should steering wheel be straight after alignment - Bimmerfest - BMW Forums
Old 02-13-2020, 01:03 PM
SunglassesGuy SunglassesGuy is offline
Mein Auto:
hey guys, just rebuilt entire suspension and steering and brought it to BMW for alignment.
steering wheel is slightly off center, maybe 3 degrees, enough to be annoying to me.
should that be straight after alignment and is it part of the procedure? wanting to know before i complain to SA
thanks!
Jim from Austin
2004 BMW E60, N62, GA6HP26Z, Dynamic Drive, Sport Pak, Logic 7, Bilstein B8's, Ti Silver
1990 Pontiac Firebird Formula, T-Tops, 305 TPI, Maui Blue
Old 02-13-2020, 01:41 PM
kd7iwp kd7iwp is offline
Mein Auto: 2001 325i
Good question. I had the front subframe out to remove my turbos and then I did an alignment afterwards and I also have a tilt in the wheel. I would imagine it should be straight. I suppose I did also put my winter tires on shortly after the alignment so perhaps they have a problem.
Old 02-13-2020, 01:51 PM
habbyguy habbyguy is offline
Mein Auto: 2006 530xiT
Yes, it should be centered.
Keep in mind that on some highly crowned roads, it's sometimes necessary to "steer into" the crown a tiny bit to keep the car tracking correctly, but that shouldn't be the case for most driving. Some of the roads in south-central Austin (the only surface roads there I've driven much) DO have pretty healthy crowns (presumably to assist in shedding the HUGE amount of rain you get occasionally).
Old 02-13-2020, 02:19 PM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Very often, particularly on BMW, the first step of an alignment by BMW procedure is to set the steering to 'zero' and lock it in place. Let's see about your car ....
Version without active front steering:
If necessary, remove steering gear cover at side
Move steering into straight-ahead position by means of markings on cap (1) and steering gear (2).
Align steering wheel and secure with steering wheel arrester.
Old 02-13-2020, 04:13 PM
dharmabmw dharmabmw is offline
Mein Auto: 2006 530Xi
It's a case of the mechanics either being lazy or too hurried to take the final step. Not sure what you paid but I have experienced this exact problem as the shop does the work on a fixed price and wants to turn over the vehicles as quickly as possible.
2006 E61 MT
2010 E91 MT
Old 02-13-2020, 06:51 PM
Mein Auto:
thanks guys, I have active steering. any of you know how to read an alignment printout? I've never studied it before, but I'm not convinced it is good.
Jim from Austin
Old 02-13-2020, 06:54 PM
BabyUnicornTaco BabyUnicornTaco is online now
Mein Auto: 2008 X5 4.8i E70 Sport
Post your printout. Also search for Bimmerfest member “ard” and click on his alignment link. It’s a big help.
2008 X5 E70 4.8i M-Sport
2008 550i RPI Exhaust, RPI Ram Air
Old 02-13-2020, 07:02 PM
Kurt_ Kurt_ is offline
Mein Auto: 2008 535xit
The shop should know better. Personally, I would get underneath and give each tie rod equal turns in the appropriate direction until your steering is straight.
While you can unbolt the steering wheel and move it back to straight, you shouldn't, because your steering rack will be off center.
Old 02-13-2020, 07:04 PM
Mein Auto:
Here is the sheet from BMW and also specs that Bently publishes. I have Sport Suspension.
ID:	881751   Click image for larger version
Jim from Austin
Old 02-13-2020, 07:13 PM
Right and left front looks too far off. Did you ask why the after measurements are so far off? Last time I saw that as the difference in alignment correction there was suspension damage.
Old 02-13-2020, 07:25 PM
Mein Auto:
No, I have not been into this dealership in a long time. Way back when, they used to be really good. I'm not so sure anymore. I trusted them based on the past, didn't even look at it until after I was driving down the road and noticed steering wheel off axis. Car has not been in accident. I did rebuild entire suspension, but made a point to torqu everything down at resting position, or as close as I could get.
What part looks off - everything on front?
Jim from Austin
Old 02-13-2020, 08:32 PM
Alignment looked better before, save for rear camber.
Old 02-14-2020, 02:19 AM
mtnbimmer mtnbimmer is offline
Mein Auto: 325ix, 530xi
Short answer-yes.
If it was easy, anybody could do it.
Old 02-14-2020, 03:02 AM
BMW dealers go for the green “within limits” and not for specific numbers unless you make them.
Old 02-14-2020, 03:03 AM
Nuclear engineer
^^^^ +1
To learn 'alignment', ask yourself why not align to straight ahead - zero toe - and zero camber? Learn the why.
Old 02-14-2020, 05:22 AM
Mein Auto:
Here is where it says to "Move steering into straight-ahead position by means of markings on cap (1) and steering gear (2).
Align steering wheel and secure with steering wheel arrester."
https://www.newtis.info/tisv2/a/en/e...ement/1LtFbLKe
The start of the alignment procedure
https://www.newtis.info/tisv2/a/en/e...rement/7DZbdQz
Jim from Austin
Old 02-14-2020, 06:41 AM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: e39, e83, e60
What i would have done is ASKED them... but im sure by now its been a few days....
your case would have been much stronger if you would have returned 15 min after picking it up....
Ive i was a service writter and a customer came back a few weeks or days later.. ID compare the mileage from when it left and ask you what you hit
*you have nothing here to work with
but in your defense yes it should be zero in a text book world
Specializing In Breaking Things Professionally
15486372<-----
Old 02-14-2020, 08:14 AM
Mein Auto:
It was just yesterday, late afternoon.
I was comparing past alignments with this one. Same dealership. None of them have been that far apart on front camber.
Pretty sure the one from 2013 is the same day, print out is off. But why the different values? Are these 2 different units of measurements?
ID:	881779   Click image for larger version
ID:	881781   Click image for larger version
ID:	881783   Click image for larger version
ID:	881785   Click image for larger version
Jim from Austin
Old 02-14-2020, 09:09 AM
Burning2nd's Avatar
Under the lift arms
call them We cant help you,
you have to take this up with them
15486372<-----
Old 02-14-2020, 09:10 AM
BAR and psi? Both units of pressure.
I'll never go to the dealer for an alignment again.
Dealers will not adjust anything up front but toe. Camber is "not adjustable" if you ask a dealer. Ask a decent mechanic and he'll pull the alignment pins on the strut tower and adjust camber from there.
Old 02-14-2020, 11:08 AM
Mein Auto:
I was referring to the 2nd and 3rd photo from June 2013. 2 different print out types from the same day, but degrees totally different?
Jim from Austin
Old 02-18-2020, 04:46 PM
ppointer ppointer is offline
Mein Auto: '11 335i, '00 323it
+1 on the comment about the fronts looking off. While this is definitely an improvement from where it was, the fronts should be closer in the camber measurement. The front left is in the green but just barely. I would go back and ask them to get the left front camber to measure closer to the right front, and then get the steering wheel centered. Alignments are expensive enough that they should do it right, not just into the green and call it a day thinking you won't know any better.
Old 02-18-2020, 05:15 PM
Jimmy335i Jimmy335i is offline
Mein Auto: 335i Convertible
Yes, your steering wheel should be perfectly centered and the sad thing is it is stupid simple to do. You should take it back and make them fill the tank for the inconvenience
Old 02-19-2020, 06:15 AM
coolmellowdude coolmellowdude is offline
Mein Auto: 2004 325i
Tie Rods need adjusting.
Old 02-19-2020, 07:08 AM
Mein Auto:
Are you referring to toe? What do you think it should be set at?
Jim from Austin
