X3m spare tire - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > X3 M, X5 M, X6 M, Z3 M & Z4 M > X3 M
X3 M
Old 09-12-2019, 04:30 PM
Stansx5 Stansx5 is offline
Mein Auto: M550i rhodonite silver,
X3m spare tire
Does having a spare tire as stud equipment raise the cargo ares floor? If so, how many inches? And is it the same with 20” wheels? Thanks
That’s standard equipments
Old 09-14-2019, 01:15 PM
hilld hilld is offline
Mein Auto: X1 (on order)
Yes the floor is raised at least in the 2020 I looked at.
Old 09-14-2019, 02:49 PM
BMW no info
I have asked at least ten times from BMW National to publish or at least inform the Geek line what the true cargo space is when you add the spare. As usual, they are deaf to their customers. Even though the X3M comes standard with a spare and raised floor, they still publish the cargo space with the same numbers as the X3
Old 11-07-2019, 12:32 AM
sayemthree's Avatar
sayemthree sayemthree is offline
Mein Auto: 2008 M3
its raised about 3- 4 inches. it makes the ceiling ht close to my 2014 X1 which I am selling to fund the x3m
For Sale 2014 BMW X1 xDrive2.8i 64,xxx miles, Le Mans Blue Metallic, Sand Beige Leather, warranty until 4/2022 or 94,800 miles PM me
Old 11-07-2019, 02:28 AM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
Here's the G01 cargo area, with and without a spare. A two-high stack of 1/2 litter water cases will fit back there with the spare, but the cargo shade can't be drawn over them. However, it's easier to get heavy stuff (e.g. cases of water) out with the raised floor.
The (non-M) X3's spare tire is a 135/80-18, which is smaller rolling diameter than the "outside" tires. Normally, that would quickly destroy the xDrive transfer case. But, the (non-M) X3's owner's manual doesn't limit the distance you can drive with the spare tire installed. It does say that handling characteristics will be affected. I suspect/assume that the modern xDrive logic is smart enough to detect a spare tire installed, and disengages the clutches sending power to the front axle, allowing the transfer case to freewheel. Good luck getting a good answer about this from a dealership, genius, or even BMW NA.
Name:	bmw g01 x3 cargo area without spare.jpg
ID:	871199   Click image for larger version
Name:	20171106 piciture of 2018 X3 cargo area with spare tire.jpg
Old 11-10-2019, 11:41 PM
sayemthree's Avatar
Mein Auto: 2008 M3
Thanks for pics
HTML code is Off
