Service Indicator Symbol - Bimmerfest - BMW Forums
Old 02-03-2018, 04:41 PM
smayo964 smayo964 is offline
Mein Auto: 1999 Z3 Roadster
Can someone tell me what the clock like symbol is indicating that is showing up in my service level indicator when I start the car? I do not have the original owners manual and cannot locate the information. This just started appearing when I got back in the car after being gone over a week. The symbol is just above the green LED bars in the middle. Also, is there PDF of the owners manual available I can get my hands on? Thanx in advance.
S. Maykowski, Columbus MS.
My '99 Z3 Alpine White 2.8L Speed Buggy
Old 02-03-2018, 05:20 PM
FZbar FZbar is offline
Mein Auto: 2002 Z3 2.5 Roadster
Worn Out
left front tire brake wear sensor???
Fred
Old 02-03-2018, 07:14 PM
khammack khammack is offline
Warning - Thin Air
Mein Auto: 2002 M Roadster/2014 435i
Quick google found this - https://www.google.com/url?sa=t&rct=...xVlI-RC-tJXNah
2014 435i M-Sport, Mineral Gray, Black Dakota Leather, Driver Assistance Pkg, Prem Pkg, Tech Pkg, 8 Speed Sport AT, Heated Front Seats, Active Cruise Control, BMW MPPK w/MPE, BMW Limited Slip Diff, BBS CH Wheels.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels.
Old 02-03-2018, 07:26 PM
daven daven is offline
Mein Auto: 1999 BMW Z3 Coupe
Its a Service indicator. Best community guess is "Its time to change the brake fluid". which has no connection to reality whatsoever. The only way to get rid of it is to reset the Service counter. Google, YouTube, whatnot - lots of different ways to do it. Some free, some not. Its not telling you anything important and you can ignore it if you like. I don't know what impact it could have at a Big Brother inspection station But You won't crash,die and burn. It drove me crazy, just google the solution and fix it for free.
David
Blue Ridge Mntns, NC
1999 2.8l Z3 Coupe
Arctic Silver
Old 02-03-2018, 08:36 PM
Thanx Daven! LOL. Heck, I thought gravity was going to let go and shift a planet slightly out of alignment. Thanx khammack for the reference.
Old 02-04-2018, 04:57 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by daven View Post
Its a Service indicator. Best community guess is "Its time to change the brake fluid".. .
The clock resets when the Service Indicator light for Inspection is reset. Use this tool:
https://www.ebay.com/itm/Profession-...1X5Ixk&vxp=mtr
"The system also operates a two-year timer, which illuminates a clock symbol indicating that the coolant and brake fluid should be replaced.The SI reset procedure requires that two sockets of the data link connector are joined together for a set period. This connector is alongside the engine, with a circular screw-on cap. Removal of the cap sets the system into 'Service' mode. The clock cannot be reset without also resetting the SI lights, as it takes about 10 seconds of joining the contacts of the data link socket, whereas the SI lights only require about 4 seconds of joining the same contacts."
https://zroadster.org/articles/bmw-z...e-fishwick.72/
Old 04-18-2019, 03:40 AM
Gregkar Gregkar is offline
Mein Auto: BMW Z3
wrong message
Old 04-18-2019, 03:21 PM
240Z2Z3 240Z2Z3 is offline
Mein Auto: 2002 Z3 2.5i roadster
Can this also be reset with the Peake R5 tool? I've had my 2002 for almost 6 years and have not seen that "clock" displayed.
Old 04-19-2019, 04:34 AM
vintage42's Avatar
BMW CCA 1405
Yes, if you have one (Peake is out of business). But I don't use mine for that because this cheaper one is easier:
https://www.ebay.com/itm/Sockets-Oil...4AAOSw4OhcoeGq
