HiFi vs HK - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series & 4 Series > G20 (2019 - Current)
Old 10-23-2019, 06:02 AM
tvel7 tvel7 is offline
Mein Auto: 330xi
HiFi vs HK
Hey guys, in my country the HiFi costs like $500 and the HK about $1100 and it requires Live Cockpit Pro for $3k, so it's about a $4k upgrade. Im guessing the HiFi is the better option considering the price gap, correct?
Old 10-23-2019, 09:13 AM
adityab adityab is offline
Mein Auto: 2011 e90 335xi
Would go have a listen in person. In the e90 the difference was less noticeable than in the F30, to my ears. Not sure how the two compare in the G20.
Old 10-24-2019, 02:51 AM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
I have the none HK and it's TERRIBLE. Just awful.
In the US its about a $900 upgrade. It has to be better. Anything is better than the stock system.
- BMW M340i - Portmau Blue-
Old 10-24-2019, 03:10 AM
Mein Auto: 330xi
Here in Bulgaria it's not the stock, you pay for the HiFi and the HK. Will have to check in the showroom I guess.
Old 11-02-2019, 02:16 PM
RobertaZ RobertaZ is offline
Mein Auto: 2013 F30, 704 SS option
Agreed! The HK is available as a separate upgrade in Canada and I've gone for it every time.
Old 11-16-2019, 12:43 PM
VipinLJ VipinLJ is offline
Petrolhead
Mein Auto: G20 330i, F25 X3, A7, SQ5
I agree with the others. I have the non-HK and it isn't great. Coming from a B&O setup in an A4 B9, this is downright pathetic. Even the HK (which I listened to yesterday in another 330i) wasn't anywhere as good as the B&O in the Audi. Slightly better than the ordinary Hifi system for sure. But yes.
Old 11-16-2019, 01:11 PM
SteveinArizona SteveinArizona is online now
Mein Auto: BMW 530e
I think it depends on you. If you are an audiophile, you need a high quality system; if you mostly listen to talk radio it doesn't matter. In between becomes an issue of how much you appreciate good music and how the extra cost factors into your purchase.
Old 11-17-2019, 02:23 PM
BenjaminBMW BenjaminBMW is offline
Mein Auto: 2018 X3 M40i
Agreed. In the States, the HK add-on isn't worth the price. The bass is muddy. The highs are mellow.
As mentioned above, Audi does awesome things with the B/O upgrade.
________________________
Current Garage:
2004 Infiniti G35
2016 Porsche Macan Turbo
2018 BMW X3 M40i
2018 BMW M5
2020 BMW M340i
Old 11-18-2019, 02:18 PM
sekitori sekitori is offline
Mein Auto: 2012 BMW 328i
The problem is that the B&O system is expensive--very expensive. If you spend a huge amount of time in your car and want the best sound possible, it may be a good idea. If on the other hand, you drive an average amount of time and can put up with reasonable HK sound, that may be a better way to go. If you care to spend money on a B&O audio setup, I would look into their home systems instead.
Old 11-18-2019, 02:58 PM
Petrolhead
I totally agree with you. Except I was talking about the B&O system in my A4 B9 which was a $950 addition (H-K is $875 for the 3 series). That B&O sounded so much better than the H-K in the bimmers. But again. Someone else might like the H-K in the Bimmer over the B&O in the A4. Itís all subjective.
Old 11-22-2019, 06:28 AM
tvr1979 tvr1979 is offline
Mein Auto: 2005 330ci
The HK in my older BMW doesn't sound any better than the basic radio in our Maxima. I didn't think it worth the money for the uprated HK in the M340i I ordered.
Old 12-02-2019, 09:19 AM
Calamari Calamari is offline
Mein Auto: Focus Sport
I think that more cost effective option is to order HiFi and replace factory speakers with Bavsound stage 1 kit or ETON BMW speaker set (100% plug and play). If you're in the US, then Bavsound is easily available. If you'r ein the EU, then ETON speakers are the way to go.
I've replaced all mid and tweeter speakers in my G20 with ETON speakers and it's a really big improvement over factory HiFi speakers. Sound is much clearer, more natural, and even has a decent kick in mid-bass range. Most importantly it doesn't fall apart when you crank the system up above 60-70%.
Total cost of ETON set is less than 400Ä (including shipping). This upgrade replaces the center speaker (mid+tweeter) front door (mid+tweeter) and rear door (mid) speakers.
Old 12-03-2019, 11:56 AM
Hangman4358 Hangman4358 is offline
Mein Auto: '14 F31 328d SportLine
To point out to the US posters. In most territories BMW has 3 levels of stereo. Base, HiFi, and HK. In the US the HiFi system is standard equipment and HK is the upgrade.
The OP can get what is the US base system for $500 or the HK system for like $4k because they need another package as well.
OP, from the sounds of it you weren't planning on getting the Live Cockpit Pro so in your case I would do what Calamari proposed. Get the HiFi system and then get an after market plug and play system.
The main reason to get the HiFi system is because it has more speakers and an Amp over the base system which has no separate amp last time I checked.
Old 01-03-2020, 02:07 PM
ideaboy ideaboy is offline
Mein Auto:
HiFi sound good if you will be use those settings:
Name:	?????? ?????? 2020-01-04 ? 01.06.06.jpg
