Throttle Actuators - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E63 / E64 M6 (2006 - 2010)
Old 05-03-2020, 04:45 PM
Kerrysc Kerrysc is offline
Mein Auto:
Throttle Actuators
I been having DSC faults (always bank 2). I took both actuators out this weekend and left one wasn't bad at all. The right one had a lot of debris inside. But not much gear play in either. I cleaned and applied new anti seize. Put everything back and still have the same faults. I'm not looking at replacing, should I be fine with just the electrical board for the right one? I'm trying to spend the least amount possible. What is the best way to fix this cheaply?
Old 05-03-2020, 05:00 PM
chrisconn04 chrisconn04 is offline
Mein Auto: 00 E39 M5; 07 E64 M6; 11
Just had both of mine replaced/ rebuilt with life time warranty with Jason at Rebuild
https://www.facebook.com/rebuild.org.uk/
Rebuild.org.uk
Costed maybe $600 and my time.
Best option.
Chris
Old 05-03-2020, 05:27 PM
Mein Auto:
I'm unsure if it is the gears or the electrical board. Also typed it wrong the left side (driver) was the dirty one. But I didn't see much play or rounded teeth in either.
Old 05-04-2020, 10:24 AM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
Have yet to run across a DIY on repairing these. Most guys send them in to the experts for repairs. can you buy the electrical board by itself? Its my understanding the MOSFET go bad in these over time. how many miles on the parts?
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
2009 BMW E63 M6, Sapphire Black
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 05-04-2020, 10:28 AM
Mein Auto:
well, just did a search
https://www.m3post.com/forums/showpo...74&postcount=7
https://www.m3post.com/forums/showthread.php?t=735033
https://www.m3post.com/forums/showthread.php?t=1068709
https://www.m3post.com/forums/showthread.php?t=1532408
BTW - the link on his drop box still work and you can see the photos. If you do the repair, please update us with photos. always good to get the knowledge base built up!
Jim from Austin
Old 05-04-2020, 12:48 PM
Mein Auto:
I looked deeper into the codes and it's definitely the electronics. I tried cleaning the gears but that didn't work. I decided I'm going to send it out to get it rebuilt. I will keep you updated.
Old 05-05-2020, 07:58 AM
Mein Auto:
good luck. where are you sending it?
Jim from Austin
Old 05-19-2020, 04:04 AM
Mein Auto:
I sent them out to a guy in the UK. He fixes my old codes but now I'm getting a 2B21 throttle-valve actuator pre-drive check, bank 1. 5E19 Engine management interface. 5FFB Terminal voltage electronic damper control. There are more but I believe those are the ones giving me the DSC fault. Any ideas?
Old 05-26-2020, 09:16 AM
Mein Auto:
slip over to m5board.com and ask the question. more guys over there can help with this engine. The M5 is more active than the M6 so ask in both sections if you don't get a response.
Jim from Austin
Old 05-28-2020, 05:40 PM
Mein Auto:
Thanks for your guys help, got my actuators rebuilt and now she's running stronger than ever!
Old 05-30-2020, 09:11 AM
Mein Auto:
great to hear! drive safe!
Jim from Austin
