X5 E70 (2007 - 2013)
E70 BMW X5 produced between 2007 and 2013. Discuss the E70 X5 with other BMW owners here. |
#51
Sponsored Links | ||
Advertisement | ||
#52
N63 Turbo Coolant Lines leaking, e70 5.0i MSport
I think it depends on the engine. Which engine do you have?
Ya the right intake plenum has to come off if you want to check and change that T-Connector. You should have 4 hoses. 2 from the main coolant line and 2 from the aux turbo cooler motor. (This is assuming we have the same engine) Sent from my iPhone using Bimmerfest
2011 550i GT
2013 1199R 2011 RSV4 SE |
#53
Yes there are 4 lines. Two each coming from the 2 Item 7s. The aux turbo cooler is item 9 or 10. Sent from my iPhone using Bimmerfest mobile app
2011 550i GT
Advertisement | ||
#54
Got it thanks
#55
No longer replacing coolant lines. Just found out I need to replace both turbos due to wastegate rattle. Not surprising since I have 106K miles on truck. Dealer wanted 7K for replacing turbos including new coolant lines (not bad since the parts alone are close to 5K. I decided to trade in and buy another X-5. This time I wont hold past 100K warranty.
#56
Thanks, Tim |
#57
2013 bmw 650i harness
What is that harness thats connected to the turbo on the right? and where does the harness come from? i just purchased a 2013 bmw 650i gran coupe, and that harness is missing, and i cant seem to find it so i can plug it back into the turbo.
Last edited by [email protected]; 11-11-2019 at 01:15 PM. Reason: want to attach a picture if possible |
See More Related BMW Stories |
Forum Navigation | |||||||
Today's Posts Search |
Thread Tools | |
Display Modes | |
