Cooling for B58 - Bimmerfest - BMW Forums
Old 06-28-2019, 08:38 PM
TCoxIv TCoxIv is offline
Tommy
Mein Auto: 2016 BMW Dinan 340
Cooling for B58
I currently drive a 2016 340 xdrive, equipped with Dinan; intake, exhaust, mid-pipe, tune, and springs.
I am looking to have the car run cooler.
After doing some research I have found mixed solutions to this question, and do not fully understand which would be the right choice.
Should I be upgrading the radiator, or intercooler? And if so, would this make much difference?
The car runs and drives phenomenally better when it is colder.
My thoughts are;
https://www.ecstuning.com/b-ac-schni...751220310~acs/
or
https://www.ecstuning.com/b-wagner-t...400001002~wgt/
Any advice would be greatly appreciated.
Old 06-29-2019, 07:13 AM
mbanks21 mbanks21 is offline
Mein Auto: 335i
You need an upgraded intercooler.
*edit* apparently for the 340 the IC is built into the heat exchanger or some ****? I'm bowing out of this conversation.
Old 06-29-2019, 02:50 PM
Tommy
Yeah thats why I was confused.
It looks like this is the way to go.
How easy is swapping a radiator on a 340?
Also, would this void any warranties with BMW?
Old 06-29-2019, 04:12 PM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
I am not sure in three year of existence, someone swapped radiator.
But, yes, it will void warranty.
Old 06-30-2019, 10:05 AM
John MS John MS is offline
Mein Auto: 2014 Glacier Silver 328i
What makes you think the car is not running cool enough?
Old 07-01-2019, 09:41 AM
El_Quandro El_Quandro is offline
Mein Auto: F30 335IAX
Off course it runs better when its colder, every car does ...
Because then there is more oxygen in the same amount of air.
When it rains, or rained there is also more oxygen in the air.
Which results in a bigger bang inside the cylinders.
I think if you change the cooling system to run cooler the car will change the fuel/air mixture etc to make it run hotter again, expecially in eco and comfort mode, because the hotter it runs the more fuel economical it get, to a certain point that is off course.
you can see that when you turn it to sport mode, the oil, get slightly cooler. because then they are aiming to get the most perf. out of the engine, not fuel economy
