After battery replacement - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-30-2020, 07:06 AM
Jjohnson Jjohnson is offline
Mein Auto:
Hello all new to the BMW world, purchased a 2001 X5 3.0i, seller just replaced the battery, and before replacement all the bells and whistles worked. When checking the car out upon purchase, there are numerous electrical functions that donít work, rear windows, heater/ ac, rear hatch, and prolly others I havenít noticed yet. Car starts fine, runs great, and I drove it home with no problems.
I was pretty sure that there was some kinda reset that needed to be done after the battery replacement that did t get done. Searched google and not finding what I need, tried the oil service reset, wonít work, nothing on dash when hitting trip button.
Seen a blurb on disconnecting the battery for 30 mins and reconnecting to reset Ecu, not sure if thatís gonna do it or not, so came here for help. Havenít went through the multitude of fuses yet in glove box or rear panel, hoping for a easy reset procedure after the battery replacement.
Any help is much appreciated
Old 06-30-2020, 09:37 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Mein Auto: 2006 X5 4.4/2013 650ix GC
The only things that need to be reset after replacing the battery is the sunroof, clock, and date. If I missed anything...I'm sure someone will chime in.
Make sure you know what size battery was used...hopefully they used the proper sized battery (49/H8 battery class size). If they didn't...an undersized battery could be causing the electrical gremlins you're experiencing.
Do you have a battery charger or battery tender? If so, perhaps the "new" battery was sitting on the shelf for a while and is slightly discharged.
Q {BMW CCA Member #191509}
2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 2013 F06 650ix Gran Coupe` (Black Sapphire) 1/13 mfg date
(SOLD)
97 740iL (Arctic Silver) <<~>> 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White)
https://www.bimmerforums.com/forum/attachment.php?attachmentid=637911&d=1538398374&thumb=1&stc=1
Mein Auto:
Tried the 5sec gas pedal, 2 mins key off, pull key reinsert, drive the car for a bit to reset ecu, no help, and also pulled neg batt cable for 30mi s and reinstalled, didnít do nothing either.
Alarm is going off every now and again as well but shuts off after a bit.
Checked all the fuses in the rear compartment, all visually look fine.
Went check fuses in glove box, and wow, there a gazillion, canít read nothing in there, print is way to small, gonna need a magnifying glass to see what Iím pulling.
Almost thinking Iím gonna need to go to a dealer and have um plug in and see what all is going on.
Old 06-30-2020, 09:41 AM
Mein Auto:
Thank you for the input, much appreciated, I drove the car home for1.5 hrs last night, so I would think it would have a full charge at this point. Starts fine, runs great, just some electrical not working. Rear windows, rear hatch, heater ac, right now the defrosters are on, lol.
Iíll check the battery size, just weird half the electrical works fine, and others not
Old 06-30-2020, 10:04 AM
Mein Auto:
Battery is a everstart platinum part#agm H7
850 cold cranking amps
140 reserve capacity
80 amp hrs
So I guess maybe the battery is t the right one, as you stated it needs to be a H8, and this one says H7.
Old 06-30-2020, 10:14 AM
QSilver7's Avatar
80 amp hrs
It's around the lowest specs recommended for an e53 X5...but probably shouldn't create the problems you mention. You can get an idea of various battery specs between the H7/H8/H9 batteries in the chart below. Even though chart below is for East Penn batteries...the specs of other branded batteries will have similar specs for the same class sized batteries. And most BMWs with a "5" (or higher) nomenclature in their model number...uses a 49/H8 or 95R/H9 battery class size. These aforementioned battery class sizes have the electrical specs to power all the features of these larger body BMWs:
(SOLD)
Old 06-30-2020, 10:39 AM
Mein Auto:
Well great, after all the messing around this am, the car now has a rough idle, wtf. Poking buttons and trying to do resets and the idle goes south, jebus
Old 06-30-2020, 04:20 PM
andrewwynn andrewwynn is offline
Mein Auto: '01 E53 X5 Black/Black
I used foxwell to bump my idle up on both mine and wife's x5 and I'm very happy with the result
Sent from my iPhone using Tapatalk Pro
Old 07-02-2020, 08:45 AM
Mein Auto:
When I shut the car off the alarm goes off for a bit, not to long 30 sec or so, while in the glove box checking the fuses, when removing and reinstalling alarm fuse it goes of as well. Any ideas, thanks
Old 07-02-2020, 08:46 AM
Mein Auto:
Went through all the fuses in glove box and only found one bad fuse, was for the rear defroster button. Replaced and light on that button now works.
Still without head, nothing works,
Old 07-02-2020, 10:04 AM
Mein Auto:
Woohoo, got all the havac going, seems the associated 50A fuse In glove box just needed reseated. So heat and air work, ran and all that. No longer getting the alarm either after pulling all the fuses and checking them, alls good with that.
So I still have these problems.....
Upper/lower rear hatch buttons Don't work (thinking the relay in the rear might be buggered)
Both rear passenger windows don't work, haven't a clue were to start
Windshield wipers don't work, says there's a fuse box in the engine bay on the pass side but I do t see it. There's a wiper relay in there so the diagram states.
Any help would be much appreciated
Old 07-02-2020, 03:21 PM
Mein Auto:
Trying now to figure out what's wrong with my rear hatch, top or bottom won't work. The fuse diagram I found( they are like the one I have on google) shows three relays on the right hand side, the one in my car only has one, no plugs for more. I don't have the air leveling system, so maybe that's why. Anyway does anyone e have a clue what's up, I was hopeing it's the rear latch relay but have no way to be sure.
