Oil change at regular garage - Bimmerfest - BMW Forums
Old 07-01-2019, 06:46 PM
sergio.dipaola sergio.dipaola is offline
Mein Auto: 328d
Will my extended CPO Warranty be void if I have the oil changed at a regular garage?
Sent from my SM-G960W using Tapatalk
Old 07-01-2019, 06:53 PM
Autoputzer Autoputzer is offline
Mein Auto: 2014 535i + 2018 X3 30i
Your car probably requires a BMW Long Life oil, and one specifically made for BMW diesels. Don't expect to find those oils at Jiffy Lube.
Old 07-01-2019, 07:10 PM
BabyUnicornTaco BabyUnicornTaco is offline
Mein Auto: 2008 X5 4.8i E70 Sport
Does your receipt display the brand of oil or just the weight and viscosity?
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 07-01-2019, 07:17 PM
edycol edycol is offline
Mein Auto: X5 35d (traded in)
You can change oil in your own garage or even at parking lot if you want. Per Magnusson-Moss Act as long as you use approved oil and filter, you are fine.
If you take your car to some fast oil change place, they might change your oil but do not expect to be filled with appropriate oil. Now, that is how you get in trouble.
I see you have 328d. You MUST use oil that has BMW LL04 approval. Chances of fast oil change place having LL04 are about 0.
Sent from my iPhone using Tapatalk
Old 07-01-2019, 07:22 PM
Mein Auto: 328d
My mechanic has his Class 1 and runs a legit shop. I just don't want to have any problems. I guess I'll take it to the dealer and play it safe.
Old 07-02-2019, 12:18 AM
floydarogers's Avatar
Pedant and Curmudgeon
Actually, JiffyLube uses Pennzoil. Shell makes Pennzoil. There's one about 1 block from my condo building; I walked in and asked and they have it. I even insisted to see the container.
Don't know if they have a filter. I also don't trust their so-called "techs" at all. And they always try to sell you an oil filter.
Old 07-02-2019, 06:57 AM
Not all Pennzoil synthetics are BMW LL04. The Platinum Euro L is.
Old 07-03-2019, 06:09 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 540i; 428 GC; 340i 6MT
Most dealers run a "Value Service" $89 oil change special. Why run the risk of having some idiot use the wrong oil just to save $20 or $30?
You can do the cabin air filter and engine oil filter yourself.
Current BMW's:
2017 540i MSport
2016 428 GC MSport
Prior BMW's
2018 340i RWD 6MT MSport
2015 X1 35i xDrive
2015 X1 28i xDrive
2014 535i MSport
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 07-03-2019, 10:39 AM
namelessman namelessman is offline
Mein Auto: bimmer
Local value service for F30 is as follows:
$89.95* for 3 Series 4 cylinder models
$99.95** for 3 Series 6 cylinder models
$105.95Ü for 3 Series diesel models
The price includes engine oil filter, no need to DIY.
The cabin air filter is around $40 each, and DIY can be PITA, the panel needs to be perfectly aligned to pop back in.
Old 07-03-2019, 11:35 PM
Figure out how to DIY. When it comes to oil in engine, I donít trust anyone, including dealership.
