Cold start misfire - Bimmerfest - BMW Forums
The X5 SAV Forum
Old 06-12-2020, 04:31 AM
Fernando51454 Fernando51454 is offline
Mein Auto: 2004 X5 4.4i
Cold start misfire
04 x5 4.4. I know there are several posts about this issue including intermediate levers. However, my car does not fall in the production range of that issue. Manufacture date 12/03. I live in Florida and as you know itís nit cold here but when I start my car after sitting overnight I get a rough idle. But if I shut it down and wait about 20 seconds and restart everything seems fine. Plugs are new replaced when my valve covers were done about 4 months ago. I had an engine light and the code read random misfire in all but two cylinders but the light went out on itís own after driving a bit and has not returned. I also read that it could be clogged vanos solenoids. I know there are two in each bank for intake and exhaust. Can they be cleaned and new seals put in. Seems like an easy diy unless special tools are need to extract the solenoid. Could it be the coils? I donít know when they were changed last as Iím the second owner and my mileage is at 168k. I find it odd that so many would go at the same time. Another thing an Indy mechanic told me is that it could be a bad injector? A month ago I got an 02 sensor error B2/S1 and replaced it and error code never came back. Thanks for any help on this.
Old 06-12-2020, 06:24 AM
andrewwynn andrewwynn is offline
Mein Auto: '01 E53 X5 Black/Black
Cold start misfire
Cam position sensor is my bet. Do you have a scanner that will show you real-time CPS values? I use foxwell to graph requested vs actual to get a sense of CPS responsiveness. They typical start to fail about 139-150,000 miles.
Sent from my iPhone using Tapatalk Pro
Old 06-12-2020, 06:47 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
https://www.newtis.info/tisv2/a/en/e...sensor/X2t2BfK
https://www.newtis.info/tisv2/a/en/e...shafts/X62rejm
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 06-12-2020, 07:58 AM
Thanks Andrew and Doug Iíll have to look into those sensors
Old 06-12-2020, 08:02 AM
Question is camshaft and crankshaft two separate sensors? Sorry if itís a stupid question
Old 06-12-2020, 05:38 PM
They are the same concept but the cam sensors monitor the cam shaft/s and the crank sensor monitors the output shaft of the motor.
Old 06-12-2020, 05:58 PM
Thanks Andrew. Should just focus on the cam sensors. I just confused by the other poster who mentioned both when you mentioned just the cam sensors
Old 06-13-2020, 04:13 AM
Nuclear engineer
I mentioned both because either functions for the other on failure.
Old 06-13-2020, 04:17 AM
Thanks Doug I guess Iíll have to look into all of it. Do you know in total how many of those crank sensors there are. I know thereís four of the cam sensors from what I looked up. Thanks
Old 06-13-2020, 04:57 AM
Nuclear engineer
Nope. Not for your engine.
Old 06-13-2020, 04:59 AM
Guess I better to more research lol
Old 06-14-2020, 12:34 PM
Doug. Says 4 per car
https://www.pelicanparts.com/cgi-bin...rTech%23item13
Old 06-14-2020, 01:46 PM
N62 has four CPS. M62 has two.
Only intake cam variable on M62. Crank position plus math = exhaust cam position.
Old 06-14-2020, 02:11 PM
Thanks Andrew. my car has an N62 engine from what I know. Can you provide any info on the location of these? I assume all 4 should be changed given the mileage?
Old 06-14-2020, 03:09 PM
Nuclear engineer
B6203 Crankshaft Sensor
B6214 Camshaft Sensor 1
B62141 Camshaft Sensor 1, Inlet
B62142 Camshaft Sensor 1, Exhaust
B6224 Camshaft Sensor 2
B62241 Camshaft Sensor 2, Inlet
B62242 Camshaft Sensor 2, Exhaust
B6229 Camshaft Sensor 2
https://www.newtis.info/tisv2/a/en/e...l-transducers/
Old 06-14-2020, 03:12 PM
They all stick directly out the front of the chain enclosure. About 6-8" off center
Old 06-14-2020, 03:17 PM
Nuclear engineer
https://www.newtis.info/tisv2/a/en/e...-inlet/UM5cxIN
Old 06-14-2020, 03:49 PM
Thanks Doug. You already sent Me two of the four links in a previous reply.
Old 06-14-2020, 03:51 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
They can be inspected and cleaned before replacing but it is good to get sensor data from a scanner.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 06-14-2020, 04:34 PM
Hey Doug is this link you sent me of an N62 engine? The reason I ask is that Andrew said they are in a different location. On the front of the engine.
Old 06-15-2020, 07:44 AM
My mistake I was thinking about the vanos cylinders! N62 cam sensors in the back.
Old 06-15-2020, 02:48 PM
Thanks Andrew and Doug. I might have to look at the solenoids also anyway. I read that they also could cause the issue Iím having so Iíll most likely change everything lol
Old 06-15-2020, 02:50 PM
You have two banks you can at least switch them left to right
Old 06-15-2020, 03:01 PM
Andrew if I switch them wonít I just be moving the issue to another bank and still have the problem?
Old 06-15-2020, 03:02 PM
You hope so!
That's the best way to know where the prvoem is.
