F020 (F02x, F03x, F08x) I-Level flash - Bimmerfest - BMW Forums
Old 01-18-2020, 07:16 AM
RageF22 RageF22 is offline
Mein Auto: 228i
I-Level flash
Hy guys.
i just wanted to flash my 2014 F22 228i from I-Level 14-03-503 to 19-07-530
now i got this message in E-Sys
In english:
"The TAL contains transactions for installing and removing hardware, so an individual data recovery is carried out.
If the coding / programming transactions are to be carried out, you must deactivate hwinstall and hwdeinstall in the TAL matrix in the "SG" tab
Do you want to perform an individual data recovery?
I already performed the "individual data recovery".
The reason for the update is, that i retrofitted the LCI led-headlights to my car with the SA code: S552A
And now my ASCM got some error codes, because E-Sys crashed while i performed the coding for the headlights.
The codes are in the pdf file. https://drive.google.com/file/d/1kaw...ew?usp=sharing
Another problem is: my mirror indicators stop working when i turn on the headlights (low beam). But they're just working fine with just the DRL.
I would be so thankful if anybody could help me out, because i'm new to coding and flashing with E-Sys and Rheingold/ISTA+.
I'm currently working with:
Launcher =
2.8.2
Esys =
3.27.1
3.30.1
Psdzdata =
4.21.12_Full
ISTA+ =
4.21.12
Greetings from Germany.
Old 01-19-2020, 09:01 AM
shawnsheridan's Avatar
shawnsheridan shawnsheridan is offline
bimmerfest Supporting Member
Mein Auto: 2016 650i GC M-Sport
In TAL, make checkboxes ONLY at blFlash, swDeploy, and cdDeploy.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
Old 01-19-2020, 12:16 PM
Mein Auto: 228i
Thanks for the answer!
Already got another hint, that i should check, if my typeKey is still "1F53" and not "1F51".
And this was the case. it was the wrong typeKey. because i'm driving a reimported US car in Germany.
coding, esys, f22, flash, fxx, i-level, led, led headlights, retrofit
