E70 rough idle - Bimmerfest - BMW Forums
Old 07-11-2019, 08:00 PM
LeeroyBrown LeeroyBrown is offline
Mein Auto: 08 X5
E70 rough idle
In my 08 3.0si I recently started having weird startup issues and occasionally at idle the RPM's would dip down or jump. Idle is like 550 ish used to be closer to 650-725 when running good.
Codes are
P0015
P0016
P2A87
P2AA0
P2A9A
Parts new as of last year are camshaft position sensor, both Vanos sensors, All plugs and coils, CCV valve, intake seals, both Intake Manifold Flap Adjuster Units, I have also ran a smoke test to look for vacuum leaks.
Sometimes when it's hot I'll get a long crank time before it starts.
I'm leaning towards injector issues maybe? If I get new injectors do they have to be coded?
