Misfire Codes - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-22-2020, 06:44 AM
LMT LMT is offline
Mein Auto: BMW X5
Misfire Codes
Hi all, the idle speed on my 2003 6-cyl X5 has been erratic, so I did a diagnostic and came up with all cylinders misfiring, these are the codes I received in that order:
- P0300: Random/Multiple cylinder misfire detected
- P1352: Misfire during start cylinder 6
- P1343: Misfire cylinder 1 with fuel cut-off
- P1349: Misfire cylinder 4 with fuel cut-offengine
- P1347: Misfire cylinder 3 with fuel cut-off
- P1351: Misfire cylinder 5 with fuel cut-off
I recently had the engine trouble light on with vacuum leak codes and found a ruptured rubber boot, replaced it and the light went off, the vacuum leak codes were gone, I had also replaced all 6 spark plugs - any ideas what could be causing the above codes?
Old 06-22-2020, 07:03 AM
andrewwynn andrewwynn is offline
Mein Auto: '01 E53 X5 Black/Black
Those sound like old codes. You said "the light went off" after fixing the intake leak.
Clear all the codes and see what returns.
On an older e53, the most common random misfire is from dirty injector, dirty plug or bad coil.
Put in some injector cleaner, check your plugs and then if you get specific cylinder error, swap that cylinder with a different one and see if the error moves. If it does the coil is bad. I don't recommend changing all the coils just the one misbehaving.
Old 06-22-2020, 01:44 PM
LMT LMT is offline
Mein Auto: BMW X5
Thank-you Andrewwynn, I'll try your advice and will report back
Old 06-22-2020, 02:11 PM
Misfire Codes
I was chasing codes on my wifeís car for a better part of a month. I acquired a few hands me down coils so I actually was able to swap out coils and that cylinder would be fixed and then another one will be a problem. It dawned on me that Iíve never used injector cleaner and once I use some Iíve never had a misfire again
Sent from my iPhone using Tapatalk Pro
Old 06-23-2020, 01:41 PM
LMT LMT is offline
Mein Auto: BMW X5
I'm getting Liqui Moly Jectron fuel injector cleaner, have you tried it?
Old 06-23-2020, 01:47 PM
No I just used Lucas
Old 06-24-2020, 07:20 PM
Fifty150hs Fifty150hs is offline
Mein Auto: SF Bay Area
I've used it along with a variety of others. They all seemed to be about the same.
