CSF M4 Cooling Mods quick review, video & pictures! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M3 & M4 > F80/F82/F83 M3 and M4 (2015 - Current)
F80 BMW M3 sedan, F82 BMW M4 coupe and F83 M4 convertible forum. This 5th generation M3 and all new M4 features a 3.0 liter twin turbo engine (engine code S55) 425hp and 406lbs of torque! Heavy use of light weight materials makes this generation lighter and faster then the outgoing E9x M3.
Old 10-15-2018, 12:16 PM
[email protected] mike@x-ph.com is offline
Mein Auto: FBO 07 e92 335i
Top Mount Dual-Pas Charge-Air-Cooler (CSF #8082)
Before:
After:
- Multiple air dividers cast into both the hot/cold side end tanks for optimized air flow through the custom designed CSF liquid-to-air intercooler core (CFD analysis and testing completed to ensure optimal performance)
**60% increase in core size compared to the OEM cooler.
- Left/right, cross-flow, dual-pass core configuration with 2-stage water cooling for maximum efficiency and intake temperature reduction (vs. OEM single-pass vertical-flow design)
- Designed with 3D scanning / rapid prototype technology to ensure precise fitment and maximum surface area utilization.
- “Drop-in fit” design for an easy & quick plug-and-play installation.
- Complete with OEM style “Quick-Connect” water connections and sensor ports.
Front Mount Heat Exchanger ( CSF #8075 / #8075R)
- 2-row 42mm core (dual core) featuring CSF’s exclusive B-tube technology
- Core features an ultra-efficient fin with 6.5mm fin height and multi-louvered design for maximum surface area contact
- Dual-pass flow structure allows the coolant to flow across the core of the radiator 2 times before exiting the radiator for the lowest outlet temperature possible (OEM style design)
- CNC machined, OEM style “quick-connect” inlet/outlet connections
- CNC machined, OEM style mounting brackets & fittings for superb fit and durability
- Includes removable aluminum rock guard
- All-aluminum race style drain plug
- 1 hour “mirror finish” hand polish
- “Drop-in fit” requiring no modifications to install. Accepts all attaching OEM components including “quick-connect” hoses, mounting brackets, OEM X-brace, and all air ducting/shrouding.
- CSF #8075 – 45 row design – no modifications necessary
- CSF #8075R – 50 row ultimate race-spec design (limited availability)
Requires some modification including trimming to bottom side of upper core support.
Dual-Pass Race-Spec DCT Transmission Cooler (CSF #8081)
- Made with CSF’s AC condenser technology using a 1-row super-high pressure 26mm multi-channel microtube
- Dual-pass high performance core with 10 cooling tubes vs. OEM single-pass with return pipe 6 tube design.
- High-density multi-louvered fin design.
- “Drop-in fit” requiring no modifications to install. Accepts all attaching OEM components including oil-line connections, mounting brackets, and shroud/ducting
- Lab tested at ~30% more efficient than the OEM cooler
- World’s 1st and only true “plug-and-play” upgraded DCT transmission cooler for the BMW S55 engine in the BMW F8x m3/m4 (F80 m3, F82/F83 m4)
Old 10-15-2018, 12:18 PM
More pictures
