535d N57 EGR/SCR/DPF Delete - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > BMW Diesel Owners & Enthusiasts
Old 06-11-2019, 10:44 AM
delviacv2 delviacv2 is offline
Mein Auto: 2015 X5 35d & 2011 x5 35d
Hello, I have successfully Deleted my 2015 535d, I gutted the DPF and the SCR AND removed both EGRīs completely also removed the swirl flaps and DEF tank, cleaned my intake manifold and walnut blasted the cylinder head.
The Tuning was done by DUDMD.
I'm going to cover mostly the Removal of the EGR coolers and the coolant lines, since I couldn't fine any info online, the rest was gutting the DPF and SCR there is lots of info online, there is no need to remove the engine mount to replace the DPF unlike the 335d.
Took a lot of research but it went flawlessly, ordered 2 different EGR delete kits on eBay but they don't exactly fit a US car.
First I ordered this kit.
https://rover.ebay.com/rover/0/0/0?m...2F173729214904
This is what comes with the kit:
It looked good until I realized that there is not cover/plate for the intake manifold.
Also there is not plug for the cylinder head coolant port.
Then I ordered this kit.
https://rover.ebay.com/rover/0/0/0?m...2F183636957862
This kit does have the needed cover for the intake manifold pipe mention above also has the plug for the water pump port and the cylinder head port Kind of ***
So this cylinder head port cover is not perfect fit, the plug is very short, although I could of make it work using one of the longer machined plugs from the first kit I ordered but instead I used a hard plastic OEM plug that I seen online while browsing pictures of N57 Cylinder heads, I was a little worry because nothing holds this OEM plug in place other than the 2 -O rings, but it has been there for couple thousand miles now with no issues and it was $4.76
Part number 11-71-8-518-878
https://www.getbmwparts.com/oem-part...20-11718518878
So Now since I want it to remove both EGR's I need a different block off plate to go on the exhaust manifold, I contacted Sebastian Work shop the seller of the kit, and he had the block off plate built for me and that worked great! After that he post it for sale of eBay so now you can get it from him or have a machine shop make one for you.
https://rover.ebay.com/rover/0/0/0?m...2F183805112344
Now on to to the EGR Cooler hoses/lines:
There is 2 hoses that come off the big hose tree right off the water pump, a feed and a return, it goes to the small EGR cooler (Attached to the exhaust Manifold), from there it T off to engine block and it goes to the Urea Injector and back to the water pump tree
This is the coolant tree after I capped the 2 lines with this 2 OEM blind caps
17-12-8-515-062 $5.98
11-53-1-436-850 $5.93
It already had 2 caps in place, I removed the 2 hoses and added 2 new caps.
Now the Connection to the engine block:
This line needs to be removed and there is a OEM bolt and sealing washer that goes on its place, the block actually has threads for this already!
Water Plug: 07-11-9-904-539 $1.67
Sealing Washer: 07-11-9-963-225 $0.40
Have your bucket ready to collect coolant when you disconnect this hose
That take care of the coolant lines, it took a gallon of coolant to refill on my car.
All the vacuum lines can be disconnected and capped at the source(driver side by oil
deep stick)
DUDMD took care of the tuning, the car runs very strong and smooth, there is visible smoke at WOT but I'm ok with that, I left the DOC in place to help with the smell.
Here is all the parts that I removed
This is what it looks like, she's all stock
2015 535d Xdrive M Sport Alpine White
Fully Deleted
DUDMD Stage 2
xHP Transmission Flash
2014 X5 50i M Sport
BM3 Stage 1
Old 06-11-2019, 10:54 AM
Does anybody know how to make this pictures smaller
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old 06-11-2019, 07:44 PM
DESwiss DESwiss is offline
Mein Auto: 2014 535d xDrive
So what advantages does this give you? Was your DPF clogged and rather than replace it for $$$ you decided to delete?
Sent from my iPad using Bimmerfest
Old 06-12-2019, 10:39 AM
My DPF was not clog yet, But I do not want all the crap to continue clogging my intake manifold/ cylinder head, this is what it looked like
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old 06-13-2019, 09:47 AM
jck66 jck66 is offline
Thanks for sharing your photos and process with the group.
Regarding the EGR delete: This a dumb question based in laziness (i.e. it seems like what you did was a lot of work) but would you not have accomplished the same goal by having the tuner program the EGR valves to be closed all the time?
Old 06-14-2019, 08:44 AM
Hello, there may be software way to do it, but EGR coolers have always been problematic, there some cases of fire.
https://www.carcomplaints.com/news/2...r-recall.shtml
also sometimes the piping start leaking and turn the entire engine bay in to a soot basket (this happened to my E70 35d).
in some cases (ford Power stroke) the EGR coolers crack internally and it dumps coolant in to the intake manifold and hydrolock the engine
so I hate them and I preffer to have them removed completely.
There is other ways to do it, some people block the EGR on both sides etc.
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old 07-12-2019, 10:57 AM
Bolosman Bolosman is offline
Mein Auto: F01 740d M Sport
Good Job done there...I too ripped out the EGR valve and cooler, removed the swirl flaps and had the engine intake cleaned and valves walnut blasted. The walnut blasting has made the car run so much smoother and increased the MPG by a few. Plus i now know that there is no more crap going through the intake system.
Not removed the DPF yet though as it's in a healthy state.
the only 2 things i need to find which did not come as part of my specific EGR delete kit are a plug that will fit the inlet manifold and also a plug that will fit the cylinder head so that i can remove that one last pipe that is connected to the cylinder head and inlet manifold.
Old 07-12-2019, 03:29 PM
robnitro robnitro is offline
Mein Auto: x5 35d e70 2011
You just need to plug the side on the exhaust manifold to prevent what delvi said about sooting the bay.
And coolant caps or bypass lines so coolant doesn't go through the cooler.
The egr valve stays shut, no need for a cap on that side. Intake Pressure pushes it harder closed anyway.
Old 07-12-2019, 04:08 PM
Send me pictures of the part you want to delete!
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old 07-12-2019, 10:59 PM
n1das n1das is offline
Mein Auto: 14 535d Xdrive, 12 X5 35d
Smile
Delvi,
Is that you from TDIclub? N1DAS here from TDIclub. it seems many of us here are former TDI owners.
I don't know how to shrink the pics other than to upload smaller pics to start with. Sorry I can't help more.
Must....resist.....urge....to mod.....my 535dx.
David Sterrett, N1DAS
2014 F10 535d Xdrive M-Sport
2012 E70 X5 35d
Why DIESEL is better: (from wxmanCCM)
PM - https://sites.google.com/view/lmarzccm/home
Air Toxics - https://sites.google.com/view/loren-marz-ccm/home
Ozone Precursors - https://sites.google.com/view/lorenmarz-ccm/home
General - https://sites.google.com/view/emissions-general/home
Old 07-13-2019, 09:24 AM
Originally Posted by n1das View Post
Delvi,
Yes David, I left the TDI but never left Diesels
Mod your 535d then we can go and put the Segway on the Dyno again
Untitled by Delvi acevedo
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old 07-16-2019, 12:33 PM
It is Pipe number 6 in the below link...I can get a blank for the end of the pipe that connects to the plastic inlet manifold but not sure if the number 7 end of the pipe in the below link needs blanking off too as this end connects to the cylinder head?
https://www.realoem.com/bmw/enUS/sho...59#11617807481
Old 07-16-2019, 12:47 PM
This kit has it.
https://rover.ebay.com/rover/0/0/0?m...2F173741610490
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old Yesterday, 10:01 AM
This kit has it.
Thanks for that...I've had a look at the kit and I can't see a round bung that would fit into the cylinder head. The only one they show fits into the inlet manifold...I have messaged the seller through ebay to confirm if they do one, so will see what the response is.
Old Yesterday, 10:33 AM
They will make it for you if they don't have it, they made one for me.
Fully Deleted
DUDMD Stage 2
2014 X5 50i M Sport
BM3 Stage 1
Old Yesterday, 12:27 PM
jfxogara jfxogara is offline
Mein Auto: 2011 335d, 2009 G650-GS
Excellent writeup thanks.
