F30 OEM Backup / reversing camera retrofit installed! - Bimmerfest - BMW Forums
Do-It-Yourself H.Q.
Old 08-18-2013, 02:34 PM
BMW_F30 BMW_F30 is offline
Mein Auto: 2013 335i
I'm active on f30post.com but thought this would be of interest to some who don't frequent those forums. I've read here before, just never posted until today.
The 2013 car I purchased came with PDC and Navigation but did not have a backup cam. Initially I thought the backup cam wasn't important, but after a couple months of ownership, I began to have too many occasions where I said to myself, why didn't I get itů..
So, after some research I found Bimmer-tech and was pleased to see they offered an OEM retrofit kit for the backup camera. After some emailing with Patryk @ Bimmer-tech, he confirmed my options would make this a relatively painless install. And for the most part, it was!
First, for an easy install and proper compatibility, you'll need the following two options:
1) iDrive Navigation
2) Park Distance Control (rear only is OK)
A week later a box arrived via DHL containing the following items:
OEM camera module (and OEM mounting screw)
OEM trunk handle with OEM camera pre-installed
Wiring harness and camera cable
ODBII cable with RJ45 on other end to connect to computer for programming
OEM wire taps for 3 of the wires (yes, BMW makes wire taps for repair purposes)
Several plastic wire ties
Install manual
After reading through the manual, and a couple clarification emails with Bimmer-tech, I felt I was ready to tackle this project. First thing was to follow the advice from Patryk (and the manual) and make certain sure I had the following tools:
#2 Philips screwdriver, torx driver with 3 bit sizes, 10mm socket wrench, wire cutters (to trim the wire ties), a plastic poking tool (to help insert the pins into the factory harnesses), and a set of plastic trim removal tools. Definitely be sure to get trim removal tools!
The retrofit required I remove the following interior parts from car:
Under dash panel
Front/rear door floor sill trim
B pillar lower trim
Rear seat shoulder bolster trim
Trunk trim on right side
Trunk floor trim
Trunk lid trim
Dash trim
A/C and radio/CD trim
iDrive Navigation unit (Nav did not need to be fully removed, just enough to expose the main harness).
Took about 2.5 hours to remove all trim pieces (and about 1 hour to reinstall later). The biggest pain was to remove the OEM trunk release handle. The trunk release handle is held in place with pressure clips. The trouble is the clips are tight and the space for your hands is small. Finally got it after 30 minutes of fiddling.
From there I ran the camera cable starting at the trunk handle hole, through the trunk to the underdash area on driver's side.
Next, was to run the main harness which starts under the drivers dash (and attaches to the camera module). Three wires go to the iDrive unit. All 3 wires came with the appropriate pins so all I had to do was push them into the corresponding holes in the main iDrive connector. Fairly easy once I removed the iDrive unit.
The next two wires went to the communication protocol that allows modules to talk with each other. These wires are tapped using the supplied OEM wire taps and the wires are located along the driver's floor, in a harness that runs to the driver seat. Not terribly difficult since the manual described the correct wire colors and those were easy to find in the seat harness.
Last two wires were +12V and GND. GND was a short run that ran behind the carpet to the drivers side underdash lamp. Here I used a supplied OEM tap to connect the camera GND to the lamp GND. Easy. The +12V wire was run along the floor, next to the camera cable until I reached the rear fusebox located in the trunk floor. The rear fusebox came with the 5A fuse already installed in the empty fuse port already designed for the camera module. All I had to do was push the pin into the empty slot. It was a tight fit and the plastic push tool helped.
I completed mounting the camera module under the dash (perfect fit) and then returned the iDrive back to the dash and I reinstalled the dash trim.
I then contacted Bimmer-tech and received an email advising me of software to pre-install so they can connect to my car. Requires a Windows PC and Internet connection where your car is located. The software took about 20 minutes to download and install and then I contacted Bimmer-tech to connect. Once they contacted me, the programmer took over and programmed my car. Took about 1 hour to program and test.
The OEM camera works the same as if it was factory installed. I compared to a friend's car that has a factory installed rear camera and indeed this one works the same. Everything is there, parking aid lines, PDC obstructions shown onscreen, and all controls in iDrive.
The best part about the rear cam is that the video image appears almost immediately after starting car and placing car into Reverse. For anyone with CIC iDrive this will be a huge plus since the iDrive typically takes up to 20 seconds to startup and show the PDC image.
I highly recommend anyone with iDrive Navigation and PDC (rear is OK) to consider the rear camera retrofit. You won't be disappointed. Based on my research Bimmer-tech is the only vendor offering a true OEM solution. And Patryk and his programmer were a pleasure to work with. I would recommend Bimmer-tech.
BTW, Bimmer-tech also offers a non OEM retrofit which is less $ and also works with cars lacking PDC. I cannot comment on this kit as I have no experience. Just saw it on their website and briefly discussed with Patryk.
Here's some pics from the kit and the final view in iDrive.
Old 09-12-2013, 01:37 PM
cartronic cartronic is offline
Mein Auto: bmw e39
hello,
could you please post the Install manual !!
your help and support are highly appreciated!
best regards.
Old 11-03-2013, 09:42 AM
rjn21 rjn21 is offline
Mein Auto: M5 2014 LCI with CP
Atttached
Old 11-22-2013, 04:22 AM
Willian Willian is offline
Mein Auto: BMW 320i
Hello.
Very informative post.
Keen in carrying out this retrofit.
Can you PM me on the pricing on this project (hardware & coding)?
Thanks!
Old 09-25-2014, 12:48 PM
bulletguy bulletguy is offline
Mein Auto: 328d
What was the price of Kit?
Old 01-20-2015, 01:50 PM
BXL4 BXL4 is offline
Mein Auto: 1999 M-B ML320
Is Nav required to be installed to do this retrofit?
Old 10-06-2015, 07:39 PM
BMWtight2me BMWtight2me is offline
Mein Auto: 2015 320RIP
Do you need the full size nav screen to retrofit the camera? Could I do it in my 320i with the smaller non-nav screen?
Old 10-12-2015, 11:08 AM
mcleod52 mcleod52 is offline
Mein Auto: 2014 328i - Alpine White;
I think if you email Bimmertech they can best answer this question for you.
Living the dream in the Pacific Northwest
2014 F30 - Alpine White, Premium Package, Moon Roof, Suntek CXP Window Tint 35%, Bavsound Stage 1 Speaker Upgrade, Front and Rear Mud Flaps, ECS Matte Blackout Kidney Grills, Coco Matts and Firestone Serviceguard tires. BMWCCA #502883
Old 10-12-2015, 06:41 PM
Sii770i7 Sii770i7 is offline
Mein Auto: BMW F30 320i
Should not be required as a friend of mine had Backup camera with smaller screen and without navigation. Hope this help.
Cheers
Sent from my iPhone using Tapatalk
Old 01-10-2016, 01:04 PM
moke moke is offline
Mein Auto: BMW
Can someone send me copies from his cafd files of cic, rem and trsvc modul. Because I have a problem with my camera. When I put my gear in reverse the screen doesn't switch automatically to camera. I have to select it with the idrive button.
Old 02-23-2016, 06:59 AM
Bigonebang Bigonebang is offline
Mein Auto: F20 120D
Hello to all I need a help. for istall my backupcamera:
http://f30.bimmerpost.com/forums/att...4&d=1437860895
I need some manuals. I do not know if you can have them without installing ista.
how can I do ?
thanks for any help
manuals are the following:
Side footwell trim on right A pillar 51 43 075
Bottom right dashboard trim 51 45 195
Both front door sill cover strips (interior) 51 47 020
Both B-pillar trims at the bottom 51 43 150
Both rear door sill cover strips (interior) 51 47 030
Luggage compartment floor trim 51 47 101
Left boot wheel arch trim 51 47 652
Rear fuse box (release only) 61 14 010
Tailgate trim 51 49 500
Both covers for the rear frame window 51 49 504
Roof lining (only lower it) 51 44 501
Rear seat backrest side section 52 26 508
Unfasten the rear power distribution box 61 14 010
Tailgate button (no longer required) 51 24 146
Head unit 65 12 816
Old 03-21-2016, 12:06 AM
cwario cwario is offline
Mein Auto: F30 328i
I have the same problem, when i put my gear in reverse it appears the pdc and i need to select the camera in the idrive, is there any way i can code it to default display the camera when i put reverse?
Old 08-11-2019, 03:33 PM
spacebug spacebug is offline
Mein Auto: 2013 F31 320d
Hi All,
I appreciate this is an old thread but I have a couple of specific questions relating to this.
Basically, I have an F31 which has done a ton of miles and I'm about to offload it at an auction, or similar. I have an F10 on the way, but despite it having a load of tech already with the car, it is missing the one thing that I really use a lot - The reversing camera.
So here is my plan... Given that the F31 is worth the same with or without the camera, I want to remove the control unit and camera form the F31 and install into the F10.
My question is, if I remove the camera from the F31 will I need to re-code the F31 to tell it that it no longer has a camera? i.e. will it throw an error if I remove it?
I was going to take a look at just disconnecting the Control module initially to find the answer to the question.... But i have no idea where it is, so before I go looking i thought i'd ask the question.
Any help appreciated.
