Some thread damage drive flange hub - Bimmerfest - BMW Forums
Old 11-10-2019, 06:35 PM
zufahren zufahren is offline
Mein Auto: 2013 X5 35i
When installing my winter tire set today I was a little quick with the air gun and managed to do a little damage to one of the 5 lug (bolt) holes in the drive flange hub . I had a new spare bolt and was able to carefully install in by hand and then torque to spec. My concern is the bolt doesn't run freely into the drive flange hub as the other 4 bolts. It should be safe but should I retap the thread (don't know if that's possible) or replace the drive flange hub. Any thoughts welcome. Thanks!
Old 11-10-2019, 06:57 PM
Markst Markst is offline
Mein Auto: BMW 5
How much of the thread is stripped? Did you clean it with a tap?
Old 11-10-2019, 08:25 PM
Probably only 1-2 cm of the thread damaged in the hub. I didn't have a tap so just used a new bolt that snugged up tight to the correct torque but it was more resistance than usual when tightening.
Old 11-11-2019, 04:57 AM
deroy deroy is offline
Mein Auto: X5 e70 4.8
You have access from behind? Maybe screwing a bolt in in the other direction straightens the threads out again.
Verzonden vanaf mijn iPhone met Tapatalk
Old 11-11-2019, 05:30 PM
Thanks for the suggestions. My mechanic was able to retap it today, new lug bolt, and torque to spec. All is well again :-)
