Lower temp thermostat for an N55 engine? - Bimmerfest - BMW Forums
Old 02-13-2020, 05:32 AM
The German The German is offline
Mein Auto: E53,E39,E30,E36
It seems to be pretty easy to find lower temperature (90c) thermostats for the N62 engine, but does anyone know where I can get a lower temperature thermostat for an N55 engine?
Old 02-13-2020, 07:24 AM
Zulu95's Avatar
Zulu95 Zulu95 is online now
Mein Auto: 2001 X5 3.0L
To what avail? Electric water pump controlled by the DME.
Sent via Telegraph wires using my Morse Key.
2001 X5 3.0L
2013 X5 xDrive35i
Old 02-13-2020, 07:41 AM
To lower the engine operating temperature and reduce coolant pressure. Pretty common mod for the N62 to make the engine more reliable. I just don't see any lower temp thermostats available for the N55 except one made by Mishimoto that I've heard doesn't actually fit.
Any other vendors that anyone has tried?
Old 02-13-2020, 07:52 AM
Zulu95's Avatar
N62 belt driven pump always turning (pumping) when engine running. N55 ELECTRIC pump. Turns on when the DME tells it to turn on and off again. Otherwise it just sits there looking cool.
2001 X5 3.0L
2013 X5 xDrive35i
Old 02-13-2020, 08:09 AM
Nyc Dito's Avatar
Nyc Dito Nyc Dito is offline
Kinda officially welcomed
Mein Auto: E70 LCI 35d
E70 LCI 35d
E90 LCI 328i xDrive
E39 528i/5 Sport
E28 535is
E84 X1 35ix M package
E38 740i Sport
E39 M5 LMB/Blk
Old 02-13-2020, 08:26 AM
Gotcha. I'm not concerned though with when the water pump turns on or off. I'm looking for the thermostat to open at a lower temperature allowing coolant to flow into the radiator. I believe the stock thermostat opens at 105c and I would like to replace it with a 90c. Thus lowering the operating temperature of the engine from 221 degrees to around 194 degrees.
Old 02-13-2020, 08:39 AM
Doug Huffman's Avatar
Doug Huffman Doug Huffman is online now
Nuclear engineer
Location: Washington Island, Wisconsin, thru Death's Door
Mein Auto: CPO2012 X5 35d M57(E70)
ECU DME controlled thermostat and coolant pump
N55 has an electrically mapped controlled by the ECU thermostat in addition to an ECU controlled variable speed electric coolant pump.
The Digital Engine Electronics (DME) regulate the following temperature range:
Economy mode: 108 C
Normal mode: 104 C
High mode: 95 C
High mode and control operation by characteristic map thermostat: 90C.
I doubt that YOU will find an electrically heated thermostat for a particular engine ALSO with a non-standard wax-pellet motor - itself very high tech.
. The wax element of the characteristic map thermostat contains a heater resistor. The Digital Engine Electronics (DME) supplies the heater resistor with current. This causes the wax element to expand and close the cylinder head inlet against the spring pressure of a spring. The spring has the task of pressing the characteristic map thermostat back into its rest position when the wax element cools down. With the engine cold, the coolant circuit runs via the cylinder head inlet and characteristic map thermostat to the return line towards the coolant pump.
The Digital Engine Electronics (DME) activate the heating element via a characteristic map depending on the current driving situation.
https://www.newtis.info/tisv2/a/en/e...oling/F7kt8r2W
Scepticism and Animal Faith (1923)
Scepticism is the chastity of the intellect, and it is shameful to surrender it too soon or to the first comer: there is nobility in preserving it coolly and proudly through long youth, until at last, in the ripeness of instinct and discretion, it can be safely exchanged for fidelity and happiness.
(The Works of George Santayana p. 65)
Eschew eristical argumentation. I am responsible for what I write, not for your understanding of it.
Old 02-13-2020, 09:30 AM
ArgentoCarNut ArgentoCarNut is online now
What was that?
Mein Auto: 05 M3, '13 TLC, '11X5 35i
It seems like the change the OP is looking to make can probably be accomplished through programming rather than replacing hardware.
Old 02-13-2020, 10:17 AM
This is good information. Thank you. If I could find someone to reprogram my ECU, so the engine temp stays out of both the economy mode and normal modes and stay in high mode or lower (90c seems to work great on the N62). It would save the internal rubber and plastic parts in our engines. Rubber and plastic won't last long at 108c...
Old 02-13-2020, 10:24 AM
deroy deroy is offline
Mein Auto: X5 e70 4.8
If you always drive it like you stole it, itll always be in high mode. Much more fun than a laptop solution.
Verzonden vanaf mijn iPhone met Tapatalk
Old 02-13-2020, 10:42 AM
smassey321 smassey321 is offline
Mein Auto: 09 X5d - 06 325i
There really is no need to do this. I just restored all the rubber/plastic on my 15-year-old N52. Only 2 hoses were close to failing. Both the thermostat and upper radiator hose hook to the top of the head with plastic fittings. This is where the hottest fluid exits the engine. Those were the only 2 that were bad. N52 runs hotter than N55.
112C ECO mode (economy)
105C Normal mode
95C High mode
80C High + mapped thermostat mode
Old 02-13-2020, 10:55 AM
Possibly not as much of a problem on the N52, but lowering the temp prolongs the coolant system as well by reducing pressure. Also keeps the transmission cooler.
For the potential benefits of lowering the temperature in my opinion it's not worth it to run it hotter for the potential economy benefits. There's a reason the Toyota's are considered to be so reliable, it's because they run much lower engine operating temperatures. The high temps of our cars likely aren't doing us any favors in terms of reliability.
