LED high & low beam bulb replacement for halogens, just plug and play - Bimmerfest - BMW Forums
Old 09-16-2019, 06:00 AM
John122 John122 is offline
Mein Auto:
I have been doing a lot of research and can not find a definitive answer on which LED replacement bulbs I could buy for my on my 2015 328i xdrive that meet the following criteria:
- both high and low beam
- no internal cooling fans on the LED heat sink
- no copper ribbon-type heat sink that needs to sit outside the housing (requiring a hole to be drilled in the back of the headlight housing)
- no coding needed to remove error codes on the dashboard
- plug and play; i.e. no cutting wire harnesses, no tapping wires, replacing harnesses, etc.
- bright white light (although anything would be an improvement over the stock halogens)
Has anyone found a plug and play LED replacement bulb that works well for both high and low beams, and meets the criteria above? If so, could you share your experience?
Old 09-16-2019, 11:01 AM
alpinef30zh alpinef30zh is offline
Mein Auto: 17 f30 318i
i only have low beam, high beam was just too expensive and don't need it anyways
the only problem is it does meet the criteria you mentioned except it does have fans for cooling as far as i know
heres a picture of my car, and another car with LCI LED
top notch quality, everyone tells me it looks OEM.
ID:	864919   Click image for larger version
Old 09-16-2019, 11:21 AM
luigi524td luigi524td is online now
Mein Auto: '17 540xDrive; '98 Z3 2.8
IF you are trying to achieve "better" and "whiter" light by replacing your "stock" halogens -- WITHOUT throwing bulb errors or compromising your BMW's electrical lighting system I'd skip the LED route and go for brighter / whiter halogen "caplets" available from a few REPUTABLE manufacturers (i.e. SKIP the bogus and heavily marketing claims that are all over the Internet. Some of those may actually DAMAGE your car's electrical/wiring!!
Some REPUTABLE manufacturers that come to mind that have brighter/whiter bulbs that will "match" your original equipment bulbs correctly AND optimize the light by taking advantage of your headlight lens and reflector optics include Philips >> https://www.usa.philips.com/c-m-au/c...-bulbs/halogen [check out the CrystalVision ultra] and Sylvania SYLVANIA - now OSRAM SYLVANIA - SilverStar Ultra ... or PIAA Xtreme White Plus High Performance Halogen Bulb.
My opinions are free - you'll get exactly what you pay for!
Current: '17 540 xDrive | '13 X1 MSport | '98 Z3 2.8
Past: '13 535xDrive|'07 530xi|'01 740i|'98 740i|'94 740i |'86 524TD
"Seek and ye shall find" - start with your owner's manual!
Click on the MrRebates logo/link for cash back savings at on-line stores like Tirerack!Mr. Rebates
Old 09-16-2019, 12:44 PM
Mein Auto:
I was going to go with the Sylvania silverstar ultras, but from what I read, they only last 8 months to a year; and I am looking for greater longevity.
Also, I want to avoid LEDs with fans simply because I'd rather have no moving parts that could fail. Thinking of a worst-case scenario, I wouldn't want the fan to fail and the headlight housing to melt.
Old 09-16-2019, 01:28 PM
i always check the lights and turn them on without the engine so i can hear if they are working but yeah it will be a problem if they fail and melt the housing..
Old 09-16-2019, 05:10 PM
John in VA John in VA is offline
Mein Auto: '74 tii / E28s / '03 530i
Much info here - https://f30.bimmerpost.com/forums/fo...play.php?f=430
___________
BMW CCA #30375 - National Capital Chapter
1974 2002tii
1986 535i
2000 328i
2003 530i
2006 330ic ZHP
2015 228i M Sport
Old 09-30-2019, 06:18 AM
Mein Auto:
Thank you all for the input. I went with the Osram Nightbreaker Unlimited bulbs (halogen) for the high and low beams and they make a huge difference. According to what I read, they last about two years or so, but that is fine. They are only $24.99 a pair on Amazon and this is well worth the cost for greater safety. I also adjusted the beam pattern up a little bit to get better down-road visibility. I am happy I went with these and not LEDs or HIDs. They are cheap enough and I don't have to worry about codes, heat sinks, melting the headlight housing, etc.
I also wanted to share a great website for those who are interested in this topic. I found a lot of useful information, charts, reviews, videos, etc. at www.bulbfacts.com.
Old 09-30-2019, 09:35 AM
southcoastguy southcoastguy is offline
Mein Auto: 328xi
Curious about installation process. Can you share? ten minutes later - don't bother; youtube shows me how.
Old 09-30-2019, 11:23 AM
Mein Auto:
Just be careful removing the old bulb... I believe the owners manual says to pull down on the back of the bulb first, then up... Well, when I pulled down on the driver's side low beam bulb, I pulled a little too much and broke the old bulb and the the broken glass ended up inside my headlight housing. It wasn't a big deal though; I just opened up the high beam cover on top and fished out the broken glass with a piece of duct tape balled up and stuck to then end of a long screwdriver. There's a video on youtube by Kies Motorsport that is pretty helpful too. In that video he actually bends the tabs on the housing slightly to help with the removal of the old bulb. I did this when I changed the passenger side and it worked perfectly; no broken bulb. If you do this, just remember to bend the tab back.
Old 10-01-2019, 05:08 PM
Car Fan Car Fan is offline
Mein Auto: X5 Premium SAV
Wow! That looks amazing. How is it to drive?
Old 10-01-2019, 09:34 PM
If you mean by "how is it to drive" how is the light output? it is amazing and i can see the road much better.
Old 10-01-2019, 09:58 PM
heres a picture of light output
Old 10-03-2019, 07:01 AM
Mein Auto: 328xi
Ran into two problems. First, my hands are too big to get good access thru the port to remove the old bulb. Second, I ordered Osram H4 from amazon. They don't fit. They are 3-prong. The H7 currently in my car is 2-prong. Oh well. Now I am in quandary. Went back to Amazon for H7 bulbs. There are several H7 bulbs available, but reviews report a short life. I wanted a brighter light but may just stick with the ones I have now.
Old 10-03-2019, 08:40 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
I believe BMW sells brighter bulbs that have a longer life. Check with your dealer.
I tried Sylvania Silverstars in another car and they too were short lived. The generate a lot more heat, so much so it melted insulation.
