Diesel exhaust smell under hood - Bimmerfest - BMW Forums
Old 07-23-2019, 02:00 PM
DarthBulk DarthBulk is offline
Mein Auto: 2014 BMW 535d xDrive
I have a 2014 535d xDrive, 56000 miles. Recently I noticed a slight diesel exhaust smell coming from under the hood of my car. The car seems to run fine despite this. When I pull the sound deadening engine cover off and look at where the injectors are on top of the cylinder head, I notice that the plastic cylinder head cover is melted a little around the front injector and partway back to the second injector. This cover does not seem to be getting hot to the point of melting any more (maybe something happened a single time?), as the engine seems to run ok and when I took the car to the dealer, they found a code that the front O2 sensor heating circuit is reading open, but nothing else. The dealer, however, said they have never seen anything like this and would probably have to replace the cylinder head ($$$$$$). My car is not under warranty.
I did a little more checking on my own, and sprayed some cleaner around that area of the melted plastic (wanted to see if any new soot or oil would appear there while driving) and found that where the cleaner pooled at the base of the injector head, tiny bubbles would float out while the engine was running. I do mean tiny. They lazily would float out from around a couple of the injector bases.
So has anyone seen something like this before? Is there anything else I can check before I look into a new cylinder head? I would think that if the injector copper washers were leaking, the bubbles would not lazily float out...but would come out with some force. I had the recall on the EGR cooler performed, and the dealer did nothing except look at the cooler and say "Yours does not suffer from the leaking EGR cooler problem" and they didn't replace anything.
Any tips or advice on what to check would be appreciated. The pictures don't make it very clear, it is tough to get a good picture of black plastic.
ID:	858979   Click image for larger version
Old 07-23-2019, 02:18 PM
ezaircon4jc's Avatar
ezaircon4jc ezaircon4jc is offline
Mein Auto: 2014 535i M Sport
I don't have a diesel but ran across this video a while ago. Does it help?
Mike
2014 535i M Sport, Carbon Black/Black (mine)
2012 535i, Dark Graphite II/Oyster (wife's)
Joshua 24:15; Phil 4:13
https://www.newtis.info/tisv2/a/en/f10-535i-lim/
Old 07-23-2019, 02:37 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Yep, that MB has a really nasty engine. Anyone that would open up an engine that filthy is begging for problems.
Important!
It is essential to adhere to conditions of absolute cleanliness when carrying out repair work on the fuel system.
Do not allow any dirt particles or foreign bodies to get into the system
Use only fluff-free cloths
Remove all traces of dirt contamination before dismantling lines or separate components
Seal all fuel system openings with protective caps.
https://www.newtis.info/tisv2/a/en/e...nes/1VnX8Dufec
I had never before heard of a diesel injector exhaust leak, so I searched with my not-G00gle search engine and got ZERO on point hits. Best wishes.
Old 07-23-2019, 03:02 PM
Thanks for the replies, I am checking out that video to see if it helps any. It would be a lot of work, but I really would like to look under that plastic cylinder head cover to see what is going on there.
Old 07-23-2019, 03:12 PM
Nuclear engineer
Here is the NewTIS.info sort file for "injector". Leak and exhaust are too commonly associated with injector to be useful as filter words.
https://www.newtis.info/tisv2/a/en/f...rch?q=injector
diesel, melted cylinder head cover, smell
