Z3 Gauges in dash not lighting up - Page 2 - Bimmerfest - BMW Forums
Old 11-23-2016, 10:18 AM
Mike Swing's Avatar
Mike Swing Mike Swing is offline
Mike Swing
Send a message via AIM to Mike Swing
Mein Auto: 2000 Z3M 2007 530i
Full instructions here: http://www.pelicanparts.com/BMW/tech...eplacement.htm
Mike Swing
Old 05-14-2017, 06:37 PM
Lilblew Lilblew is offline
Mein Auto: 2000 BMW Roadster 2.3
My problem is the car stays running with key off and headlights on. The ignition lights turn on with the headlights also.any ideas?
Old 05-15-2017, 02:20 PM
If my ignition comes on with headlights or the car stays running with key off and headlights on is this a headlight switch problem? Just bought the car its a mess. Brake lights dont work unless key is on. Has a crome plastic knob, might be a different switch from original.
Thanks my friend
Old 05-19-2017, 09:09 AM
Z3notZ8:( Z3notZ8:( is offline
Mein Auto: 1997 Z3 2.8 Dinan
My dash lights went out when I adjusted the temperature gauge. I found the cause for this while investigating why there was static in my speakers that sounded like the wires were shorting out. When I removed my aftermarket radio, I found that the installer simply twisted the speaker wires and wrapped them with electrical tape. The installer actually used a butt-connector on the dimmer wire but didn't crimp it properly, so the wire came loose. It probably came loose and shorted out when I turned the temperature control knob because there was another wire, not in use, that was left just dangling. This dangling wire was lodged in the temperature control mechanism when I removed the radio.
I have fixed the wiring issue PROPERLY, but I had no clue what was wrong with my dash lights until reading this forum. Thanks for sharing your experiences.
gauges, lights, roadster, z3
