Confirmed: MY 2014 F30 328 has Active Sounds - Bimmerfest - BMW Forums
Old 04-03-2015, 08:04 PM
Polite Canuck Polite Canuck is offline
Mein Auto: 2014 BMW 328i XDrive
It has long been thought that the F30 328 has had Active Sound since 2014, however, so far it has been based on anecdotal evidence. Well, I just wrapped up installing my aftermarket amplifier and I can confirm the unit exists on the 328. Apologies for the quality of the pictures.
Initially, when I saw the two wire harnesses (one going to audio amp and the other to the Active Sound amp), I freaked out thinking perhaps BMW split the 7-CH amp into a 6-1 or 5-2. None of the pictures I had seen of people who had done an amp upgrade before had two harnesses and I immediately thought the worst. A search on Realoem using the part number on the unit (9343317) quickly clarified it is a "Control Unit with Active Sound Design", except the website only shows it for the F30 N55s and the F22 N20s. I am pretty sure the unit is operational since after I was done hooking up my audio amp, it wouldn't turn on when I tried to test it. Turns out I had forgotten to hook the second harness to this Active Sound amplifier and, I guess, that is required to complete the circuit. Click image for larger version
ID:	501705Click image for larger version
MY2014 328i xDrive| Sports Line (ZHH)| Jet Black| Premium Package (ZGA)| ConnectedDrive (ZTY)
Old 04-04-2015, 04:15 AM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW-less (again)
...only in the 328i *Sport Line*?
Old 04-04-2015, 07:24 AM
gkr778's Avatar
gkr778 gkr778 is offline
Novice driver
Mein Auto: 2014 320i ZSP ZMT
Thank you for sharing this information, Polite Canuck! Your photo in attachment 501706 clearly shows the ASD module, as depicted in this diagram:
Good observation regarding the connection to your new audio amplifier. The fact it wouldn't work unless connected to the ASD module suggests that ASD is operational.
So at this juncture, is it safe to conclude that ALL gasoline powered F3x cars in the U.S. and Canada, MY 2014 or newer, not only have an ASD module but one that's actually 'active'? Or just 328i Sport Line, as Saintor suggested?
What the world needs is a few more rednecks - Charlie Daniels
Tell you about rednecks. They’re probably the only people in the whole country that ain’t unfit. - Fred Reed
God and guns keep us strong. That's what this country was founded on. - Lynyrd Skynyrd
Old 04-04-2015, 08:03 AM
Technic's Avatar
Technic Technic is offline
OEM Audio PnP Integration
Mein Auto: 2017 M3
ASD was widely used only on MY2014 models and only on certain trims/lines on certain models.
ASD has been almost completely removed on most models for MY2015. Only M models got it now for sure.
ASD is connected in series with the HiFi OEM amp, and as an add-on in the Top HiFi OEM amp. Meaning, if you unplug the ASD in the HiFi then no audio signal will get to the OEM amp at all. If you unplug the ASD in the Top HiFi system (HK) then no synthesized engine sound will be played thru the OEM amp.
For outside the USA, ASD is connected between the iDrive unit and the OEM speakers. Meaning, ASD powers the speakers directly.
Old 04-04-2015, 08:07 AM
bmw325 bmw325 is offline
Mein Auto: 528i
ASD has been almost completely removed on most models for MY2015. Only M models got it now.
Interesting. So the 2015 528 no longer has ASD?
Old 04-04-2015, 08:08 AM
Well, I certainly have not heard the Sports Line angle before. As plausible as that sounds, I doubt all those people suggesting their MY14 328 loaners sounded better were driving Sport Line.
I'll be putting the trim pieces back together today so I'll try to take better pictures including location of the ASD module. I'll also confirm if the module is visible without having to remove any of the trunk lining.
Old 04-04-2015, 08:10 AM
BobinIl BobinIl is offline
Mein Auto: 2019 X3 Black Sapphire
I don't think it has been covered, but if one has it on their car, can it be turned off?
2019 G01/Black Sapphire/Canberra Beige Vernasca Leather
2019 G30/Bluestone Metallic/Ivory White Leather
Old 04-04-2015, 08:11 AM
Mein Auto: 528i
Yes it can via coding. There are a few different techniques but the most common is to code the ASD module with a model that doesn't have it. Check out the coding forum for more details
Old 04-04-2015, 08:26 AM
Technic's Avatar
Mein Auto: 2017 M3
ASD is standard with the MY2015 528i up to 03/15 production. The F10 535i and 550i never got ASD.
Old 04-04-2015, 08:34 AM
namelessman namelessman is offline
Mein Auto: bimmer
For pre-MY14 that does not come with ASD, can the ASD module be plug-and-play DIY without coding?
Old 04-04-2015, 09:01 AM
Mein Auto: 528i
Very odd that they'd take it away. Cost cutting I suppose.
Nerdboss Nerdboss is offline
Mein Auto: 2015 X3 35i
2015 328i I had as a loaner for two weeks had active sound.
2016 535i | M Sport | Cold Weather Package | Driver Assistance Package | Premium Package | Driver Assistance Plus Package | Multi-Contour Seats | Dynamic Handling Package | Harmon Kardon Audio | Carbon Black Metallic | Ivory White Nappa
2005 530i | Jet Black | Sport Package | Heads up display | Adaptive Xenon | Navigation | Rear Sunshade
Old 04-04-2015, 09:04 AM
Mein Auto: 528i
I don't think it would be plug and play. Pretty sure there would be some coding involved at least of the head unit.But coding is pretty easy to learn and not expensive (just need to buy an enet cable) so I wouldn't let it deter you.
Old 04-04-2015, 09:18 AM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is online now
2020 Z4 M40i
Mein Auto: 2020 Z4 M40i
Can the volume be changed?
Kevin
CURRENT:
2020 Z4 M40i
2019 Chevy Suburban 4X4 RST 420BHP
2013 BMW 135is JB4 convt 6MT
2009 Yamaha V-Star
1998 Ford Ranger 4X4 Splash 5MT
1965 COBRA 550BHP FORD Racing COYOTE TKO-600
FFR Cobra Mk-IV COYOTE 5MT Build Thread
480 WHP of BURBBLES
I LOVE THE SMELL OF BURNT 100 IN THE MORNING
Old 04-04-2015, 09:50 AM
Mein Auto: 528i
Well, the volume increases in sport mode. And I can't confirm this (haven't tried) but the volume might be affected if you change the engine tuning code via coding in the ASD module. For example, "OL" is the highest tune (corresponds to the n20 in the 328 for examoke) and"UL" is the lowest (320 for example). I haven't seen a parameter directly for volume.
Old 04-04-2015, 09:55 AM
Having seen pictures of other people's F30 trunks, these pre MY14 did not seem to have two sets of wire harnesses (one for the audio amp and one for the ASD), whereas mine does. So. If there is no second wire harness in your car's trunk, I don't see how an ASD module would be Plug N Play. The need for coding or not would take a back seat to the lack of harness.
Old 04-04-2015, 10:01 AM
Assuming Technic is correct, and I don't doubt him, perhaps they changed the exhaust design for the MY15 and that makes the ASD redundant? I've certainly not heard anybody say the MY15 sound worse than MY14.
Old 04-04-2015, 10:13 AM
Here are a couple more shots showing the location of the ASD module and the two harnesses. Just a note that I did saw off a small part of the OEM steel bracket on which the ASD and OEM amp were attached to make space for my JL amp.
Old 04-04-2015, 10:23 AM
Mein Auto: bimmer
Sounds like a fair assessment. This is similar to the missing alarm wiring harness for units without OEM alarms.
Old 04-04-2015, 11:05 AM
gkr778's Avatar
Novice driver
Very interesting. If this is the case, it would explain why ASD on my 2014 320i (assuming it's active) is subtle to the point of being imperceptible.
Polite Canuck, thanks again for getting the ASD discussion going as you work on your car's audio system upgrade. Good discussion in this thread!
Old 04-04-2015, 11:09 AM
Technic's Avatar
Mein Auto: 2017 M3
I guess that BMW is just going through their standard cost-saving measures.
To me, ASD is the answer to no question. I mean, ASD standard in models with M Performance exhausts available? Really?
Old 04-04-2015, 11:30 AM
vintage42's Avatar
vintage42 vintage42 is offline
BMW CCA 1405
Mein Auto: 1997 BMW Z3 1.9 5MT
Very interesting. If this is the case, it would explain why ASD on my 2014 320i (assuming it's active) is subtle to the point of being imperceptible...
When I test drove a 328i and a 320i last month, the 328i had a satisfying sound and the 320i had no sound. I had not heard of active sound and figured it was just the engines.
Old 04-04-2015, 11:55 AM
krash's Avatar
krash krash is offline
Mein Auto: 2016 ///M3
Which makes you wonder why they added it to the standard F3x cars in the first place. It wasn't as if customers demanded it. As far as I know, they never even marketed it. What was the point in the first place?
2016 ///M3: YMB, Executive, Adaptive, DCT
Old 04-04-2015, 12:21 PM
gkr778's Avatar
Novice driver
+1
Perhaps the removal of ASD in MY 2015 non M models (as Technic mentioned) suggests BMW is cognizant of the growing consumer and media backlash against the whole concept of ersatz engine sounds?
Old 04-04-2015, 01:50 PM
As I recall, there was a lot of fuss made over the sound of the N20 being too muted. However, it seems the N55 equipped F3Xs were mostly given ASD, and not so much the N20. So it certainly doesn't make sense.
