2013 335i A/C Issue - Bimmerfest - BMW Forums
Old 07-04-2014, 02:22 AM
avatar220 avatar220 is offline
Mein Auto: '13 335i M-Sport
2013 335i A/C Issue
Hey Guys,
I have a 2013 335i with about 3600 miles. I was making a trip down from NYC to DC (about 400 miles) and about 200 miles in, my a/c stops working. I turn up the fan and you can hear loudly the fan's running, but no cold air is coming out.
So I turned off my car and then waited a minute or so and turned it back on. It blew out cold air normally for about 2 mins and then the same problem happened. I've notice that if I turn off the fan completely while driving, wait a little and turn it back on, cold air comes for a little bit again and then stops (with the fan still running). Does any one know what's happening?
Also I leased the car in NY but can I bring it to a BMW service center down here in DC or Virginia to have them look at it?
Thanks !
Old 07-04-2014, 08:18 AM
LDV330i LDV330i is offline
Mein Auto: 2014 335i M-Sport EB
The warranty is honored by any authorized dealer in the US.
Old 07-04-2014, 11:02 AM
chiefneil's Avatar
chiefneil chiefneil is offline
Mein Auto: 2014 335i, 2002 330i
Originally Posted by avatar220 View Post
Hey Guys,
Thanks !
Bring it to the nearest dealer. If they don't give you a loaner then look into BMW's trip interruption warranty coverage. I believe they cover about 1k in expenses. If you need to get back home before your car is repaired, BMW will also take responsibility for getting the car back to you.
Current Stable: 2014 335i M-Sport // 2012 X5 35i Premium // 2002 330i Sport
Out to Pasture: 2002 X5 3.0i // 1995 325i Sport
Old 07-07-2014, 11:13 AM
**Update**
In case anyone runs into the same problem in the future, here's an update to my A/C issue. Took the car to BMW of Alexandria (closest one) to get it looked at. They told me they ran it for about 15 minutes and the a/c looked like it acted fine. Said it might be a battery issue, but they said if it happens again, just tell my local service center and they'll replace the blower motor since it's covered under BMW warranty.
Old 07-07-2014, 05:26 PM
CE750Jockey's Avatar
CE750Jockey CE750Jockey is offline
Mein Auto: '19 M240 'vert.
**Update**
NO! NO! NO! I had this happen, I know all about it. Your dealer is wrong.
What's happening is that your a/c works fine for a while, but once it's been running for a while, like on a long road trip, there's a valve, I believe it was in the evaporator, that freezes up. Then, it'll pump some or a little air, but it won't be cold. Once the car is stopped and the ice in the valve melts, the a/c will work again...for a while. Then it'll do it again. It's definitely NOT the battery or the blower motor.
Take it back to your dealer and have them look this problem up with BMW service bulletins. It's a known problem. If they give you any crap, PM me, and I'll have my service guy look up my record and I'll give you the exact valve and bulletin numbers. They had to order the valve for me, once in, it took about an hour. Don't take "No" for an answer...it's freakin' hot out there and you paid good money for an a/c that's supposed to work.
Old 07-16-2014, 05:05 PM
Thanks CE750Jockey ! That makes sense why they couldn't find out what was wrong. I'll definitely go do that now that I'm back in my home state. I'll also PM you for the bulletin so I don't have to waste my time with them explaining it.
Thanks again for your help!
Old 08-03-2014, 07:54 PM
Raykiko335i Raykiko335i is offline
Mein Auto: 2013 335i
The same happened to my AC on a return trip from northern VA to Chesapeake, VA. 2 hours into the trip and my AC just died and started blowing hot air. I shut of the air completely and still no joy. But when i used the fan with AC off i started hearing a hissing sound from the engine and turned the AC back on and cold air started to come out. Did you get the bulletin number and the valve that was causing the problem?
Old 08-03-2014, 10:14 PM
brkf's Avatar
brkf brkf is offline
Not Wearing Pants
Mein Auto: Moped
Take it anywhere. Took my BMW dealer a few days to fix my AC though. Second BMW with a failed AC... plus I've always felt their ACs were extremely weak.
Old 02-22-2015, 06:56 PM
Newgene Newgene is offline
Mein Auto: 2014 328d/2018 Diesel X5
That is exactly what ours is doing now. Anyone know exactly which part or service bulletin number this is? Ours is a 328d, but I'm sure it's the same thing.
Old 02-24-2015, 01:37 PM
Thanks for the informational PM, CE750Jockey. Just an update for everyone else. It looks it is service bulletin, SI B64 06 13. I spoke with the dealership, and they were aware of it. The cause is a frozen evaporator coil due to position of the evaporator temperature sensor. The fix is to install a new evaporator temperature sensor adapter.
If it turns out to be anything other than that, I'll definitely post back.
Old 07-10-2019, 06:47 PM
jeffilano jeffilano is offline
BMW_Cholo
Mein Auto: 335ih, 328d, M3
Just had this done on my 2013 BMW 335 Activehybrid 3 I have had AC issues for years on this vehicle and it currently only has 74K miles on it. The part known as the Adapter Evaporator BMW (64-11-9-350-495) only cost $2.00. The replaced it today but I scratch my head as to why after taking the vehicle into several BMW Dealership Repair facilities not a single tech knew about the SB 64 06 13 and Defect Code 6411794000 until today. Could have avoided sweating during the summer for the past several years. Has anyone had any fan issues that impacting the AC unit with their 3 series? Or after the adaptor still had issues with the AC freezing and blowing warm then cold air? Thanks!
