019, 10:07 AM
mattmar1's Avatar
Wingnut
post #2 above...posts are sequentially numbered
99 528i 5sp sport
Old 11-10-2019, 10:29 AM
Mein Auto:
But if it was a bad coil wouldnt it always throw a check engine and misfire? It only happens at random moments... but if i had low compression what should i do then?
Old 11-11-2019, 09:39 AM
mattmar1's Avatar
Wingnut
coils can be intermittent, or change in efficiency under differing load conditions. if low compression, go thru the normal compression check tests post fail checks to see whats causing the issue...valve, rings etc, we can "if" for days...but youve got to go thru the recommendations above to see what it is.
99 528i 5sp sport
Old 11-11-2019, 10:04 AM
Mein Auto:
So i chould check comppresion? Yesterday i dropped into lower gear and it was a missfire in the 3 cylinder not in the 6
Old 11-12-2019, 10:05 AM
mattmar1's Avatar
Wingnut
id recommend checking everything in post #2, might even add a smoke test for vac leak if the miss changes cylinders again.
99 528i 5sp sport
Old 11-12-2019, 11:11 AM
How do you know the misfire moved to cylinder 3?
2002 530i
Old 11-12-2019, 12:47 PM
Mein Auto:
The computer told me to
Old 11-12-2019, 05:11 PM
mattmar1's Avatar
Wingnut
so gotta ask..have you tried any troubleshooting yet?
when you say computer, what kinda hardware are you using to read the codes? if on a laptop. what software are you using?
99 528i 5sp sport
Old 11-12-2019, 11:14 PM
Mein Auto:
No its a small computer with obd2.support i bought it like for 30 bucks just to see and delete the codes also check the data stream
Old 11-13-2019, 12:50 AM
Bmwe39528i Bmwe39528i is online now
Mein Auto:
Dude do what mattmar1 said...
Get compression tester and check all cylinders, write it down.
Next check your spark plugs and change them if they're bad or it's time to change them.
Then simply swap the injectors, 5 with 6 and 2 with 3.
Drive around and see if you get misfires changed to cylinders 2 and 5. If you do, then injectors are your problem.
If misfires are still occurring, swap your ignition coils from cylinders 6 to 5 and from 3 to 2.
Then drive a few more days and see if misfire code changes.
If your spark plugs were still good, swap them places as well.
Then come back and let us know what happened.
Old 11-13-2019, 02:00 AM
Burning2nd's Avatar
Under the lift arms
this isnt going to work for a BMW..
I mean for basic obd2 codes yes.. BUT since BMW and every manufacture sub codes now..
you will need a more advance scanner
The foxwell NT510, which is the schaben bmw tool
INPA, or ISTA, Or reingold
15486372<-----
