Power window reset - Bimmerfest - BMW Forums
Old 01-15-2020, 02:46 PM
Eighthnote Eighthnote is offline
Mein Auto: 2001 3.0i Roadster
Power window reset
Hello, I learned how to reset the power windows when they start to "act" up. For example my driver's window would only roll up if I kept my finger pressed on the up button. After the reset it started working the way it was meant to. However every time I roll the window all the way down the auto up feature again stops working until I do the reset again. Any thoughts? For those that haven't tried the reset it's very simple. While holding the down button roll your window down. Keep pressure on the down switch for fifteen seconds. Then roll the window up all the way and again keep pressure on the up button for fifteen seconds. The window will operate as it should. As long as I do not roll the window all the way down mine keeps working. Anyone else ever do this? Thanks for reading...........
I just stopped in to see what condition my condition was in.
Andrew
Old 01-15-2020, 05:45 PM
RAD RAD is offline
RAD 330i
Mein Auto: 2001 330i
An excellent description of exactly the same problem my wife's Z3 Coupe has. Have not found and answer yet other than - don't let the window go all the way down
Old 01-15-2020, 06:34 PM
[email protected] tgilbert@embarq is offline
terry2001z3
Mein Auto: 2001 z3
have not had your problem before but.One of the big reasons for problems on power windows is bad bushing or lubrication.Take the door panel off and see if there is any binding or lack of lube .add a liitle lube and see what happens .
Old 01-16-2020, 03:45 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Originally Posted by Eighthnote View Post
... my driver's window would only roll up if I kept my finger pressed on the up button. After the reset it started working the way it was meant to....
Originally Posted by [email protected] View Post
... .One of the big reasons for problems on power windows is bad bushing or lubrication.Take the door panel off and see if there is any binding or lack of lube...
Do you think that too much friction in the sliders can disable the auto-up feature for which the window needs to be reset?
That might mean the motor can tell the difference from one pull of the switch for auto-up, versus a continuous pull on the switch.
Or it might mean that the motor senses a static friction before the window moves and disables the auto-up.
These explanations seem unlikely and make me doubt that auto-up is affected by the condition of the sliders.
The symptom of excessive slider friction is usually slow windows.
Old 01-16-2020, 07:53 AM
terry2001z3
Mein Auto: 2001 z3
I belive it could be a problem that needs to be checked.he said that when operateing the drivers side up and down the problem happens.that tells me its that door with the problem .he has reset it many times.he does not say if the problem happens from both doors.there could be several reasons how ,where, why but I would make sure that the mechanicals are working fine first because that costs nothing to look at and to lube.This is just my opinion
