1999 BMW Z3 Roadster - Popping several codes - Bimmerfest - BMW Forums
Old 04-13-2019, 02:02 PM
MCASSICT MCASSICT is offline
Mein Auto:
Just bought a used 1999 BMW Z3 Roadster and after driving it for a couple of hours I could feel a slight wobble. Felt great up to then. Got it home and hooked up the scanner and generated the following codes:
P1520
P1523
P0301
P0302
P0303
P0304
P0305
P0306
Any suggestions as to most likely cause what would generate a misfire on all 6 cylinders? Would the 1520 and 1523 cause the misfires?
Old 04-13-2019, 05:19 PM
NZ00Z3 NZ00Z3 is offline
Mein Auto: 2000 Z3 3.0i
With a warm running engine, check your fuel trims. If they are >8% you have a vacuum leak. I suspect that is your problem.
Old 04-13-2019, 08:48 PM
Mein Auto:
Changed out the two positioning sensors that are referred to by the 1520 and 1523 code, still nothing. turns over but wont fire. I thought maybe since it is a 20 year old car that possibly the fuel gauge was wrong and maybe I had just ran out of gas. Went ahead and put a couple of gallons in but no luck. It did the same thing, turns over fine but wouldnt fire. So then I thought I would try and shoot some ether into the intake to see what would happen. That time it did try to fire. So it seems that maybe there is a bad relay, pump, or filter. Im not excluding a vacuum issue but one of these seem maybe to be a likely call. Any thoughts?
Old 04-13-2019, 08:50 PM
Mein Auto:
I might add that I had let it cool down for a couple of hours before putting fuel in and trying the ether.
Old 04-19-2019, 02:47 PM
Mein Auto:
OK so Ive tried everything I can think of at this point:
Car will turn over fine but no fire:
1) Replaced both the intake and exhaust camshaft sensors based on codes 1520 and 1523, cleared codes; still turns over but no fire
2) Thought possibly the gas gauge was incorrect so put in a couple of gallons of gas; still turns over but no fire
3) Shot some starting fluid into the intake; turns over and fires for a couple of seconds
4) Disconnected battery for 30 minutes and tried restarting; turns over but no fire
4) Checked fuel pump fuses, both OK. Turned key to start and could physically hear the fuel pump spinning. Also pulled the two fuel pump fuses to confirm silent when without fuses and then tried again after re-installing fuses. Confirmed it was the pump I was hearing.
5) Replaced fuel filter; turns over but no fire
6) Depressed test valve on ejector rail (I don't have a gauge), fuel shot out about a foot in the air under high pressure. Released additional pressure until just a small amount was being released. Tried restarting again with test valve depressed and fuel shot back out at high pressure. This tells me that I am getting fuel at some high pressure to the rail; still turns over but no fire.
7) Then considered the possibility that new cam sensors from Autozone may have been faulty (I've had this happen before on another car). Swapped them out for another set; still turns over but no fire.
8) Tried again to disconnect the battery for 30 minutes; still turns over but no fire.
Any ideas would be much appreciated.....I'm running out of ideas!!!!
Old 04-19-2019, 03:25 PM
zed3coupe zed3coupe is offline
Mein Auto: 1999 BMW M Coupe
What engine?
1999 M Coupe.
Old 04-19-2019, 08:24 PM
Mein Auto:
2.5 L
(also since my last update I have pulled two of the coils and plugs and neither appear to spark. In the process of checking the other 4)
Old 04-20-2019, 12:11 PM
Mein Auto:
Well, it turns out I'm not getting spark on any of the cylinders. I'm going to go ahead and replace the crankshaft position sensor even though that was not a code the was generated...hoping its that simple and seems to be the next logical step.
Old 04-20-2019, 01:01 PM
Mein Auto:
That didn't work either!!!
Old 04-20-2019, 02:48 PM
Mein Auto:
Checked main relay and it is opening and closing ok.....
Old 04-20-2019, 03:42 PM
Mein Auto:
OK so now I have a specific question....if this was an EWS issue, would I still be able to get the engine to turnover? I am trying to eliminate the EWS and everything I have found online seems to indicate that when the EWS is an issue, the engine won't even turn over.
Old 04-20-2019, 05:30 PM
You are correct. The car will only crank when the EWS is activated.
There is also a handshake between the DME and EWS called the ISN, a number that has to be the same in both units for the DME to work. You need a BMW specific scanner to be able to get into the module to see the number. INPA is one that will do it, link below to INPA. Also a link to the procedure to align the number in the two units. Have a look to see if the number is correctly set in both units. Its a long shot, but may be your problem.
INPA
https://www.bimmerforums.com/forum/s...xperimentation
Alignment Procedure
https://www.bimmerforums.com/forum/s...ment-with-INPA
Old 04-20-2019, 05:36 PM
Mein Auto:
INPA
Alignment Procedure
Thanks so much for the reply! I was actually just looking into INPA. Thanks for the additional links. I see on Amazon and other locations online it appears to be several different versions of IPNA. This has spurred another question I have since we are new to BMW's (This is our first). After looking up the VIN of this car I show it has the M52TU engine. In everything that I am finding I am seeing stuff for E46 but not M52. Are these two different engines or am I misunderstanding what exactly the different classifications are? Will I need to know this to get the correct INPA software?
Old 04-20-2019, 11:11 PM
The M52TUB engine is the M54 Beta, so you can think of it as an M54. Any 6 cylinder E46 information is OK to use.
Similar Threads
CSF Intercooler for E Chassis N54 & N55 ***NEW PRODUCT*** [email protected] E89 Z4 (2009 - current) 3 11-11-2019 10:21 AM
BMW Lease Rates - May 2008 LeaseCompare Ask-A-BMW-Dealer 52 06-06-2008 12:49 PM
2008 BMW 6 Series tim330i BMW News 1 06-27-2007 08:48 AM
* M6 * - Press Release from BMW Emission E63 / E64 M6 (2006 - 2010) 6 03-06-2007 08:20 AM
BMW's New Six-Cylinder Engines - In Depth sk330i General BMW Questions 7 07-19-2006 05:52 PM
